Autonomous Race Car
Intro: Autonomous Race Car
Build this autonomous driving robot car based on a old RC toy car. I removed the radio control board from the car and replaced it with a brain in the form of an Arduino UNO board (plus a motor driver board) and gave it an ultrasonic distance measuring module to see the world through.
STEP 1: Components
- Radio controlled toy car
- Arduino Uno
- Motor driver board (2 channel)
- Ultrasonic sensor distance measuring module
- Bread board
STEP 2: Brain Transplant
Remove the radio control board from the RC car cutting all wires close to the board. Connect wires to the motor driver board - rear wheel motor in one channel - front wheel steering motor in the other channel.
"Steal" power from the cars batteries.
STEP 3: Connect Arduino Board and the Ultrasonic Sensor
Connect the ultrasonic sensor and the motor driver to the Arduino board.
STEP 4: The Programming
The cars intelligence is pretty simple. It's based on different modes that controles speed & direction depending on distance to objects ahead of the car:
FULL SPEED MODE - No objects ahead - full speed
CRUISE MODE - Object is X cm away - slow down
AVOID MODE - Object is too close for comfort - slow down and turn in random direction
REVERSE MODE - Object is very close - stop and reverse for 2 seconds
STEP 5: The Code
Note: you need to find the "Ultrasonic.h" online. As I remember, I had to download a couple of different versions before I found one that worked.
85 Comments
YashuY 8 years ago
please make it fast as soon as possible...
jesper birk 8 years ago
see step 5
TalhaI4 6 years ago
F3E7GSUHZI8QI9Q:159: error: 'class Ultrasonic' has no member named 'Ranging'
distance = (ultrasonic.Ranging(CM));
exit status 1
Any idea how to fix this?
sasdsdferrcfd 6 years ago
plz .how i can do it with L298 driver .what the changing in code?
m0ebius 6 years ago
Watching this work roaming is impressive! but reading through your code I don't see how the Random Seed influences the steering choices. Is this your early code for the project?
ShayanN1 7 years ago
the front motors are not working and the rear motors are moving front only when an I move my hand in front of the ultrasonic sensor. need help
ilkergureli 7 years ago
Hi :)
First of all, Congratulations..
I wonder how many motors(dc or servo) in car? And lastly, is there any hardware circuit of this project ? Please help me :)
Dod5 7 years ago
Can it used for 2WD smart car? do you have sketch code for 2WD which uses L9110s and ultrasonic sensor?
yaseenninja 8 years ago
ayush mandavgane 8 years ago
can i adjust the sensor distance
YashuY 8 years ago
please, can i get the program code for this one..
arduinoarpan 9 years ago
jesper birk 9 years ago
hmmm - does it have a servo steering the front then? You would need to tweek the program - but it should be possible...
GarrukApex 8 years ago
This is an old thread, but if you are reading this-
Instead of one motor turning either fully right or left, with a servo you would have the option of turning in either direction in varying intensities. You would need a single channel motor driver for you rear wheel, and you would be able to connect the servo directly to arduino. Instead of just turning the front steering motor left or right, you would have to specify the angle for the servo to turn to to control steering. However, you would have the option to control the intensity (ie degree) of the turn based on the scenario.
*In case you do not already know, the Servo.h library comes standard with the arduino ide and would be perfect for your purposes.
TejeshB 8 years ago
can we do it with an old motor car not a rc one
ChrisA7 9 years ago
I cannot get the car to move forward, only reverses. any suggestions on what could be the problem?
ChrisA7 9 years ago
I was able to get it moving forward, but now it wont seem to turn.
zerger 9 years ago
I am not able to get your code. It keeps saying that there is a fault.
amir.leboss1 9 years ago
i didn't find the motor driver board 2 channel and i bought the Motor Drive Shield Expansion Board L293D .... can i use it ? and how should i connect it ?
Waiting your answer!
thank you .
