Automation of Washing Machine Using Arduino
Intro: Automation of Washing Machine Using Arduino
We are having a semi automatic washing machine. Timer switch and drain switch are spoiled. I tried to replace them but it costs more money. We stopped using it. Then I thought to remove the manual switches and make it automatic. Then I tried this using arduino and worked well with lesser cost. I presented this to my grand mother. In their house there is no over head water tank system. So I didn't try for automatic water filling. We have to fill water manually.
STEP 1: Parts Needed
- Arduino UNO
- 2 channel relay board
- 12v 1amp step down transformer
- 5v regulator IC
- L293D motor driver board
- 60 rpm geared motor
- PCB clad
- common anode 7 segment display
- 2* Tactile switches
- Threaded rod with nut
- Wires
- 2* push to ON switches
- 5v active buzzer
- 2* 10k resistors
STEP 2: Code
Initially it checks for drain closed or not. If it is open drain will be closed automatically, if not all the filled water will be drained. After the drain is closed program runs. There are three timer settings i.e.,3/6/9 mins. After completing washing drain opens and after few mins drain closes and it beeps indicating that the washing is completed. During drain open display blinks until drain is closed.
STEP 3: Control Pannel
make the control panel using 2 tactile switches as shown in the pictures. Diptrace PCB layout is attached. For smooth functioning of tactile switches I used styrofoam, It acts as waterproof.
STEP 4: Drain System
In semi automatic washing machines the drain knob is connected to the drain switch with a nylon thread. When we operate the drain switch, it pulls the drain switch and lets the water drain. I replaced the manual switch using geared motor along with threaded rod. I inserted nut into a wooden block, and fixed the threaded rod to motor so that it pulls the drain switch with nylon thread as shown in the picture. I used two push to ON switches to control the range of geared motor movement to a certain distance. Otherwise it may pull off and break the switch or may not open fully to let the water drain. This is the major setup to take care.
STEP 5: Washing Motor Control and Wiring
Washing motor contains 3 wires. In my washing machine one is directly connected to phase. Remaining two for CW and CCW motion. I connected through relay board as shown in the picture. Neutral is connected to relay board as shown in the picture. When relay 1 is ON motor rotates CW. When both relays are ON motor rotates CCW.
STEP 6: Fitting
Fit all the components as shown in the pictures.
STEP 7: Schematics and Wiring
L293D motor driver:
- 5v to EN A pin.
- A1 to pin 4 of arduino, A2 to pin 5.
- Supply 12v to board.
- Geared motor red wire to MA1, black to MA2.
Control board:
Connect mode switch to arduino pin 3, start switch to pin2 and power the board with 5v.
Buzzer:
Connect +ve to pin 6 of arduino and -ve to ground.
7-Segment display:
Connect anode to +5v and remaining to arduino pins from 12-19.
36 Comments
prashanmalith81 2 years ago
MaxAntony5 3 years ago
I'm currently working on almost the same project, I'm currently working with simulation using Proteus, I stacked things seems to not work properly, can I get help please.
i also want to add a WiFi module so as I will be getting machine status on my phone,
Amirah Shafiqah 3 years ago
wontes2320 3 years ago
sandilya.anisetty 3 years ago
TheKitMurkit. 7 years ago
Great work! But how do you control the rotation speed of motor? It will be bad for the machine if motor goes at full speed in all situations.
Rudy mar 4 years ago
VishnuM29 5 years ago
sandilya.anisetty 7 years ago
Thank you... Speed controller is not provided by the manufacturer in my machine. Speed of the motor is constant.
lathapondy24 4 years ago
Krishnap94 5 years ago
what is mean by pin no 14,15,16,17,18,19 pls help to locate this pins in arduino
JULIO CESARA12 5 years ago
amaizing proyect, just one problem I couldnĀ“t figure out the wires on the mode & time pcb, could somebody help please, thank you to all of you
mukhtyarbasha 6 years ago
in washing.into code what the mean of
i [5]={15,29,44,58,73}
iceng 6 years ago
i is a preloaded 5 num character array, with 15,29,44,58,73...
ainul yaqin 6 years ago
dear sandilya.anisetty
can you send the schematic wiring to my email sabirun327111@gmail.com ?because i was tried 5 times to build this machine but i found some problem in wiring.. i thing your project is great solution for my old 2 tube washing machine. thank you very much
sandilya.anisetty 6 years ago
I will provide you soon
Now this instructables completed with the schematic.. thank you so much dear Sandilya Anisetty.. so i try again to build this machine and succes.. in button wiring i found some problem but solved.. i connect 10K between ground and pin 2 and 3 then shorting temporary 5V to pin 2 for start or pin 3 to choice timer.. all be right.. after time enough motor rotating releasing and pushing between 2 saclar and buzer cry.. then push resset ready to washing again hahaha
