Arduino Foot Pedal PTT Switch
Intro: Arduino Foot Pedal PTT Switch
Since I got a mechanical keyboard people on Mumble have been ranting about all the clicky-clicky noise it makes :)
I dont like the idea on wasting a finger just to trigger the PTT. So I always use the automatic voice activated PTT.
The solution, a foot pedal to trigger the PTT. I used an Arduino pro micro clone. I guess any compatible Arduino works as long as it got the ATmega 32U4 for the native USB.
I got a piano sustain pedal cheap of Ebay. It´s sturdy enough and has plenty of room for internals.
The project itself is very easy to make. And I guess any kind of switch would work.
STEP 1: Unboxing
The pedal quality is very good and sturdy.
STEP 2: Removing the Rubber Bottom
I removed the floor rubber pad looking for screws. There aren't any :)
STEP 3: Opening the Pedal
To remove the cover, get a very thin screwdriver and bend some pins on one of the washers holding the rod. Slide the rod and the cover comes off.
STEP 4: The Internals
Now it is time to get the Arduino, LED and hookup wire. Also a suitable resistor for the LED.
STEP 5: Isolating the Arduino
I used digital pin 7 for the PTT switch. Pin 9 for the LED. And both GND pins.
STEP 6: Assembling the Internals
Initially I had plans of drilling 4 holes around the Arduino, securing it with zipties. Unfortunately the metal was so hard that my dremel just couldn't drill through. I isolated the Arduino with a piece of rubber glued to the bottom. Removed the polarity switch and expanded one of the holes big enough to push the LED through.
STEP 7: Final Steps
Hot glue is your friend. I used it to secure both USB cable and leads coming from the Arduino. Reassemble the cover and the board is ready for programming.
STEP 8: The Code
Code available here.
3 Comments
Jekotia 8 years ago
Would it be possible to use this hardware to connect 3-6 foot pedals? Would they each be able to be assigned a different key? I was thinking of putting the Arduino in its own enclosure with 1/4" inputs for connecting pedals to, but I have zero experience with the platform.
tactoad 8 years ago
Yes, you can have as many pedals as you have digital inputs on the arduino. Just assign them to different keys.
Jekotia 8 years ago
