Bath Salt Bars
Intro: Bath Salt Bars
Yesterday, my wonderful wife was having back pain. So being the caring husband that I am... I ran her a hot bath and homemade bath salts. Anyway the bath salts really seemed to help and I noticed that I could form the salts into nifty little bars.
STEP 1: Get It Together
So let's see here... what are we gonna need for this one:
Epson Salt - Pharmacy, Wal-Mart...
Glycerin - Pharmacy (I got mine at Wal-Mart)
Baking Soda - Almost anywhere
Cheese Clothe - Grocery Store or craft section at Wal-Mart
Water - Plain old tap water will work great!
Essential Oil(s) - Craft and Hobby stores, also check Wal-Mart (for Scent)
Tools:
Spoon
Measuring cup
Mixing bowl
Large Sauce Pan
Mold or Form of some shape...
Tools:
Spoon
Measuring cup
Mixing bowl
Large Sauce Pan
STEP 2: Make With Tha' Mixin'
So this "recipe" is vague... You can adjust it as you see fit, as long as you get the mixture moist enough to bind together.
Dry work
Step 1: Measure out 2 Cups of Epson Salt.
Step 2: Add 2 heaping spoonfuls of Baking Soda
Step 3: Mix dry ingredients
Wet Work
Step 1: Measure out 4 to 5 teaspoons of Glycerin
Step 2: Add 4 to 5 teaspoons of water
Step 3: Add Essential Oil... The amount of oil you use is entirely up to you. Just don't make it too strong.
Step 4: Stir all liquid ingredients until well blended.
Go Time
Step 1: Pour liquid mixture onto dry mix
Step 2: Stir until well blended. The mix will be like wet sand or icy snow.
Dry work
Wet Work
Go Time
STEP 3: Bringin' the Heat!
Transfer the wet snowy mixture to a large sauce pan. You can also use a glass baking dish. The baking dish is a great way to prevent dirtying so many dishes, however it will take MUCH longer to cool.
Heat the mixture on a medium low setting (electric stove), low (gas stove), or bake @ 250 degrees. The mixture will begin to melt and get glossy. It will also begin to expand... Keep this in mind for later.
[Edit / Revision] The mixture can be heated in the microwave in a microwave safe dish for roughly 1 minute. Micro wave heating melts the mix but it seems to cool quite a bit faster if "nuked."
Be patient while heating. Stir constantly and don't heat the mix too fast.
Once the mix starts to look like cream of wheat or warm tapioca pudding you're ready for the next step.
STEP 4: Taking Shape
Line the bottom of your form or mold with wax paper or cheese clothe (if you can reasonably do so.)
Carefully pour the heated mixture into the mold. Be careful the mixture is quite warm... Also the mixture will continue to expand for a while so only fill the form 1/2 to 3/4 full.
You're done just about all you can for now... set things aside and let them cool.
After the top of the mixture is cool to the touch, flip the mold over on to a cookie sheet or other hard surface. Gently tap the form to release the bath salt chunk. Slowly and carefully peel the wax paper or cheese clothe from the chunk.
Allow the chunk to cool for another 5 to 10 minutes.
You're now ready to cut the bath salt into bars.
Using a sharp knife carefully cut the block into the desired size bars, then leave them to cool some more.
STEP 5: Wrap It Up!
After the bars have cooled to room temp. they are ready to be packaged. We wrapped ours in Cheese Clothe and ribbon which I think makes a very attractive package. You could also used a decorative wash cloth or small box.
If you use clothe cut a cardboard box to serve as a base as the salt is VERY fragile...
Well that's about it for this project, so enjoy your bath!
26 Comments
Althea MaeH 8 years ago
awesome!!!!!!!!!!!!!!!!!!!!
boxen 14 years ago
Gh0stT0wnC0wb0y 14 years ago
JulzRulzz 9 years ago
TunaFishTuna 12 years ago
Mauigerbil 12 years ago
insomniaSAH 14 years ago
Batness 12 years ago
Browncoat 15 years ago
cowboyclint 12 years ago
kfernandez2 12 years ago
Gh0stT0wnC0wb0y 12 years ago
Lunarius 13 years ago
Also, most fragrance oils found in hobby stores for making soap should do great for this, but it's prudent to be wary when you find oils for home fragrance, candles or incense -- some of those aren't meant for use on the skin at all. The same goes for essential oils themselves; some, like bergamot, aren't meant to be used directly on the skin and too high a concentration of oil in your bath salts could lead to unpleasant skin reactions the next time you're in the sun.
Kittyisgood 13 years ago
JosiePosie76 14 years ago
JackiePeters 14 years ago
beans8604 14 years ago
Ascii King 15 years ago
