Auto Change RGB Led Fan for PC
Intro: Auto Change RGB Led Fan for PC
I had order a bag of 100 rgb led so i get in thought to change any led in any device with rgb.. lol
Sorry this is my first instuctubleand it is a little mesh..
STEP 1: Materials
1 pc fan transparent so the light can pass trough..
3 auto change rgb leds 5 mm
3 resistors 1 K om
40 cm thin cable
3 resistors 1 K om
40 cm thin cable
STEP 2: Tools
Solder Iron with fine tip..
solder stand helper..
hot glue gun.
optional dremel
hot glue gun.
optional dremel
STEP 3: Preperation
Solder the resistors with the anode of the leds as like the pic..
Desolder the old leds or in case of led fan and solder the rgb leds. if the hole is for 3mm led u should open it more with the solder iron or with dremel.
or
Make 3 holes as i tag them in foto with the Soldering iron or with a dremel in case of simple type fan.. in the size of ur rgb leds... Also u have to solder to wires to the red+ and -black in the back of the fan to power the leds..
or
STEP 4: Fix...
Put the led in the holes and glue them.....
connect the + cable to the resistors and - to the cathode of the led...
Dont connect the led in series, only parallel..
STEP 5: Test Time...
Connected to ur pc or to ur supply unit ant test it..
if no led light up and fan is spinning u connect wrong the power or the resistors...
18 Comments
CalcProgrammer1 14 years ago
ninjanody 13 years ago
CalcProgrammer1 13 years ago
Nawaz 14 years ago
looking forward to build it soon... :D
thanks for sharing... ;)
agis68 14 years ago
www.ledshoppe.com/Product/led/LE1008.htm
Very reliable cheap RGB (and not only) LEDS
check out!!!
punkatsub 14 years ago
ninjanody 14 years ago
ramroids55 14 years ago
tinkerman92 14 years ago
circles122345 14 years ago
akatsuki666 15 years ago
ninjanody 15 years ago
cyrozap 15 years ago
