Arduino Tutorial - Numeric Keypads
Intro: Arduino Tutorial - Numeric Keypads
This is an example of one of my Arduino tutorials.
Numeric keypads can provide a simple end-user alternative for various interfaces for your projects. Or if you need a lot of buttons, they can save you a lot of time with regards to construction. We’ll run through connecting them, using the Arduino library and then finish with a useful example sketch.
Getting Started
Numeric keypads are available from many retailers, and no matter where you get them from, make sure you can get the data sheet, as this will make life easier when wiring them up. Shown above are two examples for our tutorial, from Futurlec (slow and cheap).
Again, the data sheet is important as it will tell you which pins or connectors on the keypad are for the rows and columns, for example the black keypad shown above. If you don’t have the data sheet – you will need to manually determine which contacts are for the rows and columns.
This can be done using the continuity function of a multimeter (the buzzer). Start by placing one probe on pin 1, the other probe on pin 2, and press the keys one by one. Make a note of when a button completes the circuit, then move onto the next pin. Soon you will know which is which. For example, on the example keypad pins 1 and 5 are for button “1″, 2 and 5 for “4″, etc… Furthermore some keypads will have the pins soldered to the end, some will not. With our two example keypads, the smaller unit had the pins – and we soldered pins to the large white unit.
At this point please download and install the keypad Arduino library. Now we’ll demonstrate how to use both keypads in simple examples.
Using a 12 digit keypad
We’ll use the small black keypad from Futurlec, an Arduino Uno-compatible and an LCD with an I2C interface for display purposes. If you don’t have an LCD you could always send the text to the serial monitor instead.
Wire up your LCD then connect the keypad to the Arduino in the following manner:
// keypad type definition
As you need to change the numbers in the arrays rowPins[ROWS] and colPins[COLS]. You enter the digital pin numbers connected to the rows and columns of the keypad respectively. Furthermore, the array keys stores the values displayed in the LCD when a particular button is pressed. You can see we’ve matched it with the physical keypad used, however you can change it to whatever you need. But for now, enter and upload the following sketch once you’re satisfied with the row/pin number allocations...
And the results of the sketch are shown in this video:
So now you can see how the button presses can be translated into data for use in a sketch. We’ll now repeat this demonstration with the larger keypad.
Using a 16 digit keypad
We’ll use the larger white 4×4 keypad from Futurlec, an Arduino Uno-compatible and for a change the I2C LCD from Akafugu for display purposes. (We reviewed these previously). Again, if you don’t have an LCD you could always send the text to the serial monitor instead. Wire up the LCD and then connect the keypad to the Arduino in the following manner:
And now for an example project, one which is probably the most requested use of the numeric keypad…
Example Project – PIN access system
The most-requested use for a numeric keypad seems to be a “PIN” style application, where the Arduino is instructed to do something based on a correct number being entered into the keypad. The following sketch uses the hardware described for the previous sketch and implements a six-digit PIN entry system. The actions to take place can be inserted in the functions correctPIN() and incorrectPIN(). And the PIN is set in the array char PIN[6]. With a little extra work you could create your own PIN-change function as well.
The project is demonstrated in this video:
Conclusion
So now you have the ability to use twelve and sixteen-button keypads with your Arduino systems. I’m sure you will come up with something useful and interesting using the keypads in the near future.
If you enjoyed this tutorial, check out the rest and much more at tronixstuff.com.
Getting Started
- Keypad row 1 to Arduino digital 5
- Keypad row 2 to Arduino digital 4
- Keypad row 3 to Arduino digital 3
- Keypad row 4 to Arduino digital 2
- Keypad column 1 to Arduino digital 8
- Keypad column 2 to Arduino digital 7
- Keypad column 3 to Arduino digital 6
- Keypad row 1 (pin eight) to Arduino digital 5
- Keypad row 2 (pin 1) to Arduino digital 4
- Keypad row 3 (pin 2) to Arduino digital 3
- Keypad row 4 (pin 4) to Arduino digital 2
- Keypad column 1 (pin 3) to Arduino digital 9
- Keypad column 2 (pin 5) to Arduino digital 8
- Keypad column 3 (pin 6) to Arduino digital 7
- Keypad column 4 (pin 7) to Arduino digital 6
- the extra column in the array char keys[]
- the extra pin in the array colPins[]
- and the byte COLS = 4.
Conclusion
6 Comments
hoosseina 5 years ago
empatis 5 years ago
skjha2k 7 years ago
Hi glharrisjr , could you sol ve your problem?
I am facing the similar problem.
skjha2k 7 years ago
solved. use "const char" instead of char for the following line
char PIN[6]={ '1','2','A','D','5','6'}; // our secret (!) number
now the update code will be
const char PIN[6]={ '1','2','A','D','5','6'}; // our secret (!) number
glharrisjr 8 years ago
Hi, I copied your code and ran it... when I type in the code 12ad56 it tells me that I am wrong... now, I have already verified my col / row and my hard ware. I put in a few print statements and found that the program puts a # into the first pin number slot. it starts out thinking that the code is 12ad56 but will switch the value of the pin[0] to #. I am stumped can you help me out.... the modified code follows
oh glharrisjr@aol.com is my email
// PIN switch with 16-digit numeric keypad
// http://tronixstuff.com/tutorials > chapter 42
#include "Keypad.h"
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h>
#define I2C_ADDR 0x27 // <<- Add your address here.
#define Rs_pin 0
#define Rw_pin 1
#define En_pin 2
#define BACKLIGHT_PIN 3
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] =
{ {'1', '4', '7', '#'},
{'2', '5', '8', '0'},
{'3', '6', '9', '*'},
{'A', 'B', 'C', 'D'}
byte rowPins[ROWS] = {
5, 4, 3, 2
}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {
9, 8, 7, 6
}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char PIN[6]={
char attempt[6]={
'0','0','0','0','0','0'}; // used for comparison
int z=0;
void setup()
Serial.begin(9600);
lcd.begin(16, 2);
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
lcd.setBacklight(HIGH);
lcd.print("PIN Lock ");
delay(1000);
lcd.clear();
lcd.print(" Enter PIN...");
void correctPIN() // do this if correct PIN entered
lcd.print("* Correct PIN *");
delay(1000);
lcd.clear();
void incorrectPIN() // do this if incorrect PIN entered
lcd.print(" * Try again *");
delay(1000);
lcd.clear();
void checkPIN()
lcd.print(PIN[0]);
lcd.print(PIN[1]);
lcd.print(PIN[2]);
lcd.print(PIN[3]);
lcd.print(PIN[4]);
lcd.print(PIN[5]);
delay(1000);
int correct=0;
int i;
for ( i = 0; i < 6 ; i++ )
if (attempt[i]==PIN[i])
correct++;
if (correct==6)
correctPIN();
else
incorrectPIN();
for (int zz=0; zz<6; zz++)
attempt[zz]='0';
void readKeypad()
char key = keypad.getKey();
if (key != NO_KEY)
attempt[z]=key;
z++;
switch(key)
case '*':
z=0;
break;
case '#':
z=0;
delay(100); // for extra debounce
lcd.clear();
checkPIN();
break;
void loop()
readKeypad();
KarelL1 9 years ago
on wich pins connect the lcd?
