BMX to Motorbike Conversion
Intro: BMX to Motorbike Conversion
Well ok i took my old gary fisher bmx bike. Took my old mcculloch 32cc leafblower. I stripped it down to just the shaft and engine and well youll see the rest
PLEASE NOTE; this is just a experiment to try out instructable I will make a 1 on 1 video and take u through the whole process soon
STEP 1: Mounting the Peg Onto the Engine
Well ok the first thing u want to do is jam the flywheel with a screw driver this allows you to work without the engine spinning freely. Well for my friction shaft i used a normal bicycle peg i would recommend using a 3 inch peg because i used a 4 and that was way too long. The engine i was using has a 5/16 keyed shaft. This was extremely difficult to work with considering it was only 1 inch long and u have 2 fit alot of stuff on it. The pattern i used to lock every thing in place was in this order a skateboard bearing, bike peg, lock washer, nut. This pattern seemed to work very well.
STEP 2: Mounting the Engine on the Bike
well there are thousands of ways of doing this but the approach i took was pipe clamps and nuts and bolts. First of all because i dont have a welder yet and i dont want to ruin my bike. Well since backpack leaf blowers have anti-vibrational spring i used those with a nut and bolt and those thing that go around a handle bar that u have ur bike reflector on except metal. on other areas i just used pipe clamps because i can adjust those easily. For the friction to be applyed to the tire with force i used a very small spring on the mount closest to the shaft for the most leverage. Do remember that this bike cannot idle so you must start it and then run with it and jump on :) Spacecadet505 does not take any responsibility in injury by the machine or human error or anything else:)
STEP 3: Go for a Ride
DO NOTE that i have tested this invention and it is not 100 % my main problem is just how to get enough friction on the tire please leave comments with ideas i will appreciate them.
Go for a ride!!
Go for a ride!!
STEP 4: JUST a PICTURE FROM a DIFFERENT ANGLE
read the title...
46 Comments
BrianW121 8 years ago
Deepest port 8 years ago
ninjassassinswag 10 years ago
You might want to add a counter weight for the motor on the other side and maybe remove the pedals and attach them further away from the engine but other than that great idea
Mr.Hambone 14 years ago
PerfectPantaloons 13 years ago
Yard Sale Dale 11 years ago
It's better to have a bike that you can pedal normally, with the motor on the back, or on the fork. A handle-bar mounted kill switch is a good idea if you do not have a clutch.
I have a friction drive bike I made with a kit from Thats Dax, and a Japanese industrial motor. It works great, has a huge clutch, and a Quick Release to move the roller off the tire. You can put one on a BMX if you want, and it's possible the leaf blower engine will mount to a Dax friction drive kit. Also there is Staton-Inc, which offers more clutch drum sizes.
TSC 12 years ago
Damp Cuttlefish 13 years ago
ElvenChild 14 years ago
duh-man 14 years ago
qaswed 14 years ago
FYI, you can't just put a sprocket on because it would not be a low enough gear ratio. You will need about 35:1, perhaps 40:1 for a weedwacker motor. Otherwise it will just bog down the motor.
sharlston 14 years ago
great ible 5 stars
MrRodrigez 14 years ago
abbynormal 14 years ago
asterman 14 years ago
abadfart 14 years ago
Sandisk1duo 14 years ago
leedemo 14 years ago
