Arduino Room Status
Intro: Arduino Room Status
Today as the first day of the 21 year of my life! I wanted to show you how to connect Arduino to sensors, fetch data and show 'em on 16x2 LCD - as an example you can get your room's
temperature and light density and view them on lcd.
STEP 1: What You Need?
1. Smile :-)
2. Arduino Board (here I used UNO but feel free to choose your own)
3. LM35 Temperature Sensor
4. LDR
5. 2.2 K ohm Resistor (x1)
6. 10 K ohm Potentiometer
7. 16x2 Line LCD Display
7. Bread Board
--------------------------------- Softwares ----------------------------------------------
1. Arduino IDE
STEP 2: Wiring
The circuit:
LCD RS pin to digital pin 12
LCD Enable pin to digital pin 11
LCD D4 pin to digital pin 5
LCD D5 pin to digital pin 4
LCD D6 pin to digital pin 3
LCD D7 pin to digital pin 2
LCD R/W pin to ground
LCD VSS pin to ground
LCD VCC pin to 5V
10K Potentiometer: One of the ends to +5 Volts and the other to the Ground (GND), Connect LCD VO middle pin of the potentiometer.
LM35: Connect Arduino 5 Volt to Pin 1 (Based on the Picture), Connect Pin 2 to A1 (Analog In) Arduino Board, Connect Pin 3 to GND.
Connect LDR and 2.2k Resistor in series. Connect LDR pin to 5 Volt, Common Pin (between LDR and 2.2k Resistor) to Arduino A0 Pin and Connect 2.2k Resistor float pin to GND.
STEP 3: Arduino Code
Copy the code below to new arduino document. Select your Board and Port, then see the results.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
lcd.begin(16, 2);
void loop() {
double a = analogRead(A0);
a = (a / 1023)*100;
String str;
str=String(a);
lcd.setCursor(0, 0);
lcd.print(" "); //SIMPLE WAY TO CLEAR LCD
lcd.print("LUX: " + str + "%");
a = analogRead(A1);
str=String(a);
lcd.setCursor(0, 1);
lcd.print(" ");
lcd.print("TEMP: " + str);
delay(1000);
STEP 4: Ready, Set, Done
Now you're all set. Give it a go. Here you can use other analog sensors too. Make your own and publish it.
Wish you good luck.
