Basic Ring
Intro: Basic Ring
The following information is a single lesson in a larger Tinkercad project. Check out this and more projects on Tinkercad.
In this lesson you will learn to make a ring using Cylinder shapes. Here we go!
- Drag a cylinder to the workplane and make it a hole.
STEP 1: Basic Ring
- The cylinder should be scaled to fit the finger it is being made for.
- We will use 17mm for the diameter in this example, but feel free to adjust the size to your needs.
STEP 2: Basic Ring
- Drag a Cylinder shape to the workplane. This will make the outside of the ring.
STEP 3: Basic Ring
- Scale the new cylinder to be 4mm larger than the cylinder hole.
- Since we used 17mm we will scale the diameter to 21mm (17mm + 4mm = 21mm).
- If for example your cylinder hole is 10mm, then you would need to scale to a diameter of 14mm (10mm + 4mm = 14mm)
STEP 4: Basic Ring
- Select both shapes and scale them to a height of 4mm.
STEP 5: Basic Ring
- Keep both items selected and group them together using the group button on the menu bar.
STEP 6: Basic Ring
- Rotate the ring so it is standing up on the workplane.
STEP 7: Basic Ring
Great Job! You made it!
Now that you know how to create a ring, you may want to try adding a decoration to your ring.
