Introduction: BEST PAPER CD CASE EVER!!!!
the title is all that needs to be said and you can thank wolf.alex9 for inspiring me on 90% of the design with my minor alterations made the best that can be made in the shortest amount of time
works for dvds, blu-rays, and whatever sort of compact dis you mind can think of
Step 1: ON THE ROAD AGAIN!!
materials:
1 sheet of computer
hard flat surface
2 hands
cd/dvd for precise measurments
FIRST--having the paper with the short side towards you fold it up about 1 inch
1 sheet of computer
hard flat surface
2 hands
Step 2: YOUNG GRASSHOPPER MEETS MASTER TIGER
With the bottom still folded fold it over hotdog-style as learned in grade school.
Step 3: SPIRIT BROKEN AND UNBROKEN
Next open it open and place a disc into the spot between the fold and the rest of the paper centering it as much as possible
NOTE--you can tell if its centered by looking through the hole in the disc and seeing the crease in the paper in the center of the hole
THEN-- fold over the edges of the paper so as to cover most of the disc do for both sides like in the second picture
Step 4: FIRST FIGHT
When you have this done fold the top corners down as you would to make a paper airplane
XDD
Now fold the corner again like in the second picture so as the little point formed touches the folded part of the paper that now covers the sides of the disc ( pictures help alot )
XDD
Step 5: EMERGING VICTORIOUS
You should all have this done by now and after this your almost done
--fold the top point down to the flat part of the botton so that the point is approx. 1 cenimeter from directly lining up with the bottom and crease the fold so its like a square now.
Step 6: MASTER'S TOP STUDENT
Now when the last fold is creased insert the top point into the folded part of the paper on top of the bottom of the disc. This is closed and completed.
--to open use the second picture to help you-- but pull out the top point of the paper from the bottom tab and lift open one side with your hand and pull the cd out with the other making the case reusable.
AND IF YOU ARE WONDERING WHY I CLAIM THIS IS THE BEST IS BECAUSE IF MADE RIGHT WHICH IT SHOULD BE SINCE ITS VERY SIMPLE THEN IT SHOULD STAY PERFECTLY SEALED AND NEVER OPEN UNLESS YOU OPEN IT YOURSELF AND ITS NOT BULKY OR HAS PARTS THAT STICK OUT AND CAN EASILY STORE 3 DISCS THE MOST I USE IT 2 TO KEEP FROM MESSING IT UP AND . I MADE 10 SO FAR AND I AM GOING TO MAKE MORE SUBSCRIBE AND RATE PLEASE AS THIS IS MY FIRST IBLE!!! XDD MORE TO COME!!!!
