Introduction: Genius Project Basketball Hoop
This basketball hoop is designed so that whenever you shoot a ball, a beeping sound goes off when your basket is made.
Step 1: Get Needed Items
Get all needed materials for the basketball hoop such as...
Mini Basketball Hoop and Ball
Water Alarm Kit
Button Sensor
Soldering Kit
9 Volt Battery
Wire Cutters
Step 2: Connect the Sensor
Put the needed materials together
Follow instructions that come with the kit to put it together
Solder all the wires needed for the process
Cut off the water alarm sensor from the wiring
Switch the water sensor with the button sensor
Solder the button onto the wiring and connect
Step 3: Build Fame Work and Complete
Once you have bought the basketball hoop you can add a frame around the back for extra support.
Then when all of that done you can put the alarm inside of the woodwork as a holder
Run the wiring down the back and to the bottom of the basketball hoop
Put a small piece of wood from the bottom of the frame extended to the hoop
Put a piece of cardboard above the sensor which will be glued to the strip of wood
Once the ball hits the cardboard it will sound the alarm
