Arduino and Processing Interact.
Intro: Arduino and Processing Interact.
Arduino, processing and ultrasonic sensors to make a pages turner. It makes us can turn pages by waving hand.Ultrasonic page tunner is used to turn page on the computer.It is consist of 3 ultrasonic sensors and an Arduino UNO. It can help you turn page by wave your hand in front of the ultrasonic sensor.
STEP 1: Materials
what you need:
Arduino Uno R3 x1;
ultrasonic sensor HC-SR04 x3;
ProtoBoard 7cm * 10cm - 2.54mm x1;
330 ohm ressitor x3;
LED x3;
Some dupont lines;
STEP 2: Schematic
Connect the circiut on bread board and test the fountions.
STEP 3: Put the Pictures in Suitable Situation.
You must put some images (JPEG, GIF, or PNG) into the sketch’s data before you test the circuit.
STEP 4: Loading the Arduino Program and Processing to Test the Fountions
Here is the Arduino code:
copy and paste these code to Arduino IDE and load it to UNO
int slide = 0;
boolean left=false; boolean center=false; boolean right=false; int trignPin1=4; int trignPin2=7; int trignPin3=10; int echoPin1=3; int echoPin2=6; int echoPin3=9; int ledPin1=5; int ledPin2=8; int ledPin3=11; int maxD = 20; long int lastTouch = -1; // ms int resetAfter = 2000; // ms int afterSlideDelay = 50; //ms; all slides ignored after successful slide int afterSlideOppositeDelay = 500; // left slides ignored after successful right slide int SLIDELEFT_BEGIN = -1; // Motion was detected from right int SLIDELEFT_TO_CENTER = -2; // Motion was detected from right to center int SLIDENONE = 0; // No motion detected int SLIDERIGHT_BEGIN = 1; // Motion was detected from left int SLIDERIGHT_TO_CENTER = 2; // Motion was detected from left to center
void setup() { Serial.begin(9600); // bit/s pinMode(ledPin1, OUTPUT); pinMode(ledPin2, OUTPUT); pinMode(ledPin3,OUTPUT); }
void loop() { left = echo(trignPin1,echoPin1, ledPin1); center = echo(trignPin2,echoPin2, ledPin2); right = echo(trignPin3,echoPin3,ledPin3); if (left || center || right) { lastTouch=millis(); } if ((millis() - lastTouch)> resetAfter) { slide=0; digitalWrite(ledPin1, LOW); digitalWrite(ledPin2, LOW); digitalWrite(ledPin3, LOW); // Serial.println("Reset slide and timer. "); } if (slide >= SLIDENONE) { // only if we are not already in opposite move if ((left) && (!right)) slide = SLIDERIGHT_BEGIN; if (center && (slide == SLIDERIGHT_BEGIN)) slide = SLIDERIGHT_TO_CENTER; if (right && (slide == SLIDERIGHT_TO_CENTER)) slideNow('R');
} if (slide <= SLIDENONE) { if (right && (!left)) slide = SLIDELEFT_BEGIN; if (center && slide == SLIDELEFT_BEGIN) slide = SLIDELEFT_TO_CENTER; if (left && slide == SLIDELEFT_TO_CENTER) { slideNow('L'); } } delay(50); } boolean echo(int trignPin, int echoPin, int ledPin) { int d = getDistance(trignPin, echoPin); // cm boolean pinActivated = false; Serial.print(d); if (d < maxD) { digitalWrite(ledPin, HIGH); pinActivated = true; } else { digitalWrite(ledPin, LOW); pinActivated = false; } return pinActivated; } int getDistance(int trignPin,int echoPin) { long duration, inches, cm; pinMode(trignPin, OUTPUT); digitalWrite(trignPin, LOW); delayMicroseconds(2); digitalWrite(trignPin, HIGH); delayMicroseconds(5); digitalWrite(trignPin, LOW); pinMode(echoPin, INPUT); duration = pulseIn(echoPin, HIGH); inches = microsecondsToInches(duration); cm = microsecondsToCentimeters(duration); return(cm); // You could also return inches } void slideNow(char direction) { if ('R' == direction) Serial.println("F"); digitalWrite(ledPin1,HIGH); if ('L' == direction) Serial.println("B"); digitalWrite(ledPin3, HIGH); delay(afterSlideDelay); slide = SLIDENONE; } long microsecondsToInches(long microseconds) { return microseconds / 74 / 2; } long microsecondsToCentimeters(long microseconds) { return microseconds / 29 / 2; }
Here is the processing code:
copy and paste these code to Processing IDE run when UNO connecting with computer.
import processing.serial.*;
int slideStep = 75; // how many pixels to slide in/out // The current image and the next image to display PImage currentImage, nextImage;
// The index of the current image. int imgIndex = 0;
// Keeps track of the horizontal slide position. A negative number // indicates sliding in from the left. int slideOffset; // All the image files found in this sketch’s data/ directory. String[] fileList; // A serial port that we use to talk to Arduino. Serial myPort; // This class is used to filter the list of files in the data directory // so that the list includes only images. class FilterImages implements java.io.FilenameFilter { public boolean accept(File dir, String fname) { String[] extensions = {".png", ".jpeg", ".gif", ".tga", ".jpg"}; // Don’t accept a file unless it has one of the specified extensions for (int i = 0; i < extensions.length; i++) { if (fname.toLowerCase().endsWith( extensions[i])) { return true; } } return false; } } // This loads the filenames into the fileList void loadFileNames() { java.io.File dir = new java.io.File(dataPath("")); fileList = dir.list(new FilterImages()); } // The Processing setup method that’s run once void setup() { size(displayWidth, displayHeight); // Go fullscreen loadFileNames(); // Load the filenames /* This centers images on the screen. To work correctly with this mode, we'll be using image coordinates from the center of the screen (1/2 of the screen height and width) . */ imageMode(CENTER); // Load the current image and resize it. println(fileList[0]); currentImage = loadImage(dataPath("") + "\\" + fileList[0]); currentImage.resize(0, height); println(Serial.list()); myPort = new Serial(this, Serial.list()[0], 9600); } // Go to the next image void advanceSlide() { imgIndex++; // go to the next image if (imgIndex >= fileList.length) { // make sure we're within bounds imgIndex = 0; } slideOffset = width; // Start sliding in from the right } void reverseSlide() { imgIndex--; // go to the previous image if (imgIndex < 0) { // make sure we're within bounds imgIndex = fileList.length - 1; } slideOffset = width * - 1; // Start sliding in from the left } void draw() { // Put up a black background and display the current image. background(0); image(currentImage, width/2, height/2);
// Is the image supposed to be sliding? if (slideOffset != 0) {
// Load the next image at the specified offset. image(nextImage, slideOffset + width/2, height/2); if (slideOffset > 0) { // Slide from the right (next) slideOffset -= slideStep; if (slideOffset < 0) { slideOffset = 0; } } if (slideOffset < 0) { // Slide from the left (previous) slideOffset += slideStep; if (slideOffset > 0) { slideOffset = 0; } } if (slideOffset == 0) {
currentImage = nextImage; } } else { // If we're not sliding, read the serial port. if (myPort.available() > 0) { char inByte = myPort.readChar(); print(inByte); // Displays the character that was read if (inByte == 'F') { // Forward advanceSlide();
} if (inByte == 'B') { // Backward reverseSlide(); } // Load and resize the next image nextImage = loadImage(dataPath("") + "\\" + fileList[imgIndex]); nextImage.resize(0, height); } } }
STEP 5: Design and Assemble the Shape
My design is not looking so good. I will design a better shape next time.
Made by Xie weifang from i-element.org
