Introduction: Assembling a R00tz Parent Badge
Welcome to the 2013 r00tz asylum parent / adult badge assembly page!
By the end of this you will have taught your parent to assemble their own badge.
Because even parents should know how to solder.
Step 1: Get Your Working Area Prepared
As with any project you need the right tools...
- soldering iron
- parent's badge kit
- side cutters
- eye protection
Step 2: Make Sure Your Badge Kit Is Complete
Your badge kit should contain...
- one badge PCB
- one RGB LED
- one green LED
- one IR Receiver
- one capacitor
- six resistors
- two DIP sockets
- two ATTINY85 - one with a white marker
Step 3: Check Out the Failures...
I told you there were mistakes. Kinda awesome mistakes.
Oops.
Oops.
Step 4: Place the Two DIP Sockets
Be sure to have the notches in the correct orientation!
Solder all 16 points.
Step 5: Place the Capacitor
The capacitor goes in either way and you need to solder it and clip the leads using your side cutters.
BE CAREFUL OF FLYING LEADS
Step 6: Install the 1K Ohm, 2.2K Ohm, 150 Ohm and 100 Ohm Resistors
The 1K resistor is marked Brown Black Red, the 2.2K resistors are smaller.
Bend the leads and insert them as directed and then solder them in place.
The 100 ohm and 150 ohm resistors go in the marked holes.
BE SURE TO ONLY SOLDER ONE SIDE OF THE 100 and 150 OHM RESISTORS
Step 7: Install the IR Receiver
Carefully bend the legs of the IR receiver using the edge of the table.
Ensure that the bubble is on the TOP of the IR Receiver.
Step 8: Oops... Forgot the Green LED
Install the green LED with it's flat side the same as the drawing on the circuit board.
Step 9: Install the Battery Pack
Peel off the sticky tape and install the battery pack (it only fits one way) being sure to leave some clear space under it so that you can slip the zip tie through to keep the batteries in place.
Step 10: Install the RGB LED
Carefully bend all but the longest leg of the RGB LED away from the normal position. Look carefully at the pictures.
Insert the longest leg in the hold marked with a stripe and solder only the longest leg in place.
Step 11: Solder the Remaining 3 Legs of the RGB LED
Carefully heat and add solder to the intersection of the RGB leg and the adjacent leg of the resistors.
Clip your leads when you're done.
Step 12: Install the 2 Microcontrollers
Carefully insert the microcontroller chips into their sockets.
The chip marked with a white tab goes near the green LED.
Step 13: Insert Some Batteries and Make It Awesome!
Add some batteries and we are good to go!
Have fun with your fancy new r00tz parent badge...
What can YOU do to make it more awesome?
Send your notes to us on the Instructables Forum Page!
