Automated Lighting Using DMX and Perl
Intro: Automated Lighting Using DMX and Perl
Why automate your lights?
Well, to be honest, most of my house is automated, so it seemed the obvious thing to do.
There are lots of benefits in automating parts of your house, lighting in particular just makes life easier, lights coming on when you walk into a room is better than switching them on yourself! ....and because they turn themselves on, they turn themselves off too, so you can't forget!
Hopefully there is enough information here for most, but if (like me) you love detail, you'll find more information on my page http://www.yourmissus.com/lighting/
Cheers
-Dan
Cheers
-Dan
STEP 1: Installation
Ok, lets start at the light switches themselves.
Each room has either a double (two lights) or a single dimmer control mounted on the wall.
The pictures below show the dimmer control units mounted in the wall, you'll see they are still unfinished, I'm unable to find suitable looking knobs, like the simple white ones you get on a standard dimmer, so until I do, there are none.
These 'control units' look just like standard UK single blanking plates with variable resistors sticking out of the front, and that's because that is what they are!
Below are some pictures showing the insides of these units:
First the single dimmer.
You'll notice also that there is a small black device at the bottom of the unit:
This is a temperature sensor that I use to control the heating, it uses the same enclosure as the dimmer units and the same run of cabling, but they are two separate systems.
The double units are a bit more busy inside, but essentially just two singles in the same box.
STEP 2: Cabling
These dimmer control units are connected using Cat5e cabling back to my understairs cupboard, where the rest of the kit is.
The control units (as you can see from the pictures above) can be easily disconnected from the wall by unplugging their RJ45 plug from the connector. Each dimmer location in the house has a single run of Cat5e to it all home ran back to under the stairs.
The units themselves simply act as a potentiometer, the variable resistors have 3 legs, looking from the front, the leftmost one is grounded, the middle one (the wiper) is the output, and the right one gets 10 Volts DC.
Notice the use of heatshrink sleeving and a dab of epoxy to hold everything in place, this makes for a more reliable unit I've found Connecting them up in this way means that as you turn them clockwise from off to on, the voltage on the middle leg rises gradually from 0v to 10v - This is used to control the dimmer units manually.
Here are some pictures of how the dimmer control cabling terminates under the stairs, I've used standard Cat5e cabling throughout as it is cheap and good quality, I've also used RJ45 plugs and connectors for the same reasons, this lighting system has nothing to do with ethernet, tcp-ip or the like, I'm just using the cabling and connectors normally associated with this sort of thing.
In the picture above, each yellow patch cord represents a dimmer control location, I've used the RJ45 wall sockets as a means of connecting these cat5e runs up to both the dimmers and the temperature sensor control board.
The dimmers themselves are 4 channel units that support both DMX and 0-10v signal to control their output.
I didn't explain this very well originally, so here is some more information on how the 0-10v signal and DMX work together.
The setting of the 0-10v signal (i.e the setting of the dimmer control unit) will (if brighter) override the DMX setting.
This isn't ideal, as it does mean you can leave lights on by mistake, as turning the dimmer all the way up will force the light to stay on.
However, we don't actually use the dimmer controls manually, the lights come on automatically if it is both dark outside (there is a light sensor in the garden) and if someone is in the room (the PIR sensors tell the server if this is the case)
So there is never any need to turn the lights on yourself!
The other potential problem is if the system turned the light on, and you actually wanted to turn it off, turning the dimmer control down would have no effect either.
In reality though, the dimmer racks have a configuration switches on them, should I ever experience a difficulty where the server did something I didn't like, I could either flick one of the DIP switches on the rack, or unplug the DMX lead!!
I hope this now makes more sense.
STEP 3: Dimmer Racks
The dimmer units take the 0-10v signal on a 5pin DIN connector (1 pin is ground the other 4 represent the 4 channels) and they take the DMX signal on a 3pin XLR connector. DMX devices can be daisy chained as each one has its own id set, if you look closely at the picture above you can see an orange cable (0-10v signal), a purple cable (DMX daisy chain link) and a yellow cable (DMX in from the DMX controller)
Here are some more pictures of the dimmer racks:
Across the front of the rack you can see a bundle of 1mm T&E cable, each one of these goes to a different lighting location throughout the house. Quite simply this cable runs from the dimmer straight to the light fitting in the ceiling, this does make the wiring of any light fittings very easy, as there is just a single cable to contend with. These cables are connected to the dimmer racks using male IEC connectors (the male version of a kettle lead)
STEP 4: Serial to DMX Conversion
The DMX signals to control the dimmers come from the unit pictured above. This device takes a RS232 (serial) signal from my home automation server and converts it into the DMX protocol. This allows me to control the lighting throughout the house automatically, and means that you don't actually have to use the dimmer control units in each room, this is really the whole point of automating the lighting, I have sensors in each room (standard security PIR sensors) that are being monitored by my home automation system, if movement is detected then the server sends a serial signal to the DMX controller to bring up the lights in that room etc...
Additionally it means that you can operate your lights over the internet, via SMS, IVR etc.. which can be useful.
Finally a picure of the rear of the server that connects to the DMX interface, this server is used to control the DMX interface.
....More about that in the software section below.
STEP 5: Software
All of my other home automation (security, heating, power, cctv etc..) is written (badly in parts) using perl.
This lighting project is no different, although it does represent my first attempts at using web services.
For the web services I've used Apache 2.x and the Soap::Lite module for perl, to actually talk serial to the DMX controller, I have used the perl module Device::SerialPort.
The whole lot runs under Redhat Linux I call the web services from my actual home automation application like this: (note this is a part of a much larger program)
# Lights off if no movement for ten minutes and movement more recently in the hallway
if ( $epoch - $in11_lastmove > 600 && $in11_lastmove < $in23_lastmove && $kitchenlights == 1 ) {
&send_lights_soap(1,0) ;
$kitchenlights = 0 ;
The actual subroutine being called is here:
sub send_lights_soap {
$soap_response = SOAP::Lite
-> uri('http://192.168.101.172/Lights')
-> proxy('http://192.168.101.172/cgi-bin/lights')
-> send( "$_[0]" , "$_[1]" ) ;
$res = $soap_response->result ;
And as this is a web service, the actual serial interface and web service code resides on another machine on my network, the web service code looks like this:
#!/usr/bin/perl -w
use SOAP::Transport::HTTP;
SOAP::Transport::HTTP::CGI
-> dispatch_to('Lights')
-> handle;
# Call as -> uri('http://192.168.101.172/Lights')
# -> proxy('http://192.168.101.172/cgi-bin/lights')
# -> send("" , "")
package Lights;
sub send {
use Device::SerialPort ;
my $port = Device::SerialPort->new("/dev/ttyS0") ;
$port->baudrate(9600) ; $port->parity("none") ;
$port->handshake("none") ; $port->databits(8) ;
$port->stopbits(1) ; $port->read_char_time(0) ;
$port->read_const_time(1) ;
my ($class , $channel , $intensity ) = @_;
# send data out
$port->write( pack "C", $channel ) ;
$port->write( pack "C", $intensity ) ;
sleep(1) ;
$port->close() ;
return "Done! I used $class with chn $channel and inten $intensity";
Fairly simple code, I'm sure you'll agree, and best of all, because it runs webservices, I can spread these nodes out across my network and call them easily.
Additionally you may have noticed that like most people I've RFC1918 addressed my network, but with a suitable NAT rule, these services can easily be called from anywhere with an internet connection, meaning that I can control my lighting, heating etc.. from anywhere (even a GPRS or 3G phone!)
#!/usr/bin/perl -w
-> handle;
# -> send("" , "")
package Lights;
sub send {
# send data out
sleep(1) ;
$port->close() ;
STEP 6: Conclusions
Well, I hope you've enjoyed what I've done, I love my automated lights!
Good luck if you decide to do something similar.
If you need more info than this, checkout my page on www.yourmissus.com/lighting/
20 Comments
flyingfireguys 12 years ago
Could you Feed the dimmer Packs From a "Master Dimmer Pack".
It would work the same but if you wanted to turn all the lights off in your house you turn the master dimmer packs off?
adrumsolo4u 14 years ago
one suggestion i have is for your manual system. you could go with a "manual override" routine, where you would have two buttons on each wall plate. one for shutting off the lights and one for turning them on at a pre-determined intensity.
you would have to run each control to your computer, which would be quite an ordeal given your setup, but with a good end result. you could simply push a button to turn off the lights when going to sleep, and if the system ever had a malfuntion in movement detection, an "on" button would be the perfect backup.
van johnson112 14 years ago
toastyboy 14 years ago
vodo 15 years ago
You can find it here http://www.milinst.com/DMX/dmxtext.htm
Thanks for your interest
stephenniall 15 years ago
yokozuna 15 years ago
toastyboy 15 years ago
MisterSlippy 16 years ago
toastyboy 16 years ago
GorillazMiko 16 years ago
Pasketti 16 years ago
Erik Lindemann 16 years ago
