Assassins Creed 3 Tomahawk Replica
Intro: Assassins Creed 3 Tomahawk Replica
Materials:
· Scissors
· Black sharpie
· Ductape
· Hard book cover front and back
· Dremle or sturdy knife
· Pvc pipe
· 5 nails
· Warn black leather or pleather
· Red, brown or black leather string
· Silver acrylic paint
· Burnt lumber acrylic paint
· White acrylic paint
· Electrical tape
· 1 small paint brush 1 big paint brush and 1 medium sized paint brush
STEP 1: Step 1
Take your book covers draw the assassins creed symbol on to it make sure it is the size you want the blade. Next use your dremel or knife to cut out the symbol if you use the dremel use a vice to hold your object in place. After you have your 2 ac3 symbols cut out, wrap them up in electrical tape.
STEP 2: Step 2
Cut 18 inches off of your pvc pipe. Pick the spot you want the blade to be at on the pipe then mark it with your sharpie. Next you will need a dremle and a table clamp, cut roughly the same length of the middle of the ac3 symbol make sure that both front and back of pvc pipe are same length and width. Next you will take your blade and put it threw the wholes you just cut.
STEP 3: Step 3
Use the e6000 glue to keep it tightly in place, let dry for a day. After that get ductape and take several strips of the tape and layer the symbol with it while still being able to see the symbol make sure to make the ductape as flat as possible to make it look more like a ac3 blade.
STEP 4: Step 4
Take your silver acrylic paint and your medium sized brush, and paint the blade getting every part of the blade let dry for an hour. Next paint the pvc pipe with the burnt lumber paint using the large brush make sure to not leave any un painted spots, let dry for an hour.
STEP 5: Step 5
Take your scissors and cut the leather into mildly wide strips. Start placing the strips around the pvc pipe 8 inches up. Then cut the excess leather off the ends of the strips so there is no wrapping. Then take the e6000 and glue the pieces to the pipe layering them from the 8 inches to the bottom also glue a circle of leather to the bottom so it is covered up.
STEP 6: Step 6
Take your white acrylic paint and small brush and paint the 3 diamond design on the handle of the tomahawk.
STEP 7: Step 7
Wrap your red leather string 2 inches around the pipe next to the blade leave some space for your brown or black string to wrap around also. Then glue the ends lightly and then do the same with the brown or black string.
STEP 8: Step 8
Take your 5 short nails and hammer them into the leather on the pipe make sure to spread them out decently.
Once these steps are done you should have a assassins creed 3 tomahawk replica enjoy.
4 Comments
Christopher Avier 8 years ago
Very cool!
necd98 7 years ago
thank you
assassn 8 years ago
can you cut it straight down
necd98 7 years ago
If you're talking about the pvc pipe technically yes but I can't guarantee it being as durable.
