Introduction: Auto Sort Saving Tube-自動分類存錢筒
可以自動分類新台幣1,5,10,50元的存錢筒
是利用錢幣的大小來做分類的條件和重力的原理來設計的哦!
是說有改版過4次證明自己還是有點弱弱......目前成功率......
只要好好使用可以100%不過如果投太大力或一次投太多就可能會失誤就是XD
使使用雷射切割可以做出來喔〜買紙板自己切也可以
版厚為2毫米
如果ㄧ如果要用其他國家的貨幣大小或是不同板子的話
提提供原黨DXF可以用的的AutoCAD或其他軟體進行修改唷!
Dxf:
HTTPS://drive.google.com/file/d/0ByIvWvD-nN4hbk9Ra ...
Can automatically classify NT$1, 5, 10, 50 yuan in the piggy bank
It is designed by using the size of the coin to do the classification and the principle of gravity! It is said that there have been revisions over 4 times to prove that they are still a little weak... the current success rate...
As long as it can be used 100%, but if you vote too much or if you vote too much, you may make a mistake.
Make use of laser cutting can make it ~ buy cardboard and cut it yourself
Plate thickness is 2 mm
If you want to use the size of other countries' currencies or different boards,
Provide AutoCAD or other software that can be used by the original party DXF to modify it!
Dxf:
https://drive.google.com/file/d/0ByIvWvD-nN4hbk9RaDZreUU3bWM/view
Step 1: Step1:選擇你要的檔案choose File What You Want
打開檔案,裡面有兩種規格的檔案,如圖中的1和2。
差異僅在於結合的方式不同,會影響切割時間、組裝時間與強度。
整體來說,左邊組裝快速但強度較弱,右邊則相反。
可以選擇自己喜歡的。
Open the file, there are two kind of the file, as shown in Figures 1 and 2.
The difference is the way of combining, which will affect the cutting time, assembly time and strength. Overall, the assembly on the left is fast but weak, and on the right is the opposite. You can choose what you like.
Step 2: 切割Cutting
你需要把檔案放入雷射切割機中,依照機器的不同你得選用適合的參數。
在此檔案中,板子的厚度為2mm,你可以選擇適合切斷2mm板厚的參數。
如果沒有雷射切割機的資源,也可以考慮找外面的代工廠或是工作室。
you need to put the file into the laser cutting machine. You have to choose the appropriate parameters depending on the machine.
In this file, the thickness of the board is 2mm, you can choose the parameters suitable for cutting the thickness of 2mm. If you don't have the resources of a laser cutting machine, you can also consider looking for a foundry or studio outside.
Step 3: 組裝Assembly
切好後可以開始組裝,如圖中的編號對應組裝的位置。先後順序可以以照自己的喜好做調整,完成後最好上一些適合的膠水(如:保麗龍膠、三秒膠)來固定。
After the cut, the assembly can be started, and the numbers in the figure correspond to the assembled positions. The order can be adjusted according to your own preferences. After completion, it is best to apply some suitable glue (such as: styrofoam, three seconds glue) to fix.
Step 4: 完成與測試
組裝後等膠水乾掉,之後可以開始放入硬幣做測試。
記住,這個版本是台灣的貨幣,如果有需要可以依照自己國家的貨幣大小修改檔案,若不知道該怎麼修正可以再詢問我。
After the assembly, the glue is allowed to dry, and then the coin can be placed for testing.
Remember, this version is the currency of Taiwan. If you need it, you can modify the file according to the size of your country's currency. If you don't know how to fix it, you can ask me again.
