Basic Multi-Modular Frames for Cargo Bikes - Stackable Watertight Laser Cut Boxes
Intro: Basic Multi-Modular Frames for Cargo Bikes - Stackable Watertight Laser Cut Boxes
The basic multi-modular frames for cargo bikes is the first building block in our open source platform Vélo M², an ecosystem where we provide the electricity by solar & pedal power and the plans to build modules to your imagination that make use of this renewable energy. We want to make use of cargo bike by adding mobile fablabs, open air cinema, foodbikes, … . If you want a nice-looking stackable watertight laser cut box just to transport all kind of things or to give a place for your module idea or to immediately start building our self sustainable energy module, you first have to go through this building part.
In this documentation you will find everything to make a 450 by 650 mm base with different heights (150, 300 or 450 mm). The realisation of the content of the module itself will follow. If you want to find more about how the inside frame works and how you can arrange all kind of modules, you will find our two examples in the near future: A raspberry-pi based open air cinéma & a mobile open-source fablab
More ideas, concepts and try-outs. Follow us on:
Twitter
Facebook
SKILLS NEEDED
- Laser Cutting
- Basic Woodworking skills
REQUIREMENTS
- One person
- Laser Cutter with at least a 70 on 50 cm dimension
- Chamfer Machine
LEVEL
- Intermediate
TIME
Total time estimate: half-day work
- 20 minutes for preparation of the wood parts
- 25 minutes for file and laser cutter preparation
- 45 minutes of Laser Cutting + extra time for Fase 2
- 40 minutes chamfering the grooves
- 20 minutes sanding + extra time for Fase 2
- 20 minutes varnishing the wood
- 30 minutes assembly
COSTS
- Materials: €40 – 70
- Fablab Day Pass €20 – 50
INPUT
- Sheet of Plywood for the frame
- Water-resistant
- 10mm
- Dimensions: 1700 x 1220
- Sheet of Plywood for the arrangement walls
- Water-resistant
- 10mm
- Dimensions: depending your application of the module
- Varnish
OUTPUT
- One 450 x 650 on 300 mm Basic Multi-Modular Frames for Cargo Bikes
STEP 1: Preparation
Gather the materials
Not all plywood can be laser cut. Make sure your plywood is interior grade with an MR glue line. Check here for details on the materials.
- Water-resistant
- 10mm
- Water-resistant
- 9mm
- Varnish for the finishing of the wood and to make it watertight.
Get the tools
If you have a FabLab nearby, you have all the tools you need.
- Laser cutter with min 100W power and dimensions of min 650x450mm
- Chamfer machine with chamfer head of 10mm diameter
STEP 2: Download the Lasercutting Templates
The lasercutting templates provide the cutting lines for 10mm plywood. If the plywood is less or more than 10mm, the plans should be adapted.
STEP 3: Download Aditional Lasercutting Templates
For other sizes than 300mm height, download the additional templates and follow the same logic.
STEP 4: Lasercutter Preparation
Prepare and set the parameters of the Laser Cutter to cut through 10mm plywood. Check you parameters and make a few test to find the good settings. This is dependent on the type of machine.
STEP 5: Laser Cut !
Laser cut the nine elements following the Laser Cutter DXF files.
For a box of 300mm high use the templates:
In 10mm plywood:
- bottom one time
- side1_30 two times
- side2_30 two times
- balk_pl1 two times
- balk_pl2 two times
- handle1 two times
- handle2 two times
In 9mm plywood:
- mid_plate_1_30 two times (or more)
- mid_plate_2_30 two times (or more)
The wood will be burned on the sides, that's why it needs to be sanded later on.
STEP 6: Chamfer
Chamfer the side plates following the grooves engravings. The grooves are there to fit the mid plates that allow to make compartiments in the boxes. They are placed every 5cm over the whole length of the side plates. Use a 10mm chamfer head to make the grooves.
STEP 7: Finishing
Sanding
The sanding makes the boxes nice looking. The wood burn should be sanded to prevent to black color to be spread. The grooves should be sanded to allow the mid plates to slide in easily.
Varnishing
The varnish makes te boxes watertight. Apply two layers of wood varnish to each element. Check the instructions that are dependent of the type of varnish.
STEP 8: Assemble
Assemble the box following the laser cut indications.
- Fix the side plates and the bottom plate with screws in the laser cut holes.
- Have fun assembling the module to your own ‘goesting’ (cf. Most beautiful Dutch word of 2004)
Fix the top borders to the sides to hold the second frame on top.
Now you have the frame ready to fill it in to your own imagination. What would you take outside with a cargo bike, knowing you have an energy source?
3 Comments
yesimadeit 8 years ago
Could this be used as a solar cooker - with a glass window in the top?
Velo M2 8 years ago
tomatoskins 8 years ago
This is great! I love the look of those boxes!
