Arduino - NRF24L01 2.4Ghz Wireless Relay Switch
Intro: Arduino - NRF24L01 2.4Ghz Wireless Relay Switch
Hello world! Today i made a Wireless switch with the NRF25L01 - 2.4ghz Wireless Module. I used a nano in the video for the transmitter but you can change it to a uno if you don't have a nano. Check out the next step for the Schematics, Code's & parts list. Also complete fritzing files included!
STEP 1: Schematic, Code & Parts List.
Wire it up like the above schematics, The Schematic with the NANO is for the TRANSMITTER and the Schematic with the UNO is for the RECEIVER.
MAKE SURE that you have installed the following libraries. Download RF24.hHere
- SPI.h
- nRF24L01.h
- RF24.h
Parts list!
- Arduino UNO for receiver
- Arduino Nano for transmitter ( You can use 2 nano's, or 2 Uno's to if prefered.. i just used a nano cuz its nice and small)
- NRF24L01 2.4 Ghz Wireless Module.
- KY-019 1 Channel relay
- Jumper Wires Set MM/FF/MF
- Perfboard / prototype board for buttons (or just a Solderless BreadBoard)
Good luck!
Buy sensors here: http://arduinosensors.nl
See more projects on my blog! http://blog.arduinosensors.nl/
6 Comments
billwhite0847 4 years ago
C:\Users\BILL\Documents\Arduino\sketch_wirless_relay_recver_aug27b\sketch_wirless_relay_recver_aug27b.ino: In function 'void loop()':
sketch_wirless_relay_recver_aug27b:27:12: error: void value not ignored as it ought to be
done = radio.read(DataMgs, 1);
exit status 1
"Show verbose output during compilation"
option enabled in File -> Preferences.
Hi this the error that will not allow this sketch to compile on arduino uno r3 from Arduino - NRF24L01 2.4Ghz Wireless Relay Switch
please help me
Regards BILL White
koselan77 3 years ago
SeanF114 5 years ago
Arduino: 1.8.6 (Windows 8.1), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Sean\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -ide-version=10806 -build-path C:\Users\Sean\AppData\Local\Temp\arduino_build_337003 -warnings=none -build-cache C:\Users\Sean\AppData\Local\Temp\arduino_cache_909506 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Sean\Desktop\Receiver\Receiver.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Sean\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -ide-version=10806 -build-path C:\Users\Sean\AppData\Local\Temp\arduino_build_337003 -warnings=none -build-cache C:\Users\Sean\AppData\Local\Temp\arduino_cache_909506 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Sean\Desktop\Receiver\Receiver.ino
Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\Sean\\AppData\\Local\\Temp\\arduino_build_337003\\sketch\\Receiver.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\Sean\\AppData\\Local\\Temp\\arduino_build_337003\\sketch\\Receiver.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Sean\\Documents\\Arduino\\libraries\\RF24" "C:\\Users\\Sean\\AppData\\Local\\Temp\\arduino_build_337003\\sketch\\Receiver.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Sean\\Documents\\Arduino\\libraries\\RF24" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Sean\\Documents\\Arduino\\libraries\\RF24" "-IC:\\Users\\Sean\\Documents\\Arduino\\libraries\\RF24\\utility" "C:\\Users\\Sean\\Documents\\Arduino\\libraries\\RF24\\RF24.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Sean\\Documents\\Arduino\\libraries\\RF24" "C:\\Users\\Sean\\AppData\\Local\\Temp\\arduino_build_337003\\sketch\\Receiver.ino.cpp" -o "C:\\Users\\Sean\\AppData\\Local\\Temp\\arduino_build_337003\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Sean\\AppData\\Local\\Temp\\arduino_build_337003\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Sean\\Documents\\Arduino\\libraries\\RF24" "C:\\Users\\Sean\\AppData\\Local\\Temp\\arduino_build_337003\\sketch\\Receiver.ino.cpp" -o "C:\\Users\\Sean\\AppData\\Local\\Temp\\arduino_build_337003\\sketch\\Receiver.ino.cpp.o"
C:\Users\Sean\Desktop\Receiver\Receiver.ino: In function 'void loop()':
Receiver:27:12: error: void value not ignored as it ought to be
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library RF24 at version 1.3.1 in folder: C:\Users\Sean\Documents\Arduino\libraries\RF24
exit status 1
VicençJ 5 years ago
Thank you very much for your help in advance, but when I compile the reciver it says:
C:\Users\HP\Downloads\receiver_13072018\receiver_13072018.ino: In function 'void loop()':
receiver_13072018:27: error: void value not ignored as it ought to be
Dzintars 7 years ago
Do you check working distance for you Wireless Relay Switch?
How far its work?
vandenbrande 7 years ago
Follow me for more!
