Avengers Infinity Mirror
Intro: Avengers Infinity Mirror
I made a light out of the Avengers Logo with LED's and mirror foil
STEP 1: Prepare Your Logo for Cutting
I used lightburn to create every single layer of the light
The acrylic mirror is also cutted by the laser and glued to the first layer of the light then you measure the width of your led stripe, this will be the height where you have to glue layer by layer together
don't forget to apply enough pressure on your pieces for them to glue tightly together
STEP 2: Applying the Led Stip
now you glue the led strip to the inner walls of your logo, next to the mirror. I made holes for the cables to run behind the wood and enter the foot of the light later on.
STEP 3: Acry and Mirror Foil
now you take a big 2mm acrylic panel and stick the mirror foil to it. here is an easy tutorial on how to do it: https://www.youtube.com/watch?v=fqpnBpaSSzs
now you cut the same file again you have done for the mirror, but make it a little bigger.
the there panels will then be glue to your light.
STEP 4: Finishing the Light
for a good finishing, i glue another few plywood panels on top of it, and spayed them in the desired color
STEP 5: Adding a Foot/Stand
I designed the food in a 3d program, you can download my STL and easily print it yourself
make it with enough infill, so the light will stay good in place.
beneat the stand i used some rubber sticky pads, so that the light doesn't slip away
the stand is designed so that the weight of the light is redirected to the stand, which makes it very stable and it will not easily tilt to the front with it's own weight
the stand is glue with a hot glue-gun.
STEP 6: Controlling the Led
I've used the normal LED driver that was furnished with the light them self, but you can also go for a Shelly if you want to use the light smarter
Arpan Mondal 1 year ago
