Awesome ArduLIGHT
Intro: Awesome ArduLIGHT
There is a new trend to make the car look different from the other similar cars. One of which is to make the car lights lit / blink not as usual.
Such trend began in BMW cars, as BMW uses Lighting Control Module (LCM) to regulate all lightings in the car, from head light lights, tail lamps up to cabin lights.
Various modules used in this trend are connected to the LCM Module of the car as the case of Piggyback for Racing / Performance upgrades on the car's ECU.
Thus, cable connection from LCM module to the lights needs to be modified.
DO-IT-YOURSELF...
After having learned various car electrical references and examples of finished products on x the internet, I decided to use Microcontroller (MCU) to set the flicker / flash of my car head lights, which fortunately I have, the diagram of my Lighting Circuit Diagram, then I have made two versions and the latter is the enhanced version.
STEP 1: The Project Is Named ArduLIGHT Module.
The MCU being used in this project is Arduino Nano V3.0
Arduino Nano V3.0 have 14 Digital Inputs/Outputs and 6 Analog Inputs. which is able to control up to 14 lamps for this project.
USING UNIVERSAL IR REMOTE CONTROL
In order to remotely control the unit or from outside the car, Universal IR Remote Control as the picture below is used.
This Remote Control could be used universally, each key of any IR remote control sends / transmits different codes. Each code can be used for any desired things.
Codes of the above IR Remote Control are as below:
Power 16753245
Mode 16736925
Mute 16769565
Play 16720605
Prev 16712445
Next 16761405
EQ 16769055
- 16754775
+ 16748655
Loop 16750695
U/SD 16756815
1 16724175
2 16718055
3 16743045
4 16716015
5 16726215
6 16734885
7 16728765
8 16730805
9 16732845
0 16738455
STEP 2: ArduLIGHT VERSION 1.0
Above is the first version scheme or the trial phase. IC 7809 is used for generating 9-V regulated power to MCU (arduino Nano V3). IR Remote Sensor is used for data input from IR Remote Control to MCU. The number of Relay Modules in ArduLIGHT version 1 was 8. Output relay is used for switching on/off the lights.
TRIAL OF BLINKING LIGHTS
I tried to color print a front view picture of a car (fortunately similar to mine). LED is mounted on each lamp on the picture, serving as material SIMULATION
MODULE SIMULATION
Above is video SIMULATION of ArduLIGHT with Remote Control and Relay Module
STEP 3: REDESIGN, REVISION, REBUILD…
REDESIGNING THE BOARD
After conducting several tests, among others changing the scheme, the MCU Board needs certainly to be remade 3 ARDUINO NANO units were ‘BURNED And not less interesting… 3 Arduino Nano MCUs were broken due to electric current leak or due to Electric Noise of the car (might be due to ignition etc.) But don’t give up… the research should continue!
TESTING ON BOARD ArduLIGHT unit was tried to be installed on board,..
SUCCEEDED!! Watch the video above…
STEP 4: ArduLIGHT VERSION 2.0
After having improved several times, both the scheme design and MCU Board, the expected schemes was finally achieved. Previously, the board used module relays, and now all relays were changed by MOSFET DRIVER circuit, removing the ticking sound of the relay.
To avoid backflow to the MCU and Mosfet, 6-Amp Diode is used at the line-in and Line-out.
The Mosfet being used is P-Channel Mosfet IRF9540N, which is able to accommodate 23 Amp power .
The board is still using Universal 2 Layer PCB, as shown below.
All Mosfet units are cooled down by one Heat sink. The Unit is ready to be mounted on board.
STEP 5: FINISH and SUCCEDED!!!.. the Result…
Enjoy this video..
thank you!
Saftari
Translated by : Taufik Masjhur
Library & Sketch Code:
Library IR Remote Control Arduino could be downloaded here.
The Arduino Sketch Code
6 Comments
kicker109 9 years ago
Amazing idea. You'd might have to consider the legality in having lights like this. Its starting to look a little emergency service-y. Amazing idea though.
kondzio29 9 years ago
I guess it will kill your lightbulbs... It is not good for lightbulb when it is switched on and off quickly
r5sb 9 years ago
Really cool!
SparkySolar 9 years ago
I love this instructable. Thank you so much,
Rima/Sparky
LunaEros 9 years ago
This is fantastic!
I HAVE to put this in my Lincoln Mark VIII
seamster 9 years ago
Very cool! Great modification to your auto headlights with arduino!
