Awesome Duct Tape Wallet
Intro: Awesome Duct Tape Wallet
Note- This is my first actual instructable so don't be too harsh
Also after i make it neat and add decoration i will add the new pictures
This is a wallet I made for myself based off of one i previously made. It has 1 main pocket, 1 pocket for an ID card and 6 pockets for normal cards and 1 secret pocket for anything that wouldn't fit in the card pocket.
also all measurements do not have to be perfect.
If you like it rate it and comment. if you make it post pictures.
STEP 1: Gather Materials
Duct Tape (any color you want)
Scissors
Exacto Knife
Ziploc Bag
Tin Foil or Paper
Ruler
Surface to Cut on
Marker or Pen
Scissors
Exacto Knife
Ziploc Bag
Tin Foil or Paper
Ruler
Surface to Cut on
Marker or Pen
STEP 2: Making the Outside of the Wallet
First cut out a piece of tin foil or paper 8 6/8 inches by 3 5/8 inches
Then Cover Both Sides With Duct Tape and put this piece to the side
STEP 3: Making the Inner Piece
This is the inner piece that will combine with the outside piece to form the main pocket.
This step is the same as the first step except the measurements are different.
First Cut Foil or Paper in a rectangle with the dimensions 8 5/8 inches by 3 1/2 inches
STEP 4: Making the Card Pockets
This step will show how to make the pieces that will form the card pockets.
First cut two - 4inches by 3 1/2 inches pieces of foil or paper then cover with duct tape.
Then cut six - 1 7/8inches by 3 6/8 inches of foil or paper then cover in tape.
STEP 5: Making the ID Pocket , Part 1
First cut out a piece of foil or paper 6 3/8 inches by 3 1/2 inches.
Lay this so the long way is horizontal.
Then fold it 3 6/8 inches from the right side to form a right angle
after this apply duct tape only to the smaller side
STEP 6: Making the ID Pocket , Part 2
For this step you are going to need the Ziploc bag.
First Place your ID Card into the bottom right corner of the Ziploc bag (picture 2)
Second trace around the left and top edges of your card but leave a good amount(picture 3)
Third Cut just inside of the line you drew(picture 4)
Fourth Trim the bag so it fits on the piece you made in the previous step(picture 5 and 6)
Fifth trace a small semi-circle and cut it out so you can remove your card with ease(picture 7)
Sixth now tape this onto the piece that you made in step 5(look at picture 6 again)
STEP 7: Making the ID Pocket , Part 3
Now you are going to need one of the 4 inch by 3 1/2 inch pieces and the piece you finished in the last step.
First lay the piece with the clear pocket face down
Then take the other piece and lay it on top of it(see picture 2)
Tape the two pieces together(see picture 2 again)
STEP 8: Putting It All Together. Part 1:The Main Pocket
Get The Two Pieces from step 2 and 3
Lay them on top of each other with the bigger one on the bottom(see picture)
Then Tape them together on the left side the bottom and the right side(see picture again)
STEP 9: Putting It All Together. Part 2:The Card Pockets
Now go get all those smaller pieces we made before and the ID Pocket
First Lay the 4 inch by 3 1/2 inch piece on the left side and the ID pocket on the right side(picture 1& 2)
Second tape these pieces down(picture 1 again)
Third take the little pocket pieces and get a piece of tape bigger than it. then take the pocket piece and place it in the middle of the tape. then tape it over the 4 inch by 3 1/2 inch piece and the ID Piece (see pictures 3,4,5 and 6)
Now you're done
Now you're done
STEP 10: Make It Neat and Decorate
Now you are done.
If it is messy go over the messy places with tape to give it a neater look.
Then you can go ahead and decorate it with multiple colors of duct tape or stickers or anything else you can think of.
84 Comments
awesomeness12345 13 years ago
kslattery2 10 years ago
kholly 11 years ago
kholly 11 years ago
alindley 12 years ago
ColleenG 13 years ago
YellowBlu Co. 12 years ago
derekk 12 years ago
DuctSkin! Affordable duct tape wallets for the masses!
derekk 12 years ago
average joe 1999 12 years ago
astaley 12 years ago
silentkarl 12 years ago
jacmaster88 15 years ago
troyqaz 15 years ago
rawrulz17 13 years ago
saitaiable child 13 years ago
Goodhart 13 years ago
