Introduction: DIY. 3D Led Cube 8x8x8 3mm
This project is made by our customer Kohonov.
3D LightSquared DIY Kit 8x8x8 3mm LED Cube White LED Green Ray
Step 1: Accessories
1.1.512 x 3mm white green LED
2.2 x XH2.54-40P round female pin
3.9 x 20P IC socket
4.9 x74HC573 DIP
5. 1x USB to DC005 cable
6.1 xDC005 power socket
7.1 x18P IC socket
8.1 x ULN2803 DIP
9.1 x 40P IC socket
10.1 x STC12C5A60S2 (with code)
11.1x A09-103 Resisters
12.1 x8*8 Self-locking switch
13.2 x 10uf 25V electrolytic capacitor
14.1 x12MHz crystals
15.2x 22pf ceramics capacitor
16.8 x 470ohm resistor
17.2x 4.7K ohm resistor
18.1x LED 3mm
19.1x 0.8mm cable
Step 2: Solder Contacts Are Cleaned to the Board. A Total of 72 Pieces
Step 3: Go to the Resistors, Capacitors and Other Small Things
On the product page shows the type of resistors SMD. In fact, come resistors type MLT. Soldered resistors, and their 10 pieces, 4 capacitors, quartz resonator, the power button, power connector, 9-pin LED and resistor A09-103.
Step 4: Go to the Soldering DIP Sockets for ICs 8 Panels of 20 Pins, 1 Bar for 18 Contacts and 1 Bar for 40 Contacts.
Step 5: Fix the Plastic Stand on the Board and Chip Set
Step 6: Go to Work With LEDs
For convenience, soldering LEDs I made a template of Plexiglas. Draw the lattice 8 x 8 mm with an interval of 15 and drilled holes diodes.
2 Discussions
24 days ago
Hello,
What is a "white green" LED?
Thank you
Question 4 months ago
Could you be more specific about the part with the LEDs? How and Why you bent the legs that way, how to arrange them before soldering, How to attach the layers to form a cube?
