Arduino Web Server
Intro: Arduino Web Server
This instructable will show you how to make an Arduino web server that you can turn an led on and off and rotate a servo motor with an internet connection.
You will need:
1x Arduino Uno:
-US Link: http://amzn.to/2nf4tyO
-UK Link:
1x Ethernet Shield:
-US Link: http://amzn.to/2nfghB7
-UK Link:
1x Ethernet Cable:
-US Link: http://amzn.to/2nfgsMN
-UK Link
1x 220 Ohm Resistor and LEDs:
-US Link: http://amzn.to/2mjCzm9
1x 220 Ohm Resistor:
-UK Link:
1x LED:
-UK Link:
1x Micro Servo Motor:
-UK Link
1x Breadboard:
-US Link: http://amzn.to/2lEEhBw
-UK Link
Jumper Cables:
-US Link: http://amzn.to/2nfeNXJ
-UK Link
STEP 1: The Schematic
Make this up on your breadboard!
STEP 2: Now Upload the Code
Make sure to change the IP address so it works with your router then upload it to your Arduino.
STEP 3: Connect Up:
You now need to connect up the Ethernet cable to your router and plug in your Arduino to start the program.
STEP 4: The Challenge:
See if you can make it move when connected to other Wi-Fi networks other than your own. You will need to go into router settings to do this so make sure you know what you are doing because if you change the wrong setting(s) you might be locked out and unable to change it back.
9 Comments
diytransistor 7 years ago
I see that your code and schematic come from Rui Santos, but nowhere do you give him credit. I think you owe it to him to put his name in the intro.
Conor M 7 years ago
I haven't seen his schematic (or heard his name) and I made it myself using a program called fritzing.
robdevenney 6 years ago
Conor the commentor was referring to the sketch / script including the css code which I agree clearly belongs to Rui Santos... and you should credit him. The css is hosted at the domain randomnerdtutorials.com which is owned by Rui Santos so unless you have two names that isn't you. It's good you made a Instructable showing people how to do this but credit where credit is due given that you found plenty of time to add affiliate links and to add your name in the footer of the html code
diytransistor 6 years ago
Nitr0 8 years ago
Can you use this webserver to host a Bitcoin Mining pool? Or does it need more processing power?
Conor M 8 years ago
Nitr0 8 years ago
Conor M 8 years ago
RicardoE14 8 years ago
