BLUE LED RING
Intro: BLUE LED RING
THIS IS A RING VERY EASY TO MAKE AND CAN BE MADE IN LESS THAN 30 MINUTES
STEP 1: MATERIALS REQUIRED
SOLDERING IRON
BATTERY
WIRE
LED STRIP
FLUX AND SOLDERING WIRE
BATTERY
WIRE
LED STRIP
STEP 2: CIRCUIT DIAGRAM
EASIEST CIRCUIT DIAGRAM EVER
STEP 3: DESOLDER THE LEDS FROM THE STRIP
DESOLDER 13 LEDS FROM THE STRIP
STEP 4: THE SMD LED
IT IS A VERY SMALL SURFACE MOUNTED DEVICE LED WHICH HAVE VERY HIGH POWER NO HEATING AND A LOT OF BRIGHTNESS TOO
STEP 5: START ATTACHING THE LEDS TO THE WIRE
AND MAKE THE RING PATTERN OF YOUR SIZE AND CHOICE
STEP 6: THE FINAL LED PRODUCT YOU WILL GET
TAKE CARE OF THE POLARITY - POSITIVE, NEGATIVE OF THE LEDS
STEP 7: THIS IS THE FINISHED LED.RING YOU NEED TO CONNECT WITH a POWER SOURCE
CHOOSE A POWER SOURCE LIKE I HAVE USED A 3.7 VOLT LI ION RECHARGEABLE MOBILE PHONE BATTERY
STEP 8: SOLDER THE WIRES WITH THE LED
ALSO ATTACH THE BATTERY
MAKE SURE THAT THE THINNER WIRES YOU ATTACH THE BETTER IT WOULD BE
STEP 9: ATTACH IT TO YOUR HAND
PUT IT ON YOUR FINGER AND USE SOME RUBBER BANDS TO HIDE THE WIRE OR PUT DOWN YOUR SLEEVES
STEP 10: LIGHT TESTING
STEP 11: TIME TO LIGHT IT UP
ENJOY EVERYWHERE FROM PARTIES TO MARRIGE RING CEREMONY OR TO SHOW OFF YOUR FRIENDS
7 Comments
БарсиВ 4 years ago
Somebody made the clocks based on attiny 85 on the finger. Led ring would be more esthetic
tashtan1 9 years ago
parvgupta001 9 years ago
voblak 9 years ago
Mr AbAk 9 years ago
It would have been better if you have used (x2) 3v coin cells...
And Thanks For sharing
