Backpacking Toiletries
Intro: Backpacking Toiletries
Toiletries can take up quite some space and weight in your rucksack. Even "travel sized" products are often bulky and come in differently shaped containers making it difficult to pack them with as little empty space as possible...
One nice solution is to fill everything you need in syringes, put a cap on the tip and cut off the plungers:
- Now you have uniform, space saving containers...
- You can fill them with just the right amounts for your trip...
- You see immediately how much is left...
- And they allow you to dose and ration precisely...
STEP 1: Filling
Filling the syringes:
- High-viscosity liquids like toothpaste or shaving gel are best poured in from the back. Just remove the plunger completely...
- Filling from the back is also the best choice if the original containers opening is too small for the syringe. Just don't forget to put a cap on the tip first like I did just a few minutes ago ;-)
STEP 2: Cut the Plunger
Cutting the plunger:
- pull the plunger back until it almost falls out, then cut it off with a sharp knife...
- This saves a lot of space and more important: you can't spill the contents accidentially...
- Keep one of the plungers to squeeze the syringes and throw the rest away...
Saving even more space:
You can even cut the syringe itself if it is only partially filled and throw away the last plunger - just use your toothbrush as replacement...
STEP 3: Some Final Tips:
- I prefer transparent, alcohol based products - they have some advantages:
- Alcohol based sunscreen is very thin - it applies evenly and dries within seconds. But most important: you need much less compared to traditional products.
- They are easy to dilute with water. A 20ml syringe with 50 SPF alcohol based sunscreen can last several days if you need full protection and weeks if the conditions allow you to dilute it.
- Always take more sunscreen with you than you expect to need in the worst case. Running out of toothpaste or deodorant? well... shit happens... But running out of sunscreen can be serious trouble...
Shaving gel:
- Don't use shaving foam - you can't put it out of its container for obvious reasons. Use shaving gel instead...
Deodorant:
- Use liquid deodorant instead of spray. You'll need very little: 5ml is more than enough for a week...
Toothbrush and razor cover:
- I also use a syringe as toothbrush and razor cover. It protects them from dirt but still allows them to dry during the day...
Measure the amounts you'll need before traveling:
- Put the original container on a scale and note its weight...
- Use the product for a few days...
- Weigh it again and divide the difference by the days you've used it...
15 Comments
bdennis4 7 years ago
maxbul 7 years ago
Perfect idea, thanks!
I would propose a simpler way to measure.
Put a liquid you need to use into the syringe and write down a date.
Use it one week or until the syringe is empty.
Now you know how much of the liquid you need (and how big syringe you need) for your travelling time.
GreyCorvid 7 years ago
Have you tried this with bug dope? Was wondering if the DEET would eat the plastic? Am thinking of some drugs that can't go in plastic syringe and need glass. Does any know ?
Thanks
psargaco 8 years ago
Congratulations, this is a brilliant instructable. I'm only thinking that a bunch of syringes in certain parts of the world could end up bringing you to the attention of the law enforcement officers. This could be troublesome in countries where they only start being reasonable after having exhausted all other options.
Nathicana 7 years ago
ashleyjlong 8 years ago
Really unique and efficient way of packaging toiletries! I would agree that one should always take more than enough sunscreen. Take 2 or 3 syringes full instead of trying to dilute! I'd be worried that mixing with water might give you patchy coverage and a super weird burn.
SimoneZ 8 years ago
xaenon 8 years ago
Hi, SimoneZ !
You are correct; this would probably NOT be a good idea for a commercial flight. However, the OP stated that this idea was for backpacking (and presumably camping), where it's desirable to carry only enough to get by for a comparatively short time.
For a commercial flight, regular retail packaging for toiletries are usually acceptable, and even if they're not, you can usually buy toiletries at your destination.
Rabid_Dingo 8 years ago
If one has syringes over 3 oz one is defeating the purpose of this-ible and will be questioned/stopped.
The volume would be the only concern for the security personnel. Diabetic passengers travel with needles all the time.
Christian Knuell 8 years ago
Well, strange looking liquids are never a good Idea at the airport. For me it has never been an issue as I'm just backpacking in the alps and travel there by car. If you're traveling by plane just take the syringes with you - of course without needle - and buy the toiletries at your destination. Unfortunately this forces you to throw away most of it - but if you're backpacking this is often the better alternative instead of carrying unnecessary weight and volume for days or weeks.
Just4Fun Media 8 years ago
No - I'm backpacking in the alps - there have never been any problems or spillages.
Battlespeed 8 years ago
I can buy a multi-pack of small plastic bottles with squeeze nozzles (one 6-oz, two 4-oz, two 2-oz and two that remind me of contact lens cases, for pills) at the dollar store for about $5. They also have screw tops, of course, so no worries about spilling or leaks. How does that compare with the cost of these syringes?
I've paid 15.50€ ($17) for 50 syringes including caps and shipping. My local pharmacy sells syringes for 0.20€ / each but unfortunately does not offer caps.
Don't worry about spilling - as long as you cut the plunger they are safe.
DIY Hacks and How Tos 8 years ago
Interesting life hack.
