Arduino Nano 4x 18650 Smart Charger / Discharger
Intro: Arduino Nano 4x 18650 Smart Charger / Discharger
This is my Arduino Nano 4x 18650 Smart Charger / Discharger Open Source Project.
This unit is powered by 12V 5A. It can be powered by a computer power supply.
LinksBattery Portal: https://portal.vortexit.co.nz/
Parts List: http://www.vortexit.co.nz/parts-list-nano-4x/
Schematic: https://easyeda.com/brettwatty/arduino-nano-4x-ch...
PCB Gerber Files: https://www.pcbway.com/project/shareproject/Brett...
Source Code: https://github.com/brettwatty/arduino-nano-4x-cha...
Facebook Group: https://www.facebook.com/groups/DIYbatterycharger...
Forum: https://secondlifestorage.com/t-Brett-s-Arduino-8...
Checkout my database stats page of all currently processed batteries: http://www.vortexit.co.nz/batteries-recycled/
Donate: http://www.vortexit.co.nz/donate/
The HistoryI wanted to make a smart Arduino powered charger, discharger battery tester that could have a barcode scanner that scanned barcodes on batteries and input all the data into an Online Database Portal. This would allow me to correctly sort and analyze trends in all my reclaimed lithium batteries.
Version 1: I originally started out using a single sided PCB milled out with my CNC. This unit only had one cell and could charge ,discharge and test milli ohms.
Version 2.2: I moved onto using smaller PCB's that were etched then I had two cell modules on a Arduino UNO.
Version 3.2: I used the same smaller PCB's but I used an Arduino Mega and mounted it all on a Acrylic stand. I had originally planned to have 16 modules but ended up only using 8 cell modules as I would of needed to use analog signal multiplexers and the wiring was already very messy.
Arduino Mega 8x Charger / Discharger 1.1: I designed a PCB in easy EDA for an Arduino Mega 8x Charger / Discharger. This has a 20x4 LCD, Rotary Encoder, SD Card reader (never used), Ethernet, USB Host for a barcode scanning direct into the Arduino.
Arduino Mega 8x Charger / Discharger 1.2+: Later I made some small changes and added a ESP8266 Adaptor for WIFI communication.
Arduino Nano 4x 18650 Smart Charger / Discharger 1.0: I started designing a 4x version to make it much cheaper and easier to build. This version does not have a barcode scanner but it communicated with the Vortex IT Battery Portal to send and receive data via the internet.
Arduino Nano 4x 18650 Smart Charger / Discharger 1.1: This has some small amendments from Version 1.0 as it had some small bugs in the design and this version was released to the public.
STEP 1: Get the Components
PCB Gerber Files: https://www.pcbway.com/project/shareproject/Brett_s_Arduino_4x_ASCD_18650_Smart_Charger_Discharger_1_11.html
Main Components- Arduino Nano 3.0 ATmega328P x1 AliExpresseBay
- ESP8266 Arduino Adaptor x1 AliExpresseBay
- ESP8266 ESP-01 x1 AliExpresseBay
- LCD 1602 16x2 Serial x1 AliExpresseBay
- Battery Holder 4 x 18650 x1 AliExpresseBay
- TP5100 Module x4 AliExpresseBay
- CD74HC4067 Module x1 AliExpresseBay
- 74HC595N DIP16 x1 AliExpresseBay
- DIP16 Socket x1 AliExpresseBay
- Temp Sensor DS18B20 x5 AliExpresseBay
- Tactile Switch 6MM x1 AliExpresseBay
- Connector KF301-2P 5.08mm x4 AliExpresseBay
- DC Jack 5.5 x 2.1mm x1 AliExpresseBay
- Resistor Carbon Film 3.3ohm 5W x4 AliExpresseBay
- Conical Rubber Feet 14x8mm x8 AliExpresseBay
- Insulating Washers 3x7x0.8mm x16 AliExpresseBay
- M3 x 12mm Flat Head Stainless Steel 304 Hex Socket Screw x20 AliExpresseBay
- M3 304 Stainless Steel 304 Hex Nuts x4 AliExpresseBay
- M3 Standoff 18mm Brass F-F x4 AliExpresseBay
- M3 Standoff 35mm brass F-F x4 AliExpresseBay
- Header Female 2.54mm 1x4 x1 AliExpresseBay
- Headers Male 2.54mm 1x40 Pin x1 AliExpresseBay
- Header Female Right Angle 2.54mm 1x4 x1 AliExpresseBay
- USB to ESP8266 ESP-01 Programmer x1 AliExpresseBay
- 5V Active Buzzer x1 AliExpresseBay
- 12V 5A PSU x1 AliExpresseBay
- 10k - 1/4w Resistor THT x7 AliExpresseBay
- 4.7k - 1/4w Resistor THT x1 AliExpresseBay
- 1k - 1/4w Resistor THT x8 AliExpresseBay
- P-Channel MOSFET FQP27P06 TO-220 x4 AliExpresseBay
- N-Channel MOSFET IRLZ44N TO-220 x8 AliExpresseBay
- NPN Transistor BC547 TO-92 x4 AliExpresseBay
- Diode IN4007 x2 AliExpresseBay
- 10k - 1/8w Resistor SMD 0603 x7 AliExpresseBay
- 4.7k - 1/8w Resistor SMD 0603 x1 AliExpresseBay
- 1k - 1/8w Resistor SMD 0603 x8 AliExpresseBay
- N-Channel Mosfet IRLML2502TRPBF x8 AliExpresseBay
- P Channel MOSFET AO3407 SOT-23 x4 AliExpresseBay
- NPN Transistor SOT23 BC847 x4 AliExpresseBay
- Diode 1N4148 0603 x2 AliExpresseBay
- Solder Wire 60/40 0.7mm AliExpresseBay
- Diagonal Pliers AliExpresseBay
- Youyue 8586 SMD Soldering Rework Station AliExpresseBay
- UNI-T UT39A Digital Multimeter AliExpresseBay
- Wire Strippers AliExpresseBay
- Barcode Scanner AliExpresseBay
- Barcode Printer AliExpresseBay
- Barcode Labels 30mm x 20mm x700 AliExpresseBay
- MECHANIC Solder Paste AliExpresseBay
- Anti-Static Tweezers AliExpresseBay
- Third Hand Soldering Stand AliExpresseBay
- AMTECH NC-559-ASM No-Clean Solder Flux AliExpresseBay
- Solder Wick AliExpresseBay
- Precision Magnetic Screwdriver Set AliExpresseBay
For an updated list go to my website: http://www.vortexit.co.nz/parts-list-nano-4x/
STEP 2: Solder Resistors, Transistors and MOSFETs
Either SMD or THT solder (not both) the 1K, 4.7K, 10K, P-Channel, N-Channel and NPN components
STEP 3: Solder in the Headers and DIP Socket
Solder the Nano's two 15 pin female headers, 16x CD74HC4067 Multiplexers 8 pin and 16 pin female headers, ESP8266 adaptors 4 pin female, LCD 4 pin female and the 74HC595N Shift registers 16 pin DIP IC socket.
Note: solder all components on the silk screen side.
STEP 4: Solder Basic Components
Solder and install the 5.5mm DC Jack, Arduino Nano 328p, CD74HC4067 multiplexer and 74HC595N shift register.
When soldering the Arduino Nano and the Multiplexer I recommend first placing the male header pins in the female header pins then solder the component in place.
STEP 5: Solder the Dallas DS18B20 Temperature
First place two 3mm x 7mm x 0.8mm Insulating Washers on each Dallas Sensor (This is used to create a space off the PCB so you don't measure the PCB temperature)
Solder the 4x Dallas Sensors on the top layer for each cell module plus the ambient sensor on the bottom layer.
Be careful not to bridge the solder joints on the TO-92 solder pads. Once soldered measure in diode mode on your multi-meter between each leg on any Dallas Sensor (they are all connected in parallel)
Solder the 5V Active Buzzer on the top layer where the + (positive) pin is facing the Arduino Nano
STEP 6: Solder in the Diode
Solder in the Diode under the CD74HC4067 multiplexer
It is good practice to clean the flux with isopropyl alcohol.
STEP 7: Test and Adjust the LCD Screen Contrast / Serial Jumpers
Connect the LCD Serial 4 pin female to a 4 pin Male -> Female Dupont Jumper wires. Make sure you connect you connect exactly:
GND -> GND
VCC -> 5V
SDA -> SDA
SCL -> SCL
Load the Arduino Sketch from github: ASCD_Nano_Test_LCD_Screen
Unplug the USB cord and use a 12V power cord in the 5.5 mm DC Jack (+ positive center / - negative outer)
Adjust the potentiometer on serial adaptor at back of the LCD Screen CC or CW until you see the text displayed.
Once you are happy with the contrast remove the Dupont Jumper wires.
Serial JumpersConnect 2x 2.54 mm jumpers on pins 1-2 for software serial communication with the ESP8266
STEP 8: PWM Fan
Solder the following components:
JST 2.0 PH 2pin connector (Note: the silk screen is backwards on the PCB version 1.11)
100uF 16V Electrolytic Capacitor
BD139 NPN Transistor
Diode
TestLoad the Arduino Sketch from github: ASCD_Nano_Test_Fan
Plug in the 30mm Fan
The Fan should speed up then stop
STEP 9: Testing the MOSFETs
Load the Arduino Sketch from github: ASCD_Nano_Test_Charge_Discharge_Mosfets
With the PCB facing the bottom layer set your multi-meter to diode / continuity mode.
Place the negative probe on a GND source and the positive probe on the 1st modules load resistors connectors right side (as shown in the images).
Your multi-meter should beep for 1 second then no beep for 1 second.
Repeat this for each module.
Testing P-Channel TP5100 Charge MOSFETsLoad the Arduino Sketch from github: ASCD_Nano_Test_Charge_Discharge_Mosfets (Same as above you can use this sketch for both tests)
With the PCB facing the bottom layer set your multi-meter to DC voltage mode (usually 20V range).
Place the negative probe on a GND source and the positive probe on the 1st modules TP5100 right side + positive connector (as shown in the images).
Your multi-meter should show 12V for 1 second then a low voltage for 1 second. Repeat this for each module.
STEP 10: Get the Dallas DS18B20 Temperature Sensor Serials
Load the Arduino Sketch from github: ASCD_Nano_Get_DS18B20_Serials
Leave in the USB cable. Do not connect the Fan or 12V Power.
Open the Serial monitor in Arduino IDE at 115200 baud rate.
It should detect / locate 5x devices.
Heat up the 1st DS18B20 Temperature Sensor with the upper tip of your soldering iron for a short period of time.
Note: Module number are from left to right with the PCB facing upright on the top layer
It should print "Detected Battery: 1" then "Heat Up Battery Sensor: 2"
This will sequentially go through each 4 x modules until it says "Detected Ambient Sensor Completed"
It will display the Hexadecimal Serial numbers of all the DS18B20 Temperature Sensors at the bottom.
Copy the 5x Serial numbers and then paste them into "Temp_Sensor_Serials.h" within the "ASCD_Nano_1-0-0" sketch. Make sure you emit the last comma (shown in the image)
Note: If you get 99 degrees Celsius temperature reading it means that there is an error reading that sensor. Either the serial is wrong or the device is faulty.
STEP 11: Install and Test the TP5100 Charging Modules
With a knife or some diagonal pliers cut 20x single Male 2.54 mm headers.
Place 5x Male headers per TP5100 module on the bottom layer on the PCB. I recommend putting the long side down through the hole.
Place a TP5100 module on each module and solder it in place. Use some tweezers to manipulate the Male headers if they won't align.
On the top layer of the PCB solder the connectors as flush with the PCB as you can. (You will need to fit the plastic Battery holder on top so the less stick out the better)
Note: Make sure you connect the Charge Pin on the TP5100. It is the closest pin next to the VCC in GND above the P-Channel MOSFET
TestLoad the Arduino Sketch from github: ASCD_Nano_Test_Charge_Discharge_Mosfets (Same as above you can use this sketch for both tests)
All the TP5100 modules should turn on for 1 second the turn off for 1 second.
STEP 12: Drill DS18B20 Temperature Sensor Clearance Holes
- 0.7mm Drill bit or Scribe
- 3mm Drill bit (optional)
- 6.5mm - 7mm Drill bit
Get a spare blank PCB and a 4x 18650 Battery Holder
Mount the 4x 18650 Battery Holder with the + marking facing the top of the board
Mark the hole positions with a 0.7mm Drill bit or a Scribe via the center pin on each of the TO-92 DS18B20 Temperature Sensors
Remove the 4x 18650 Battery Holder and drill a 6.5mm - 7mm hole. I recommend using a smaller drill bit first.
Test fit the 4x 18650 Battery Holder and see if the DS18B20 Temperature Sensor have sufficient clearance.
Note: Do not solder the 4x 18650 Battery Holder until all other components have been soldered.
STEP 13: Mount the Discharge Resistors
First mount the headers. You can either use the 5.08mm Screw Terminal or JST 2.54mm Male Header.
Note: I use some blu tack to hold the header / terminal in place while soldering.
Solder them in.
Measure Ohms of Resistors (Optional)Measure, number and log the resistance of each resistor.
I use my LCR-T4 Tester for this. You could use a quality multi-meter (this is not 100% accurate but is a good base measurement)
Edit the Arduino Sketch from github: ASCD_Nano_1-0-0 add in the amended resistor values.
Mount the ResistorsIn this example I am using the 5.08mm Screw Terminals and I am staggering each wire wound resistor. Later I will add steps for aluminium clad resistors on a heat-sink.
STEP 14: Solder the Final Components
Solder in the 4x 18650 Battery Holder.
Note: You may need to trim some contacts down with some flush / diagonal pliers.
Solder the 6mm push button.
STEP 15: Mount All the Hardware
4x Use M2.5 stand-offs M-F or F-F
8x M2.5 Screws or 4x M2.5 screws and 4x M2.5 nuts depending if you use M-F or F-F stand-offs
Use a right angle 4pin 2.54mm connector to connect the Female to Male connectors.
Note: you may need to tin the connector to get a good connection if it is loose.
LCD4x M3 Standoff 18mm Brass F-F and 8x M3 x 12mm Screws for the LCD
Fan3D Printed case only: Thread some M3 x 18mm screws the Fan screw holes add the Fan.
STEP 16: Upload the Arduino Nano Sketch
Before uploading the sketch check the 5V Voltage output from the Arduino's Voltage Regulator. There are two probe points about the LCD screen.
Edit the Arduino Sketch from github: ASCD_Nano_1-0-0 Change this line in the Arduino Sketch to your voltage reading
const float referenceVoltage = 5.01; // 5V Output of Arduino
You can also change some other custom setting for your testing needs
const float shuntResistor[4] = {3.3, 3.3, 3.3, 3.3}; const float referenceVoltage = 5.01; // 5V Output of Arduino const float defaultBatteryCutOffVoltage = 2.8; // Voltage that the discharge stops const byte restTimeMinutes = 1; // The time in Minutes to rest the battery after charge. 0-59 are valid const int lowMilliamps = 1000; // This is the value of Milli Amps that is considered low and does not get recharged because it is considered faulty const int highMilliOhms = 500; // This is the value of Milli Ohms that is considered high and the battery is considered faulty const int offsetMilliOhms = 0; // Offset calibration for Milli Ohms const byte chargingTimeout = 8; // The timeout in Hours for charging const byte tempThreshold = 7; // Warning Threshold in degrees above initial Temperature const byte tempMaxThreshold = 20; // Maximum Threshold in degrees above initial Temperature - Considered Faulty const float batteryVolatgeLeak = 0.50; // On the initial screen "BATTERY CHECK" observe the highest voltage of each module and set this value slightly higher const byte moduleCount = 4; // Number of Modules const byte screenTime = 4; // Time in Seconds (Cycles) per Active Screen const int dischargeReadInterval = 5000; // Time intervals between Discharge readings. Adjust for mAh +/
Connect up the Arduino Nano to your computer and load the ASCD_Nano_1-0-0 sketch
You may need to use ATmega328P (Old boot loader) as the processor in Arduino IDE
Select the correct COM port and upload the sketch
STEP 17: Upload the ESP8266 Sketch
If you have not already registered your Vortex It - Battery Portal Account go to the next step.
You need to install the ESP8266 Arduino Addon in your Arduino IDE use this guide:
https://learn.sparkfun.com/tutorials/esp8266-thing...
Change the following in the ESP8266_Wifi_Client_1-0-0 Arduino Sketch
const char ssid[] = ""; -> to your WIFI routers
SSID const char password[] = ""; -> to your WIFI routers Password
const char userHash[] = ""; -> to your UserHash (Get this from "Charger / Discharger Menu -> View" in the Vortex It Battery Portal)
const byte CDUnitID = ; -> to your CDUnitID (Get this from "Charger / Discharger Menu -> View -> Select your Charger / Discharger" in the Vortex It Battery Portal)
Use USB to ESP8266 ESP-01 Programmer to upload sketch ESP8266_Wifi_Client_01.ino to the ESP8266 with the switch on PROG
STEP 18: Setup Your Vortex It - Battery Portal Account
Go to https://portal.vortexit.co.nz
If you have not already register for an account.
Login with your credentials
On the menu click "Charger / Discharger" -> "New"
Select from the drop down list "Arduino 4x C/D"
Click "New Charger / Discharger"
On the menu click "Charger / Discharger" -> "View"
Select from the drop down list "xx - Arduino 4x C/D" (where xx is the CDUnitID)
Make not of your "UserHash" and "CDUnitID"
Click "Live View Module" to view you Charger / Discharger online
STEP 19: Optional - Make a 3D Printed Enclosure
If you have a 3D printer you can print an enclosure that I have designed. Feel free to make your on style of enclosure and share it:
Fusion 360https://gallery.autodesk.com/fusion360/projects/asdc-nano-4x-arduino-charger--discharger-enclosure
STEP 20: Start Testing Cells
Insert some batteries into the Cell Modules and go to the "Live View Module" page scan in your barcodes and you are off.
Check out the Facebook group for updates, information, help and discussions.
https://www.facebook.com/groups/DIYbatterychargerdischargertesters/
3 Comments
elefant66 3 years ago
The actual one is not working any more
JesterSoft 1 year ago
rafpigna 2 years ago
