Introduction: Arduino Nano: Rotary Encoder With Visuino
The Rotary encoders are very useful precise rotation sensors, also often used as user controlled input devices instead of potentiometers. They are easy to connect to Arduino, and with the help of Visuino - an easy to use graphical development environment for Arduino, they are equally easy to program.
Step 1: Components
- One Arduino compatible board (I use Arduino Nano, because I have one, but any other will be just fine)
- One Rotary Encoder module I got from this cheap 37 sensors set.
- 4 Female-Female jumper wires
Step 2: Connect the Rotary Encoder to Arduino
- Connect Ground(Black wire), Power(Red wire), Direction(Brown wire), and Clock(White wire) to the Rotary Encoder Module (Picture 1)
- Connect the other end of the Power wire(Red wire) to the 5V power pin of the Arduino board(Picture 2)
- Connect the other end of the Ground wire(Black wire) to Ground pin of the Arduino board(Picture 2)
- Connect the Clock wire(White wire) to Digital pin 2 of the Arduino board(Picture 3)
- Connect the Direction wire(Brown wire) to Digital pin 3 of the Arduino board(Picture 3)
- Picture 4 shows where are the Ground, 5V Power, Digital 2 and Digital 3 pins of the Arduino Nano.
Step 3: Start Visuino, and Select the Arduino Board Type
To start programming the Arduino, you will need to have the Arduino IDE installed from here: http://www.arduino.cc/ .
Make sure that you install 1.6.7 or higher, otherwise this Instructable will not work!
The Visuino: https://www.visuino.com also needs to be installed.
Step 4: In Visuino: Add and Connect Rotary Encoder Component
- Type "rota" in the Filter box of the Component Toolbox then select the "Rotary Encoder Sensor" component (Picture 1), and drop it in the design area
- Connect the "Out" pin of the Digital[ 2 ] channel of the Arduino component to the "Clock(A)" pin of the RotaryEncoderSensor1 (Picture 2)
- Connect the "Out" pin of the Digital[ 3 ] channel of the Arduino component to the "Direction(B)" pin of the RotaryEncoderSensor1 (Picture 3)
Step 5: In Visuino: Add and Connect Up/Down Counter Component
- Type "coun" in the Filter box of the Component Toolbox then select the "Up/Down Counter" component (Picture 1), and drop it in the design area
- Connect the "Up" pin of the RotaryEncoderSensor1 component to the "Up" pin of the UpDownCounter1 component (Picture 2)
- Connect the "Down" pin of the RotaryEncoderSensor1 component to the "Down" pin of the UpDownCounter1 component (Picture 3)
- Connect the "Out" pin of the UpDownCounter1 component to the "In" input pin of the Serial[ 0 ] channel of the Arduino component(Picture 4)
Step 6: Generate, Compile, and Upload the Arduino Code
- In Visuino, Press F9 or click on the button shown on Picture 1 to generate the Arduino code, and open the Arduino IDE
- In the Arduino IDE, click on the Upload button, to compile and upload the code (Picture 2)
Step 7: And Play...
Picture 1 shows the completed and running project.
If you connect to the Arduino with Serial Terminal from the Arduino IDE or Visuino and then rotate the encoder back and forth, you will see in the terminal the value of the counter showing the encoder changes (Picture 2)
On Picture 3 you can see the complete Visuino diagram.
Congratulations! You have learned how to connect Rotary Encoder to Arduino, and how to read it.
Also attached is the Visuino project, that I created for this Instructable. You can download and open it in Visuino: https://www.visuino.com
Arduino All The Things! Contest
5 Comments
Question 4 years ago on Introduction
Hi I'm trying to make a rotary encoder button box for a flight sin with five encoders four toggle switches and for push buttons would this program show me the wiring and generate code for it if so I'm in would be a godsend.
5 years ago
Can i use the Pushbutton from the Rotary Encoder with the Visuino? I can´t find it in the Programm.
7 years ago
And here's a way of doing it without the need for Visuino, just the regular Arduino IDE. Hope it's helpful:
https://www.instructables.com/id/Improved-Arduino-Rotary-Encoder-Reading
Reply 6 years ago
You do realize that the guy that posted this is the developer of Visuino, right? And that the point of this Instructable was to demonstrate the use of his software?
Reply 6 years ago
No harm in him showing his project :-) . Actually without Visuino Rotary Encoder is not that trivial, so his project only highlights the advantage of Visuino ;-)
