BLUEBOX Portable Generator
Intro: BLUEBOX Portable Generator
For a long time I wanted to have something like a Xantrex Portable Backup Power System 1500. The idea of having a silent, off-grid power supply ready for taking in camping trips or wherever I need power for small repair jobs was not possible for several reasons: I live in Romania and over here our grid is 220V (Xantrex being 110V) and the ridiculous pricetag of anything similar. Sure, a small gas generator would have been enough but I hate hearing such noise in our camping trips. Besides, I wanted it to be able to charge it from solar panels.
Last week I was cleaning the attic and I found an old Mustek 800Pro UPS I knew (and forgot) I had. It had no battery but It worked. I also had three 12V/7.2AH SLA batteries. Searching the net on this generator subject I noticed several similar builds that shared the same idea. They were using an inverter for AC output but I decided to repurpose that UPS unit I found. This is a controversial subject but using a UPS unit has its perks. I'll get to this part later on.
So I headed to a local hardware store and came home with the needed stuff. The main thing was the project box. It had to be able to contain everything, be sturdy enough to take the weight and provide some side panels for the external connectors. I found this blue tool box that eventually gave my project a name (very original, I know). The next steps describe the 7 days process. Total cost of the project (excluding my work) - around 180 USD. Cheap, silent and very useful.
DISCLAIMER: This project is NOT for people that do not have advanced skills in electric work and electronic circuits. While building this project LETHAL voltages are available on some parts of it. I take no responsibility for any injuries that may occur while building this by other people.
ADVICE: If you feel like taking this with you on a holiday trip, avoid getting there by airplane as you'll never pass airport security with this. (Good luck trying to explain the security officer that this box full of wires and stuff, with something that looks like a timer on the lid is just a glorified UPS unit.) :-)
STEP 1: Layout and Planing
I started by gathering everything I wanted to use on this project in a separate box. Power plugs, electrical wire, batteries, electronic circuits, connectors, etc. My workspace is very small so I needed to have everything at hand. The blue box I found had the perfect size for my project. It also had side panels I could use for mounting the external switches and sockets. The only thing I wasn't happy was the flimsy plastic It's made of. But I handled that too.
Inside this box I wanted to have the UPS electronic board along with three 12V/7.2AH SLA batteries I had around. The batteries will be connected in paralel for a total amount of 12V/21.6AH battery bank. Not much but enough tor light loads. I first dismantled the UPS unit and kept only the mainboard and the transformer. Then I arranged all the components inside the box. It soon occured to me that I had to arange things so that the weight get evenly distributed. As the box had a top -centered handle I had to arange things like the last photo of this step shows. Any other layout was out of balance and made the box impossible to carry around. Then I decided I have to reinforce the box as the bottom was soft and started to bulge a bit when lifted. See the next step.
The schematic shows the general layout. I'm no technical engineer but you should understand it. It's actually pretty simple. Like a LEGO game for grown-ups. Except that, let me repeat this, it all should be made by people with proper skills. The 220V live lines are LETHAL when touched. Not depicted here, the grounding wires were all preserved and connected to the input plug ground wire. This way, whenever a power surge happens, it can stay connected to any wall socket and use the grounding of the grid. When camping however no grounding will be available. (Unless you're willing to stick a copper rod 2 meters deep into the ground and connect it to any grounding wire of the generator.)
STEP 2: Getting the Box Ready
The box needed reinforcing (the perfect Pelikan boxes are unavailable here). The combined weight of about 15 kg of components was more than it was designed to handle. So I used a very sturdy plywood sheet (cut to the shape of the box) to hold everthing. This plywood got four rubber legs (second photo of this step) mounted using 8mm bolts. This way, the entire weight was supported by the plywood and its four legs while providing some clearance from the ground. This was very good because such a heavy box could easily get punctured by some small rock on the ground.
Reinforcing job done, I got my good old DREMEL and started to cut out the power connectors and switches. This was a pig of a job. The dremel is too fast for cutting plastic and it melted everything in its path. It all went like I was cutting butter with a hot knife. No second chances. Just mark your shape and start the mess. Oh, be advised, the smell of melted plastic is horrible as always. Use a vell ventilated area when doing this. Try not to inhale the fumes.
The DC panel (the fourth photo of this step) needed some special treatment. I wanted to have a fan cool down the UPS board as I always noticed that MUSTEK UPS running hot wether its charging or providing power. That will shorten your battery life. So I used a 60 mm PC fan I had around. At first I wanted to have a switch for it to turn it on or off but then I remembered I had a small circuit I built a long time ago that was a thermal switch for fans. (insert here two days looking for it ). I found it and I decided it will be great as it had a thermistor I could use on the cooling radiator to read the temperature and turn the fan on or off accordingly. I cut out the fan hole and mounted a protection grill over it. The small fuse visible on top is for the DC plug.
STEP 3: Assembly Time
I used the grooves on the bottom of the box to run some wires under the plywood sheet. This was for wire management only. Then I started adding the components. The second photo shows the UPS trasformer bolted to the plywood. Also I kept some of the old UPS case to shield the UPS board from the rest of components. That was also bolted to the plywood. The third photo shows some plastic ribbons I used to secure the batteries in place. I run those thru some cuttings I made in the plywood. My plan was to use industrial-strength double-sided adhesive tape on the bottom of each battery and use these plastic ribbons as an added security. You wouldnt's want those things to start move around the box. The last photo shows everything in place. It's all very sturdy. The thick grey wire (actually an ethernet CAT5 cable) is for the lid connections, more on this in the next step.
All the electrical connections were insulated and verified. Do not take shortcuts when doing this. It's important that you make this part properly as dangerous voltages are involved and you or your loved ones may risk electrical shock when using this unit.
The entire assembly involved several undo operations as the space got cramped in places and I had to mount some things and then the ones on top of them. The last photo also shows the external battery connectors (two 8mm bolts) that were connected the the positive and negative of the battery bank. Those got two plastic spacers (one red and one black) indicating the polarity. I'll also put a plastic cap on them to avoid shorting them. Having external connectors is very important. You could put a solar regulator on those and use a solar panel to recharge the bank. You could also start a car off them if your car battery dies. Or you could just connect aditional batteries to increase the capacity of your bank.
STEP 4: Lid Connections
On the box lid I mounted a panel voltmeter. I wanted to have a quick look on the battery bank voltage whenever I wanted. The panel voltmeter I had needed a separate power supply of 9V to run and at start I was thinking of using a 9V battery and holder. But then I would have had another battery to watch out for. So I used another circuit I built some time ago, an isolated power supply of 9V that was perfect for the job. This way the voltmeter takes power from the same battery it's measuring.
The link is here: http://www.thebackshed.com/windmill/articles/PanelMeter.asp
The three LEDs are taken from the UPS front panel . The yellow one turns on when it's working in "offline mode" providing power to the power sockets. The green one turns on when it's working as an UPS. The red turns on whenever AC overload occurs or battery voltage gets too low (11.8V). Then the power output is automatically stopped to protect the battery. This is one of the great features of using an UPS as an inverter as you already have charging/generating/discharge protection in one unit. Be aware that these UPS units are not designed to run for extended amounts of time. Therefore I used a Pentium II cooler on top of the existing one as well as a cooling fan. As long as you handle the heat, you're fine. Oh, one more thing. The UPS had a lound buzzer that I discarded. The status LEDs are enough.
The lid (last photo of this step) was powered (bank voltage and LED connections to the UPS board) via an Ethernet CAT5 wire. This one had eight pairs of wires. Two were used as power supply (and battery voltage) for the voltmeter and the remaining three pairs for the status leds. A messy job involving a gluegun and steady hands (the rest of the unit was already completed and the lid could only be opened about 100 degrees). I will cover all these wires with a rectangular plastic cover to protect & hide them.
STEP 5: Testing
I have yet to test this generator. The first power on test went fine, everything works. The cooling fan turns on after about 10 minutes of charging via power plug or when turning on power output. Then it turns off as it cools down. The UPS takes 0.5A when running as an inverter, with no load. The voltmeter takes 60mA. The cooling fan about 180mA. Charging via the power socket is going to be three times longer as the original UPS unit only had one battery. Now it has three.
I have a 5W solar panel I want to test this unit with but it's way too small to charge the entire bank. Maybe in a month or so, if the sun keeps shining. :-) The generator powered a small TV set with no problems. That TV was a 60W CRT type. I figure as long as I keep my load on this unit under 500W things will be fine. I'll edit this instructables and post the results here as soon as I run some real load tests.
28 Comments
MSeos 9 years ago
Great information, you are obviously very well versed on this.
Link:http://www.bestportablegeneratorsreviewsonline.com/
xxxSpox 9 years ago
claudiopolis 9 years ago
apillai5 9 years ago
It is a 300w ups mother board and transformer any idea how can i make it more powerful and the batteries in the UPS are in pretty bad condition the acid dried out and only solid particles inside now
thaliquid 10 years ago
claudiopolis 10 years ago
If you take a look on th photos you'll see the tiny vents (holes) I made on the box. Just in case. But here's why I think venting will never happen: The UPS charging board is set to a floating charge voltage of 13.8V. Venting only occurs when overcharging (14V or more) and it's a very slow process. The amount of gas those small batteries would somehow put out will never be a fire hazard. Oh, and that box is far from airtight.
blackvyper 10 years ago
The same to you as well.
skilalowski 11 years ago
claudiopolis 11 years ago
johnnyscolex 11 years ago
vincent7520 11 years ago
I vote !
n2go 11 years ago
I would use 8 standard car batteries + one 600w car dc-ac inverter.
If I were to use a 13w Walmart floodlight (apx $12) I would derive from this setup
(after rounding up...) up to 8 DAYS of continuous light.
Assuming: amps = watts/ volts
Car battery = 12v
Inverter = 600w (max)
(600w/12v = 50amps)
So, 50a distributed over 8 car batteries = 6.25 amps used per battery per hour.
(6.25ah/battery)
Each battery averages 40ah...so (40/6.25 = 6.4 hours of life at full power.)
Now... if I use only 13w (1 LED floodlight)...
Car battery = 12v
inverter -> lightbulb 13w
(13/12 = 1.08333 amps)
1.09a / 8 = 0.13541666ah/battery (rounding to 0.2
Each battery averages 40ah...so (40/0.2 = 200 hours of life for the one floodlight.)
8 DAYS of constant on. (If u use a daylight sensor...16 days)
so, theres the math...have fun!
You know you could make all kinds of guestimations based on theory. But I'd rather test it in real life. I have no way of knowing the condition of each battery and I'm reluctant to just assign it the official values.
The same applies to loads: I have a 12V CFL. It's rated 5W. It actually takes 0.56A (constant) and that's more like 6.72W. A 75W-rated TV set actually takes only 60W. I avoided such predictions because I'd like to test it all in real-life. But if it makes others better understand the potential of my generator, here's the rundown:
- CFL 6.72W will run for (21.6A/0.56A) about 38 hours continuous.
- TV set 60W will run for (21.6A/5A+inverter losses) about 3.9 hours
- Inverter on takes 0.5A just idling. That's a runtime (idle) of 43.2 hours.
Things change if you use 12V loads. It's more efficient as you no longer have inverter losses. But if I were you i wouldn't use car batteries. Instead buy some deep cycle or AGM ones. Car batteries are not designed to handle deep discharges and will fail prematurely.
matokage 11 years ago
Lectric Wizard 11 years ago
