Audio Problems
Intro: Audio Problems
Anyone who has ever used technology knows one thing: IT FAILS. A LOT. This is more true in the realm of professional audio than in any computer or circuit I have ever worked with. In this instructable, I hope to teach you some concepts that will help you run audio with as little problems as possible. Please note that this instructable only covers VERY BASIC problems you can run into with a sound system. If there is any problem that you would like me to cover, please leave me a comment or contact me.
You can also see my other instructables on sound:
How Sound Works
The Concept Of Sound Pressure (SPL)
Before we go into how to fix problems there are a few things that I strongly believe about sound that you should know.
1. You can't program sound.
2. If it can fail, it will. If there is no way possible for it to fail... then it sill might.
3. You should know your equipment better than the back of your hand before attempting to troubleshoot.
With that in mind, let's talk audio!
How Sound Works
STEP 1: Feedback
Feedback is a howling noise. It can either be on the high end (very high pitched) or low end (very low pitched). Feedback is caused when a mic is too loud and is able to "hear itself" in the speaker. This starts what is called a feedback loop. Tiny imperfections in the mic are amplified, and looped over and over again, causing the howling effect.
You can fix feedback by turning the volume on the mic down (the fader on the sound board), turning the gain down (usually the knob at the top), moving the mic behind the speakers, or turning the main fader(s) down. The preferred way to fix it is to turn the gain down, or the main fader(s). (The main faders affect your gain structure.) If you don't know what mic the feedback is coming from, you should use the main fader(s). To prevent feedback keep your volume and/or gain as low as possible.
STEP 2: Humming
One very common problem in a sound system will be hum. It is also one of the hardest to troubleshoot. Hum is especially prevalent whenever a facility installs a sound system as an afterthought. If you are designing a building and you know that you will have a sound system installed, make sure to have an AV consultant present with your architect. No doubt there will be some fighting between the two. When all is done and over with, you will have many compromises between architectural and acoustical, but in the long run it will save you a lot of money and headaches. Also make sure to have the AV consultant talk to your electrician before any work is done in the room where you will have the sound system.
One of the most common causes of hum is grounding issues. The soundboard and amps should in an ideal world have a dedicated electric line and ground. The rest of the sound equipment should also be isolated from the rest of the electric. If you have computers in your tech booth, try putting a ground lift on each of the computers and see if that helps. A lot of hum can come from a computers ground. Whatever you do, do not leave a ground lift on a computer. Use it for no more than 10 minutes for troubleshooting, and then figure out a way to isolate the ground. Most ground lifts have a contact to easily redirect the ground.
Another cause of hum is interference. Even if you are not using wireless technology in your sound system, cables still have problems with RFI (Radio Frequency Interference). Mute all of the channels on your mixer and bring your mains down. If you still hear hum, that means that it is coming into your line past the soundboard and it isn't one of your inputs. If you don't hear the hum anymore, make sure your cables are properly shielded, and start removing cables one by one to see which ones are giving you trouble. Once you find where you are having problems, try to replace the cable and see if that helps. When a cable starts to go bad, it can start to hum.
Yet another fix would be to have as little unbalanced signal in your system as possible. Unbalanced signal is very prone to humming. The difference between balanced and unbalanced signal is for another discussion, so for now I will just go over the basic cables and whether or not they are balanced. If I forget to address a cable, please leave it in the comments and I will address it as soon as possible. XLR is balanced, 1/4 in. and 1/8 in. (normally used for guitars and headphones) are normally unbalanced, and RCA is unbalanced. Normally the rule of thumb is if it has two contacts for every channel, it's unbalanced. If it has 3 for every channel, it's balanced.
A product for fixing grounding hum is called Hum X, a product for 1/4 connections is HE-2 Hum Eliminator (You could also try a Direct Box A.K.A. DI Box), and a more universal product is DTI Hum Eliminator.
There are more ways of fixing hum, but this covers the basics. If you have more advanced problems, consider hiring an AV consultant. I personally have worked with All Pro Sound, and really like their staff, knowledge, and business ethic. I would highly recommend calling and talking to any one of their staff about any problem you might have.
STEP 3: Clipping
Clipping is a distortion caused when the audio going to a component is too hot (loud). This causes the top of the signal to be "clipped" off. You should turn down the gain or volume on any adjustment available until the distortion is gone. Prolonged clipping can cause damage to equipment.
You can compare a "healthy" waveform to a "clipped" waveform in the pictures.
STEP 4: Wireless Problems
Static on a wireless mic is usually caused when the mic is too far away from the receiver, or when something is interfering with the signal. To fix interference on a mic, you need to adjust the frequency on the mic and receiver to another frequency that is not in use. (Unless you are a licensed operator that is not restricted by Part 15 of the FCC rules and regulations.)
A good way to get the mic closer to the receiver is to move the receivers to an area backstage. Many facilities already have wire run from their backstage areas to their tech booth.
STEP 5: Conclusion
There are many problems that can happen when you are running sound. This instructable only covers a few. If you want me to add a step on any other problem you might have with sound, please leave a comment or contact me.
If you are serious about sound, I suggest looking at your local library to see if they have any books on sound. There is no "right" way to do sound. It is an art form. As long as it sounds good, then you are doing it the "right" way. If Picasso did everything the "right" way, we wouldn't be able to view artwork in the same way as we do today.
Please note that I do claim copyright to the information. I did not use any specific sources when compiling this information, all of this is from my personal experience.
You may quote parts of this information for educational purposes. Under no circumstances will you sell this information.
I do not own the copyright to any of the images (except the pictures in step #2), however, as far as I have been able to find, I have the right to use them in this instructable. If there is any question about whether or not I have the right to use these images, please contact me. I have no intention of stealing anyone's intellectual property.
Use of this information implies that you agree to these copyright terms.
© 2011
© 2011
10 Comments
kustermramba 1 year ago
Biggycat1 5 years ago
kumzyd 6 years ago
8ball947 6 years ago
my church has a EURODESK SX2442FX Soundboard. And for some reason the sound is completely bypassing the soundboard while playing music videos and stuff. And we don't know how to fix it. We can not control the volume from the soundboard. We tried muting button and turning volume down with slides. But it doesn't work. We have to turn the volume down manually on the computer. Cause it won't work on the soundboard. Can you please help?
bricabracwizard 12 years ago
thegeeke 12 years ago
Thanks again!
S_darnell 12 years ago
