Introduction: Baby Shower Diaper Favor
This is a table favor/nut and mint cup was a standard favor for every baby shower my mother ever gave,and she gave a lot of them! She usually made them in pink and blue, but I choose green and yellow for these. My son said I could post it under his user name. Since I thought it was a neat and inexpensive favor and others might be interested in. This is my first Instructable. I would appreciate comments on this product and what you thought of the information presented.
Supplies needed for this project are:
Flannel - Lightweight - color of your choice
Brass safety pins- 0,00 size
Scissors,
Ruler or tape measure
Paraffin Wax- candle or canning
Knife and cutting board (for the wax)
Double boiler or two pans that fit together to make one
Spoon, tongs, foil or wax paper
Nuts and mints or small candies like M&M's
Step 1: Measure and Cut Your Fabric
First I cut the fabric into 6 in squares and then cut them on the diagonal to give me the triangles.
I then folded the the corners in to make a diaper shape, finishing it with a pin, to hold the corners together.
Step 2: Next Melt Your Wax and Dip Your Diaper
In a double boiler melt the wax. I didn't check the temperature of the wax, but you want it hot enough to be clear not cloudy but not so hot that you cannot handle the diaper when it comes out of the wax.
While the wax is melting lay a sheet of wax paper or aluminum foil on the counter to set your finished product on.
Lay the diaper in the melted wax. I used the tongs to pick up the diaper and let the excess wax drain off. Then I carefully slid my fingers inside to make the diaper into the nut cup shape. I then set it on the aluminum foil to cool. You may reshape as needed while it is cooling. I even leaned this one up against a pill vial to make sure that the back of the diaper stayed flat. (this was something I have never done before it seemed to work well)
Step 3: The Finished Product
I reshape them as needed and let them cool here on the foil. Then they are ready to fill.
I hope you enjoy making these old fashioned party favors, but hey.. retro is cool!!
21 Comments
7 years ago on Introduction
I remember my Mom made these for a baby shower for my Aunt nearly 50 yrs ago. I'm giving a shower for a friend & was trying to remember how they had made them. Thank you for posting this and confirming some parts of my memory are still in tact ?. I had one thing to add, I didn't read all the comments but caught one asking about clean up. I'm wondering if you lined pot with wax paper prior to melting wax, then once cooled but still pliable, it would lift out easy peasy...yes/no?
we just poured the majority of the wax out into a storage jar let the remainder harden until we could scrape it out the washed it in very hot soapy water, but the wax paper sounds like an idea worth trying.
10 years ago on Introduction
I still love this great baby shower tutorial. It's my absolute favorite!
I had a great idea that I wanted to share. Instead of using wax, you could get some heavyweight fusible interfacing (available at any fabric & most craft stores CHEAP) using some really cute decorative cotton fabric and fuse the interfacing with your iron to make the fabric stiff. I'm not sure how well this will work but I am going to give it a try this week and I'll be back to let you know how it turns out.
11 years ago on Introduction
this might be a stupid question but how do you clean the wax from the pan after?
Reply 11 years ago on Introduction
wait for it to harden and cut the majority of it out then wash with very hot water to get the residue out
Thanks!!! I'm making them next week and I cant wait. I'll let you know how it goes!
I just thought Id share an Idea, I used a regular size recieving blanket,and folded it half way and shaped it into a diaper with a pin. You can use it to put your favors in it. No need to use wax, it stands up great, and this way the recieving blanket can be washed and used for baby.
12 years ago on Step 3
This is the BEST and most unique baby shower favor I have ever seen! Thank you so much for sharing and especially the step by step instructions. I can't wait to get started!!
12 years ago on Introduction
This diaper favor is absolutely cute. I bought this favor two years ago on Ebay. I have been looking for it for a while. I make baby shower favors and a customer came into my store recently to order several of these favors. Does anyone know where I can buy the diaper at? Unfortunately , I don't have the time to make them due to my diaper business. I have a picture of the favor.
13 years ago on Introduction
Has anyone tried spray starch instead of wax? What are your thoughts on that?
This is really cute! I have what is probably a dumb question: whydo you bother with the wax at all? Why can't you just put thecandy in as it is? Especially if it's wrapped candy like Hershey'skisses, although I was thinking of using M&Ms. I'm sure I'mmissing something here, so feel free to talk slowly and use small words. :-P
Reply 13 years ago on Introduction
You could but the wax enables it to stay standing in an upright position
Ah-ha! I knew there was a good reason! Thank you!
I used your instruction for the diaper favor just last night. Here's a couple of things that might be of help to others. If you pin the diaper with the one point up first, then the left and the right, it seems to sit better when taken out of the wax. Also I used 1 lb of wax melted and was able to make 50 diaper favors with that amount of wax. It is certainly a very inexpensive way to make an adorable favor! The wax was $3.49 for a lb, and I maybe used 2 yds(probably less) of flannel pink and white check on sale 50% off for a baby girl shower coming up. Thanks!!
14 years ago on Introduction
It's been awhile since anyone posted, so I hope you read this. I thought your idea is great. I have a question for you. Do you think it would possible to make one of these for a chip bowl? I am throwing my daughter a co-ed baby shower and she does not want favors, so I was curious to know if this could be made bigger to make something like a chip bowl. Or is this something I would just have to try out? Just wondered if you may have possibly tried something like this or similar to this. Again, great idea.
Reply 14 years ago on Introduction
First of all Congratulations on the grand-child! I think a chip bowl would be very possible even though I have never tried it before. If you cut the fabric bigger and you may need a larger pot for the wax, you could just follow the same instructions and then you might need an extra set of hands to hold the diaper open while the wax hardens. If you made a smaller one for salsa just be sure to serve the salsa cool or the wax would melt.
Thanks for the congratulations, it is our first grandchild and she due in July. We are so excited!!!! I made some of the ones you gave the instructions too, they are so cute, I have to try the bigger ones now. I made them to put powdered creamer and sugar, for all of us coffee and tea drinkers at the shower. I added plastic wrap after they were cool and you can't see it, but makes me feel better so no one can say it taste like the wax, I have a lot of complainers in my family. Again thanks for the great instructions.
I was so glad to find these instructions. We tried to come up with a plan ourselves to make them, but your step by step with pics helped tremendously!!! Love them!
15 years ago on Introduction
Great Instructable!
I like it, a lot.
And yes, I would like some of those nuts. (No, not those nuts....)
I don't think I am too keen to put lollies and things in a poop receptacle even if it is fake. Kinda likes serving m&ms in a potty, even if I was told the the potty was brand new I don,t think I would be to keen. On the upside you could use the diaper thingy for that holiday what's it called? Halloween? Yeah I think thats it, Put in some yellow gummy lollies [Translated = candy] and some chocolate logs [Giant hershy kisses would be cool]. The kids would love it#:)
