Introduction: Arduino Radar
In this tutorial, we will learn how to make a cool looking Arduino Radar using ultrasonic sensor. Arduino radar allows you to detect objects within a short range. This project is easy and fun to make, obviously. You can use this project for showcasing in school science fair. I have added the video to help making this radar easily. Lets start making it…..
Overview
To make this radar we need three basic components. First one is the Arduino which processes the data sent by the sonar sensor. Sonar sensor has a transmitter which produces and transmits ultrasonic sound wave which later is received by the receiver after reflecting from any object. However, servo motor is the third component which revolves with in a particular degree and helps the radar to detect objects.
Components
The listed components are needed to make a arduino radar using ultrasonic sensor.
- Arduino Board (i have used arduino Uno)
- Servo motor (mg-996)
- HC-SR04 Ultrasonic sensor
- Bread board
- Jumper wires
Step 1:
First of all, we have to cut a card board (15cm * 8cm). Then, glue arduino and servo motor on it.
Step 2:
Now, we have to make a “L” shape stand for Ultrasonic sensor (HC-SR04) which keeps it still on the servo motor.
Step 3:
Now, we have to connect sonar sensor to arduino. Be careful while connecting VCC and GND of the sensor to 5v and GND of arduino respectively. Later, connect the trig pin to 8 and echo pin to 9 of arduino.
Step 4:
After connecting sensor to arduino it’s time to attach servo motor with it. Again, be cautious about connecting VCC and GND of servomotor. Connect servo signal to pin 10 of arduino.
Step 5: Required Software for Arduino Radar:
You will need arduino IDE and Processing IDE to run this radar
project. Processing IDE will get the values sent from arduino and illustrate the object area (red marked). Follow the links to download them.
Processing IDE: https://processing.org/download/support.html
Arduino IDE: https://www.arduino.cc/en/main/software
Step 6: Arduino Code:
#includeconst int TriggerPin = 8;
const int EchoPin = 9;
const int motorSignalPin = 10;
const int startingAngle = 90;
const int minimumAngle = 6;
const int maximumAngle = 175;
const int rotationSpeed = 1;
Servo motor;
void setup(void)
{ pinMode(TriggerPin, OUTPUT);
pinMode(EchoPin, INPUT);
motor.attach(motorSignalPin);
Serial.begin(9600);
void loop(void)
{ static int motorAngle = startingAngle;
static int motorRotateAmount = rotationSpeed;
motor.write(motorAngle);
delay(10);
SerialOutput(motorAngle, CalculateDistance());
motorAngle += motorRotateAmount;
if(motorAngle <= minimumAngle || motorAngle >= maximumAngle) { motorRotateAmount = -motorRotateAmount;
int CalculateDistance(void)
{ digitalWrite(TriggerPin, HIGH);
delayMicroseconds(10);
digitalWrite(TriggerPin, LOW);
long duration = pulseIn(EchoPin, HIGH);
float distance = duration * 0.017F;
return int(distance);
void SerialOutput(const int angle, const int distance)
String angleString = String(angle);
String distanceString = String(distance);
Serial.println(angleString + "," + distanceString);
Step 7: Processing IDE:
We can easily locate any object within the range (40 cm) by using processing IDE. If you don’t have the IDE on your pc just download it.
Before using this IDE, we have to configure the font.
For this, we have to install “OCRAEXT.TTF” file which is located in Radar.zip .
Then, go to tools/create Font. Select “OCRAExtended” from the list, choose font size 25 and click OK.
Step 8:
Now, we have to find the COM Port number. Go to Arduino IDE and find the Com port(COM3 in photo). Put the COM port number in line 13 of processing code (COM3 in photo).
Step 9: Final
Finally, pressing the Run button will show a processing window. It will show both servo angle of the radar and the object distance.
Follow our Blog to learn more interesting projects.... https://aboutsciences.com
You can download the Radar.zip file from here,
5 People Made This Project!
- monadello made it!
- bspanda made it!
- nickchuang29 made it!
- Max Hsiao made it!
See 1 More
15 Comments
3 years ago
It is not a RADAR. It is a sonar.
RADAR is an acronym for "Radio Detection and Ranging."
Reply 2 years ago
This is correct. This is not a radar. It is 100% fundamentally and physically a sonar device haha.
Reply 3 years ago
You can call it anything you want. But, most of the people considers the project as the DIY version of a radar. So i renamed it as a arduino radar.
Reply 3 years ago
You refer to the sensors as sonar in step 3. So then why call it radar?
Reply 3 years ago
Bull, I agree with okrad123. It is misleading/misservice to call it Radar.
Question 2 years ago
Could you plug the radar into a program with a 3d field at all? So you could see a 3d design of what it detects?
how can we increase the detection distance from 40 to 200. thanks
Answer 2 years ago
I haven't done the project yet but I'll say you need a stronger sensor with more range
2 years ago
Hello,
Nice to meet you ...
thank you very much for shared this project. I'll try program IDE and Processing.
Best Regard
3 years ago
Whassup, guys, I was wondering, how are you powering the whole thing (arduino + servo)? Is it the arduino from laptop USB port and the servo off the arduino 5V pin? Is the current sufficient?
I am thinking this way, it looks much more convenient than an external power source and also the USB-C Port should be able to supply the current needed, I just want to be sure I am not crippling my laptop in the process.
Question 3 years ago
I cannot find any thing already written in the processing ide.plzz tell me where to get it fast.plzzz
3 years ago
Is this something that you could use shocking someone or tasing them? My backyard neighbors are tasing me and I feel vibrations at my feet, but my husband cannot feel it. I have confronted him with this and doesn’t deny doing this but won’t stop and says they can’t be caught. Please help or direct me to anyone you think could help me. Thank you.
3 years ago
Ok I found the file correct in https://aboutsciences.com/blog/arduino-radar-using-ultrasonic-sensor-diy-cheapest-project/, please correct this .
Question 3 years ago on Step 9
Radar.zip not contain neither ttf font nor processing code. Where are they? Thanks for the project.
Answer 3 years ago
Please check the newly updated file "radar_updated.zip". Thank you....
