Introduction: Auto Coffee Machine Bluetooth Arduino + Android App
About: 🔩Maker Arduino Raspberry. 🇫🇷🇬🇧 🖨️3D Print and design creation ! 🖨️ ☕My STL design ; https://cults3d.com/fr/utilisateurs/diyfunproject 📲FULL WEBSITE : …
Must of us know what is to be in a rush in the morning and don't have time to wait for the machine to get hot .
In this insctruables i will show how to make automatic coffee with android and arduino.
At the end of the tutorial you will have an android app working in bluetooth to make small/large coffee
and you can even send command by voice recognition !
Step 1: What We Need:
This tutorial does not required much the main will be the coffee mahine !
-Arduino uno
- Coffee machine i used this one, bough from second hand .
-Wire
-Bluetooth module hc06 (HC05 should also work)
-Relay 4 channel as i have 3 button for the machine
-Iron solder
That's it if you already have the coffee machine it will be very cheap
Step 2: Opening the Coffee Machine
Here we have the most complicated part i will advice you to check the doc of your machine.
For the one i use you just need to detach the bottom with something tiny like a screwdriver.
Step 3: Soldering
Now that the machine is open we gonna solder 2 cable under each button and connect it to the relay.
If you use an old coffee with one button it's the same process just use one channel relay.
Step 4: Arduino Side
In this part we see of to connect the bluetooth module with arduino and the relay
The connection between the relay and arduino are:
IN1: None
IN2: PIN 11 small coffee
IN3: PIN 10 turn on machine
IN4: PIN 9 Big coffee
Bluetooth:
VCC= 5v
GND=GND
TXD=RX
RXD=TX
Step 5: The Code:
The code is simple it initiate a bluetooth connection then
If you send value 1 you make small coffee, value 2 big cofee
When you upload the code disconnect the bluetooth (remove the 5v wire) otherwise you will get error
For some reason when I put HIGH it turn off the relay , so if you have problems just try to inverse HIGH and LOW.
then a button is pressed to make the coffee and the machine turn off
check the code comment
<p>char junk;<br>String inputString="";</p><p>void setup()                    // run once, when the sketch starts
 Serial.begin(9600);            // set the baud rate to 9600, same should be of your Serial Monitor
 pinMode(10, OUTPUT);
 digitalWrite(10,HIGH);
  pinMode(9, OUTPUT);
   digitalWrite(9,HIGH);
 pinMode(11, OUTPUT);
 digitalWrite(11,HIGH);
}</p><p>void loop()
  if(Serial.available()){
  while(Serial.available())
      char inChar = (char)Serial.read(); //read the input
      inputString += inChar;        //make a string of the characters coming on serial
    Serial.println(inputString);
    while (Serial.available() > 0)
    { junk = Serial.read() ; }      // clear the serial buffer
    if(inputString == "1"){         //in case of '1'
            digitalWrite(10, LOW);    //turn on machine
      delay(500);
      digitalWrite(10, HIGH);
      delay(120000);                   //time to heat up 2mn (milli)
      digitalWrite(9, LOW);
      delay(500);
      digitalWrite(9, HIGH);           //big coffee
      delay(30000);                      //coffee comes out
      digitalWrite(10, LOW);        //turn off machine
      delay(500);
    }else if(inputString == "2"){   //incase of '2'
      delay(500);
      digitalWrite(11, LOW);
      delay(500);
      digitalWrite(11, HIGH);          //small coffee
      delay(500);
    inputString = "";
}</p>
Step 6: APP Inventor Android
In order to control our coffee machine with our phone, we will create an app with MIT app inventor .
Only requirement a gmail acoount.
You can upload my app and modify it in the app inventor it is very easy to use but i will advice to check some tutorial before.
I add voice recognition so if you say "coffee" it will give you a big coffee
To be able to install the app you have to go to your phone setting (in security) allow unknown sources.
Important :
To send value from the bluetooth i used the object "send text" so it will send the number 1 or 2.
You can also use the "send byte number" but it use ASCII so in order to send 1 to the arduino you need to send the value 49
Pay attention to the difference .
Step 7: Conclusion
We are done !
We can now control our coffee machine with bluetooth. I am not very good in design so forgive me my coffee machine look bad but you can easily make a small box for the arduino and the relay to fit properly
In the future i will update the tutorial with a conveyor belt could be nice to be sure the cup is not missing !
Let me know if you have any idea of improvement .
If you liked this instrucable please vote !
Circuits Contest 2016
IoT Builders Contest
Dorm Hacks Contest 2016
