Arduino Browser Based Remote Control (linux)
Intro: Arduino Browser Based Remote Control (linux)
After this happening on a daily basis for several years, and after my darling wife allowing me to have an Arduino for Christmas I decided that it was time to make something useful (in her eyes!) with the Arduino.
So here we have the culmination of that: a web-based interface to the Arduino that replaces my remotes and is accessible from my internal network.
When I figure out why my ethernet shield won't allow my arduino to keep a sketch I will write a new sketch that uses the ethernet shield as the web server, meaning I don't need apache installed on my computer. Stay tuned, I will get there!
STEP 1: Prerequisites
Arduino side:
Arduino - I am using an Arduino Uno R2
Breadboard - your local electronics shop, or the kitchen if you want an authentic breadboard
Mounting enclosure - I used an old plastic case with a transparent lid
Components:
Infrared LED - I desoldered one from a broken remote control (thanks kids!)
Infrared Receiver - I got mine from a magic eye remote extender
Transistor - I used a BC547
Resistor - I used a 1.5k ohm variable resistor set to 1k ohm
Breadboard jumper wires - I got mine from a solid core RJ45 cable reel
Computer side:
Computer to use as server
USB lead to Arduino
Software:
Arduino software - from arduino.cc
irremote library - from http://www.arcfn.com/2009/08/multi-protocol-infrared-remote-library.html (thanks Ken, great work!)
Apache web server with PHP installed - apache.org
Internal IP address - mine is 192.168.0.9
Picture of your remote control - google or a picture taken on your camera. I saved mine at 200x600 resolution
STEP 2: Building the Board
Arduino pins used for this project:
5v, ground
Digital pins 3, 11 (pin 3 controls the IR LED, pin 11 connects to the IR receiver)
STEP 3: Schematic
IR LED connections:
Connect one of the legs of the resistor to Arduino digital pin 3
Connect the other leg of the resistor to the base pin of the transistor (the middle leg in my case)
Connect the emitter of the transistor to ground
Connect the collector of the transistor to the negative leg of the LED (short leg, flat side of the LED)
Connect the positive leg (long leg, curved side) of the LED to the 5v pin
IR receiver connections (you would need to find the pinout for your particular IR receiver):
GND pin to ground
VS pin to 5v
VO pin to Arduino digital pin 11
STEP 4: Add Irremote Library to the Arduino Software
Download the library from http://arcfn.com/files/IRremote.zip and install it as you would any other library for the arduino.
His blog has a lot of helpful information about the library and how to install it.
STEP 5: Record the Codes From Your Remote Controls
Pressing every button on the remote control, saving the output string and mapping it to the virtual remote control.
You only need to do it once, expect to take approximately 20 minutes or so.
Start a text editor to save your output.
Create a new document and type out every button on your remote control, one per line:
Power
Up
Down
Left
Right
.. et cetera
Start the Arduino IDE and click on "Files->Examples->IRremote->IRrecvDump" and upload it to your Arduino.
This example will dump the remote codes to the serial port.
Start the Serial port monitor and press a key on your remote control. You will see a string appear in the serial monitor window:
"Decoded *: * (* bits)". Copy this line and save it into your document on the appropriate line.
Repeat until you have all your keys stored in the text file. I know how much fun this bit is, I have done it twice so far :P
We now need to do a little searching and replacing in the text file:
search for
"Decoded "
replace with
search for
": 0x"
replace with
search for
replace with
search for
" bits)"
replace with
So for a line such as:
Decoded NEC: 0x000110 (15 bits)
we should now have a line that says:
NEC,000110,15
STEP 6: Create the Web Page for Your Remote Control
We now need to map the buttons on your image of your remote control.
I used http://www.maschek.hu/imagemap/imgmap to map the buttons and modified the code that website gives you to make it work.
Click on "Use an image on your computer: [choose file]", select your image, click [upload], click [accept]
Drop rectangles, circles etc onto each button. For HREF put
/remote.php?command= and the line for that button from the text document
for example /remote.php?command=NEC,000110,15
It would be wise (and aid immensely in debugging) if you also fill in Alt: with the button name but that is up to you.
Repeat for each button.
All done? Then we will continue.
At the bottom of that page is "Code", click on that and a box will open showing the code for the imagemap. Copy that and paste it into a new text document. This is the main part of our web page.
Here is my complete web page, just replace the ...
with your own code above and save it as remote.php in your web directory (/var/www on linux) along with your remote control images.
Change the lines for your own images:
"http://www.w3.org/TR/html4/loose.dtd">
Arduino LED control
STEP 7: Upload the Remote Control Code to Your Arduino
Create a new sketch and paste the following code into it:
* WebRemote
* An IR LED must be connected to Arduino PWM pin 3.
* Version 0.1 July, 2009
* This code copyright Gregory Fenton, http://labby.co.uk/2012/02/irremote-arduino-experimentation/
* IRremote Library copyright 2009 Ken Shirriff, http://arcfn.com
#include
template inline Print &operator <<(Print &obj, T arg) { obj.print(arg); return obj; }
boolean ended = false;
char inData[64]; // Size as appropriate
byte index = 0;
#define EOP "\n"
IRsend irsend;
void setup()
Serial.begin(9600);
Serial << "Serial port initialised" << EOP;
void loop()
String pch, sType, sTemp;
char inChar,sTest, k;
int sBits;
long sHex;
int i, j;
while(1)
while(Serial.available() > 0)
inChar = Serial.read();
if(index == 0)
pch = "";
if(inChar == '\r' || inChar == '\n' || inChar == '/') // EOP
ended = true;
index = 0;
break;
else
if(index < 64) // Array size
pch += inChar;
index++;
if(ended)
// Parse the data in inData here...
pch.toUpperCase();
i = pch.indexOf(' ') != -1 ? pch.indexOf(' ') : pch.indexOf(',');
sType = pch.substring(0,i);
i++; // skip over ',' or ' '
// i now points to start of hex
j = pch.lastIndexOf(' ') != -1 ? pch.lastIndexOf(' ') : pch.lastIndexOf(','); // j now points to ',' or ' ' after hex
sHex = 0;
sTemp = pch.substring(i, j);
if(sTemp.substring(0,2) == String("0X"))
sTemp = sTemp.substring(2);
for(i = 0; i < sTemp.length(); i++)
k = sTemp[i];
if(!((k >= '0' && k <= '9')||(k >= 'A' && k <= 'F')))
break;
sHex *= 16;
if(k >= '0' && k <= '9')
sHex += (k - '0');
else if (k >= 'A' && k <= 'F')
sHex += ((k - 'A') + 10);
break;
sTemp = pch.substring(j+1);
sBits = 0;
k = sTemp[i];
sBits *= 10;
sBits += (k - '0');
if(sType.length()>0)
Serial << pch << EOP << "Code type: "<< sType << " Hex: ";
Serial.print(sHex,HEX);
Serial << " Bits: " << sBits;
sendIt(sType, sHex, sBits);
pch = "";
ended = 0;
void sendIt(String sType, long sHex, int sBits)
for(int i = 0; i < 2; i++)
if(sType.equals(String("RC6")))
irsend.sendRC6(sHex, sBits);
else if (sType.equals(String("RC5")))
irsend.sendRC5(sHex, sBits);
else if(sType.equals(String("SONY")))
irsend.sendSony(sHex, sBits);
else if(sType.equals(String("NEC")))
if (!i) irsend.sendNEC(sHex, sBits);
else if(sType.equals(String("")))
Serial << "Delaying" << EOP;
delay(450);
delay(30);
STEP 8: Connect to the Web Server From Your Computer
go to http://webserver IP address/remote.php in your browser
For me the address is http://192.168.0.9/remote.php but yours will doubtless be different.
If all is working you should see a picture of your remote control with buttons you can click on.
STEP 9: Optional Step: Edit Your Hosts File to Make It Easier to Use
Note that this file can only be edited in an administrative command prompt (windows) or by su (linux)
Add the line
ip.add.re.ss remote
replace ip.add.re.ss with the server IP address and save the file.
You would need to do this on every device you wished to access the web page with the short name.
Now you can access the remote with http://remote/remote.php
This is my first proper instructable, be gentle and let me know if there are any problems so I can fix them.
13 Comments
jasonmarkham 7 years ago
remote.php link is dead
arielslyz 8 years ago
hello..Can I use remote control for only activated on/off button on desktop PC?
gregoryfenton 8 years ago
I am sorry, I do not understand your question. Could you elaborate on it please?
Only the power button
This remote can control the booting desktop function?
brianfit 9 years ago
"When I figure out why my ethernet shield won't allow my arduino to keep a sketch I will write a new sketch that uses the ethernet shield as the web server, meaning I don't need apache installed on my computer. Stay tuned, I will get there!" I suspect you're going to run into memory issues. There's precious little to spare for HTML processing, and at a guess I'd say on-board processing of what you've got here is going to be too taxing even for the Little Arduino that Could.
You really helped me get to the point where my board can record and send, my problem now is I don't want to tether the Arduino via USB to get serial input -- I'd need to rearrange my house to get the computer in IR range. I'm looking into whether I can use Marco Shwartz's REST library to get data into the Arduino over WiFi, so I can place it independent of the computer. If I manage, I'll come back and post a link. While that won't eliminated the need for Apache on the computer (the html for your virtual remote still needs to run somewhere) it at least untethers the Board from the USB cable.
Thanks for a super clear instructable!!! The one thing I'd suggest adding which I found myself looking up 8 times was how to determine polarity on the Infrared LED if, like you and me, we've scavenged from another board and lead length no longer gives you a clue. The image that helped me is attached.
agiuliano martins 10 years ago
I'm planning to do one "universal remote controller" like yours.
And your instructable is perfect for what I'm thinking! :-)
Many thanks for sharing...
Ps.: Sorry my poor english.
Computothought 12 years ago
gregoryfenton 12 years ago
WineSoaked 12 years ago
The only thing left to consider is at what point do you throw out or lock up the actual physical remotes and have everyone use a mobile/tablet/web browser to control your TV and satellite?
Stage one complete, she now asked me if I can use the arduino to control the sky box upstairs.
Do I:
a) say yes and code the ethernet header
b) say yes but I need a second arduino (like maybe a mega)
I would love to do a) but I just sent my ethernet header back as it has been badly soldered so it looks like b)
What is a harmony remote? lmgtfy here I come
I will (possibly) change the code to dynamically resize the image to suit your screen, it is a touch small on my phone screen.
