Introduction: Simple Distance Measuring Device
In this project we are going to learn how to use the HC-SR04 PING))) ultrasonic sensor to measure distance. This sensor is also often used on robots to detect obstacles.
Difficulty level: Easy
Time needed: ±10 minutes
Step 1: Things You'll Need
HC-SR04 PING sensor (x1)
Arduino UNO (x1)
LCD 16x2 (x1)
9V battery + dc adaptor (x1)
Potentiometer 10kΩ (x1)
Set of jumper wires
Step 2: Plug the PING Sensor and LCD
HC-SR04
GND (pin 1) to potentiometer (left pin)
VCC (pin 2) to potentiometer (right pin)
VO (pin 3) to potentiometer (center pin)
RS (pin 4) to arduino digital pin 12
RW (pin 5) to potentiometer (left pin)
E (pin 6) to arduino digital pin 11
D4 (pin 11) to arduino digital pin 5
D5 (pin 12) to arduino digital pin 4
D6 (pin 13) to arduino digital pin 3
D7 (pin 14) to arduino digital pin 2
Potentiometer
left pin to arduino GND
right pin ro arduino 5V
PING Sensor
VCC to arduino 5V
Trig to arduino digital pin 7
Echo to arduino digital pin 6
9V battery
To arduino DC power socket
Step 3: Upload the Code
Step 4: Have Fun! Show It to Your Friends :)
Yay! you have finished making your own measuring device. Now you can measure things without using a ruler! You can adjust the LCD brightness using the potentiometer. Feel free to give comments or ask questions and stay tune for my next project ; )
34 Comments
4 years ago on Step 3
thank you for sending the code
boss
Question 4 years ago
send the code to me the code is not correct
6 years ago
Can u please make a how to make video
6 years ago
How will this react if the surface is not parallel? Can i read it then?
6 years ago
please i will like to get your contact, I need to discuss with you
7 years ago
How can i get the LCD display to show the the distances more clearer? Mine seems to be pretty dark even with the 10k trim pot adjusted the best it can be.
7 years ago
LCD display connection?
which is ping sensor here?
thank?
7 years ago
I can connect phone in the place of LCD screen
7 years ago
7 years ago
7 years ago
Awsm bro
7 years ago
Awsm bro
8 years ago on Introduction
Good work ....am make it and its funny
Thanks, nice and easy!
8 years ago
simple but useful too!
thanks for sharing :-)
Thanks!
i have ir sharp sensor (range- 20cm-150cm).will it work instead of the ping sensor used here????
Reply 8 years ago
You can replace the ping sensor with your ir sensor, but you'll have to modify your code and the wiring. if you let me know your email I can help you :)
Reply 8 years ago
Solanki.akash786@gmail.com
Pls reply soon
