Introduction: BJ-2 Combat Knife : KNEX
This knife is part of a series of weapons for BATTLEFIELD 2142, the Morretti SR-4 is part of that group. This weapon can easily be used to humiliate any foe.
In step 3 part 1 you can replace the 3 upper yellow half moons with white snowflakes, by doing this you can turn it into a bayonet!
Step 1: Parts
Gather the parts that are needed:
Green Rods : 20
White Rods : 21
Grey Rods : 2
Dark Grey Connectors : 3
Red Connectors : 5
Green Connectors : 2
Yellow Connectors : 11
White Connectors : 2
Y Connectors : 1
Tan Clip Connectors : 1
Green Rods : 20
White Rods : 21
Grey Rods : 2
Red Connectors : 5
Y Connectors : 1
Step 2: Start to Assemble the Parts
1. First of all make this part.
2. Add a red connector.
3. Add a yellow connector and a green rod.
4. Add another red connector.
5. Add 2 white rods.
6. Add a third white rod.
Step 3: Continue to Assemble the Parts
1. Add 4 Yellow Connectors, 3 White Rods and 4 Green Rods.
2. Get your 'Y' Connector ready.
3. Attach the 'Y' Connector.
4. Attach the 2 Grey Rods.
5. Make up the knife tip using a Dark Grey Connector, A Green Connector and a Green Rod.
6. Attach the tip to the Grey Rods.
Step 4: Assemble the Handle
1. Add a Connector and a Green Rod on each side.
2. Attach a White Rod across the handle and then attach 2 Yellow Connectors and 2 Green Rods, Repeat on the other side.
3. To one side attach this to it.
4. Attach 2 White Rods.
5. Add a Tan Clip Connector
6. Repeat Step 3 and make sure that the White Rods from Step 4 are connected.
Step 5: The Final Checks
1. Check the handle and make sure it is all put together correctly.
2. Make sure the blade is correctly connected into the handle.
Step 6: Complete
The knife is now complete. This knife is good for combat training, to do this cover the bottom Grey Rod and the tip with your mum's or your sister's lipstick. And when you you get a critical hit like the neck you will know for sure.
