Baby Crib/Cot Braided Bumper
Intro: Baby Crib/Cot Braided Bumper
Hi everyone!
Today I would like to share with you how to make Braided Bumper for Baby Bed, cute and trendy DIY nursery decor. You can make it monochrome, or use any color you like.
Let's start!
STEP 1: Supplies
- Stretch Cotton velvet Fabric (3 colors): Size 35x150 cm
- Pillow stuffing (6pcs IKEA SLÅN Pillows): about 2 kg
- Sewing machine
- Needle & Thread
- Pins & Safety Pins
- Empty Paper Towel Roll or Cardboard
- Scissors
- Ruler
STEP 2: Cut Out
Fold the fabric in half (I took 150cm width). Measured 17cm and cut out.
2 pieces of each color 17cm x 150cm.
STEP 3: Sewing Tube
Take 2 strips of the same color, fix them with pins and sew toghether. You obtain 1 long strip 17cm x 300cm. Form a sleave of fabric by folding strip in half the long way with the right side facing inside, and pin. Make sure that you use a planty of pins as the fabric will be prone to slip.
If you took Velvet, it is impotrant to make sure you always have the nap going the same way.STEP 4: Turn the Tube
Turn fabric tube right side out using a safety pin. Hook a safety pin in one end, turn the head of the pin down inside the fabric. Push the pin in, and then pull the fabric. Do this until the fabric tube is turned.
STEP 5: Start Stuffing
Insert Empty Paper Towel Roll inside tube and roll the half of the fabric around (The half - because the tube is long, and we will work in 2 steps).
Start stuffing:
Place o small amount of pillow stuffing inside and push down with a long object (I use ruler). Keep doing this until you have stuffed the whole fabric tube. Ensure the tube is stuffed evenly. Leave a few centimetres at the end, then close with a safety pin to avoid the stuffing escape.
Now insert the paper roll from another side and stuff the remaining part. Repeat the same with remaining 2 tubes.
STEP 6: Braiding
Join together 2 tubes with slip/ladder stitch. Now you a ready to braiding. Start making a basic braid. For a best results, the fabric seam should allways looks to the back. After, hide and secure the ends of tubes to the back of the braid using needle and thread.
Depending how tight you will braid the bumper, it will decrease in size a little, because it is so soft and fluffy :)
My finished bumper has a length of 2.75 m
That’s it! Now you have unique and personalized nursery decor.
26 Comments
AndréaGodoy 2 years ago
DebMacNab 3 years ago
I live in Canada so I tried to buy the velvet cotton and they didn’t have it. What other fabric can I use?
Thank you so much for this tutorial. I’m planning to make one for my 6 month old daughter in bumble bee colours (Yellow black white with burgundy.
bbcrafts1281 3 years ago
Cocoetmarcel 3 years ago
Auroris 3 years ago
For 2m braid: 85cm x 1.5m
For 1m braid: 50cm x 1.5m
For 2m braid: cut it in 5 strips by 17cm x 1.5m
Sew one Long tube (3 strips) and one Short (2 strips).
Fold the Long tube in half and pin to the Short one. Braid. After braiding the bumper will shorten, measure 2m and just cut off the unnecessary part.
For 1m braid: is almost the same, cut the fabric in 3 strips by 17cm x 1.5m
I hope this will help you. For more question you can
also message me in PM :)
Dilya1 4 years ago
Auroris 4 years ago
I think you should multiply by 1.5 all my sizes. So you final bumper size will be around 420 cm
If you will buy fabric 1.5m wide, as I, you will need:
- 50 x150 cm fabric of each color
Cut the fabric in 3 strips 16.6 x 150 cm, sew together.
You will obtain 3 long tubes, diferent colors, with size 450 cm.
I use 6 pillows (the cheapest Ikea decorative pillows 50x50 cm) to stuff the bumper.
You will need 9 pillows or about 3 kg of stuffing poliester.
Bjguinn 4 years ago
MissyRich 4 years ago
SarahI37 5 years ago
I am looking to make a 2.5m braided bumper of this. But not sure how much fabric to buy - can you please assist for fabric measurements?
I will be using either one color, or monochrome colors in 3.
It would be greatly appreciated!
Auroris 5 years ago
For 2.5m braided bumper is better to follow my steps. You will obtain a little longer bumper (2.75), but is not a problem. Braid, stitch one end, and cut the exact length.
About fabric:
For 1.5m fabric width, in one color, you should buy:
3tubes x (17cm x 2)=102cm
For 1m fabric width, in one color:
3tubes x (17cm x 3)=153cm
I hope I have helped you. If you have more questions don't hesitate to ask. ;)
Kristinarenee3 5 years ago
Auroris 5 years ago
I think you should sew a tube by 4m length, 3 of each one.
If your fabric is 1m width- buy 70cm and make one long tube from 4 parts by 1m.
If you take 1.5 width - 50 cm will be enough (cut in 3 parts by 1.5m and trim unnecessary part at final)
It's all about one tube of one color. If you make it monochrome multiple the size by 3.
Hope I helped you, good luck and share your result :)
MajaN7 5 years ago
Auroris 5 years ago
After you braided the bumper and before sewing the endings, just try it in the crib and trim if it will be longer.
LianneBr 5 years ago
Hi, love your colour choice. How long was the end product? I need my completed braid to measure 2.5m. Do I make 3 tubes of 5m in length?
Auroris 5 years ago
Good luck and waiting your photos
Zoey777 5 years ago
It looks great! Maybe I'll try it. Thanks!
michaelthehutt 5 years ago
Auroris 5 years ago
Thanks for the warning. Good information to read and research for parents.
