Arduino Traffic Display Using Google Maps API
Intro: Arduino Traffic Display Using Google Maps API
Hello Everyone!
In this instructable I'm going to show you how to make a Arduino device that gets traffic data from the Google Maps API and displays it to a screen and will also set the colour of a RGB LED.
The project runs on an Wemos D1 Mini (ESP8266) programmed via the Arduino IDE and costs roughly $10 in total to make.
The Arduino Traffic Display in this instructable will have the following features:
- Gets the estimated travel time between two locations from Google Maps
- Is configured dynamically using Telegram messenger
- Configurations are persistent across resets (Uses SPIFFS, internal flash memory on the ESP8266 board)
- Displays to an OLED screen and a RBG LED
The code should run on any ESP8266 board, but the small one with only a couple of GPIO pins will not have enough pins for the display and RGB led.
STEP 1: Hardware
First thing we need to do is put together the hardware for the project You'll need the following
- Wemos D1 Mini - any ESP8266 dev board should work
- 1.3" OLED Display (The 0.96" version will also work) - I really like these displays as they only need two data wires
- RGB LED - this is a 10 pack but you only need one
- Breadboard, 3x 1K resistors and wires - You probably already have these, if not a basic starter kit is probably a good option
You then need to assemble it as shown in the wiring diagram.
STEP 2: Google Maps API Key
In order to get the traffic data from the Google Maps API you need use an API key, these are free and very easy to get.
- Click on this link
- Scroll down to Quick start steps and click the Get a Key option
- Type in the name of your project and click the checkbox to agree to the terms and conditions
- You will then be given your key that you need to use later in the sketch
I recommend trying out your key using the following URL to make sure it's working correctly (Make sure to change the key at the end!)
https://maps.googleapis.com/maps/api/distancematrix/json?origins=Galway,+Ireland&destinations=Dublin,Ireland&departure_time=now&traffic_model=best_guess&key=PutYourNewlyGeneratedKeyHere
STEP 3: Telegram Bot Token and Chat ID
Telegram is an instant messenger very like whatsapp.One advantage it has over whatsapp is it allows you to create bots, which are programs that you can interact with in the chat application. We'll be using the Universal Arduino Telegram Library.
To use the library the first thing you need to get is a Bot Token, to get this inside telegram search for "botfather" and type the "/newbot" command. Then follow the onscreen instructions for naming the bot. Botfather will return you a bot token that you will use with the library.
Bots can only message you if you've first started a conversation with the bot first, so click on the link to your bot in the message that botfather sent and click the "Start" button
So the bot knows where to send the message you are going to need to add your chat id to the sketch, this is your unique identifier on Telegram. The easiest way to get this is search for a bot called "myIdBot", press the start button and send the "/getid" command.
You should now have everything you need to use Telegram to control the Arduino Traffic Display.
STEP 4: The Code
You now have everything you need to program you board with the example sketch which you can get off the project's Github page.
- Open the traffic-notifier sketch in the Arduino IDE.
- There is a list of libraries up the top of the sketch, they will all need to be installed if you do not have them already (All are available on the Arduino Library Manager)
- If you scroll down a small bit, you will see a section with the comment Replace the following, update everything in here
You should now be able to program your board with the sketch.
STEP 5: Controlling the Device Using Telegram
When the device powers on and connects to the WiFi it will send you a message via Telegram.
You can reply back to the device to send commands to configure it. Here is a list of the commands and what you can do with them
- /start
Lists out the available commands to the bot - /values
Lists the currently configured values that the bot has - /origin location
Sets the place you want your journey to start from. See comment below the list - /destination location
Sets the destination of your journey. See comment below the list - /limit value
Sets the limit of when the LED should turn red based on percentage difference. Value is a float (a negative percentage difference would mean the traffic is slower, so this would normally be a minus value (-10.0) or 0.0) - /save
Saves the configured value to a file (this file will be loaded at start up) and also will force a update from Google Maps
Note on locations, if you want more precise locations go to Google Maps and get the travel time between the two areas. You will see the origin and destination in the URL, you can use those values as they appear in the URL.
And that's it! Hopefully you enjoy this project, please let me know if you have questions or feedback.
Thanks alot
Brian
14 Comments
ku5h 4 years ago
हरिशमणीत 5 years ago
ibrahim109 5 years ago
CườngN66 5 years ago
Hello friends
How can I get the route data, routing path to the arduino
For example, you want to go from A to D:
Arduino will tell you the itinerary is:
From A to B: turn right and go 100 m
from B to C: turn right and go 20 m
May you help.
witnessmenow 5 years ago
The response from Google maps API gives step by step instructions like that, but I never included it in the Arduino API library because it's really too much data to be able to handle on the Arduino (during testing I saw a 20,000 characters of text in this field), you would also have the problem of not knowing when you reach B in your example, so you wouldn't know when to change to the B to C instruction
Greg_Griessel 6 years ago
Some questions regarding the Logic and Displays
Display gives % slower .. slower than what ? is the baseline normal traffic conditons ?
i dont understand the /limit command .. seems from the code that if the % slower is less than the limit then it will light the Red Led ?? doesnt make sense ...
witnessmenow 6 years ago
The maps API returns two travel times, one "duration" and "duration_in_traffic" (or something like this).
Duration seems to be some sort of average travel time (I actually can't find a proper description of what this is), as during low traffic, such as at night, duration_In_Traffic can be lower than the travel time.
I take the duration and traffic away from duration and that is my difference. I use this difference and compare it to the duration to get the percentage difference.
If duration in traffic is bigger than duration, that percentage difference will be negative. So as a bigger difference means a more negatvie (smaller number) i check is it less than the limit.
Maybe this is the wrong way to do it, feel free to change it around to however you like!
Thx Brian I think i understand it better now , let me play around with the options a bit
TuananhT2 6 years ago
i want to use thought bluetooth. How?
tmercados 6 years ago
How could I put the letter of the traffic time, bigger?
Thanks
The screen library being used is this one,
https://github.com/squix78/esp8266-oled-ssd1306
There are some instructions on how to use it on the Github page
DeepaK18 6 years ago
Hi,
What if I have to calculate intensity of vehicle in just 100 m, how do I do that ?
Hi Deepak,
You dont get to see the travel time of individual parts of the route, but what you could do is make a request for that 100m of road as you origin and destination.
Go to google maps and get the request you want to make, and then you can take the origin and destination from the URL
