Introduction: Arduino With Pir Sensor
Subscribe our channel friends
Supplies:
Arduino
Step 1: Arduino With PIR Interfacing a PIR Sensor With Arduino.
https://youtu.be/adg96CgvU7w
Hi friends! I am back ones again to share with you my simple but useful project and step by step descriptive video to show you, how you can auto turn on the room Light when some come inside the room. It’s only work when someone moving in the room and after few second light will turn off automatically. To detect the motion I have used PIR Motion Sensor and program the arduino board to read the sensor signal and turn on the light for few second.
List of components to make this prototype:
Arduino Uno
PIR motion sensor
LED
Jumper wire
PIR motion sensor with Arduino video tutorial
Step 2: Code
Arduino code for PIR Motion Sensor prototype
intcalibrationTime = 30;
//the time when the sensor outputs a low impulse
longunsigned intlowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
longunsigned intpause = 5000;
boolean lockLow = true;
boolean takeLowTime;
intpirPin = 12; //the digital pin connected to the PIR sensor's output
intledPin = 13;
//SETUP
voidsetup(){
Serial.begin(9600);
pinMode(pirPin, INPUT);
pinMode(ledPin, OUTPUT);
digitalWrite(pirPin, LOW);
//give the sensor some time to calibrate
Serial.print("calibrating sensor ");
for(inti = 0; i < calibrationTime; i++){
Serial.print(".");
delay(1000);
Serial.println(" done");
Serial.println("SENSOR ACTIVE");
delay(50);
//LOOP
voidloop(){
if(digitalRead(pirPin) == HIGH){
digitalWrite(ledPin, HIGH); //the led visualizes the sensors output pin state
if(lockLow){
lockLow = false;
Serial.println("---");
Serial.print("motion detected at ");
Serial.print(millis()/1000);
Serial.println(" sec");
delay(50);
takeLowTime = true;
if(digitalRead(pirPin) == LOW){
digitalWrite(ledPin, LOW); //the led visualizes the sensors output pin state
if(takeLowTime){
lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false;
//if the sensor is low for more than the given pause,
//we assume that no more motion is going to happen
if(!lockLow && millis() - lowIn > pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print("motion ended at "); //output
Serial.print((millis() - pause)/1000);
delay(50);
2 Discussions
1 year ago on Step 2
Nice and detailed instructable.
Reply 1 year ago
Thanks
