Bathroom Cabinet With Curved Doors
Intro: Bathroom Cabinet With Curved Doors
After renovating the bathroom, I needed a new bathroom cabinet that had some storage space underneath the wash basin and some extra storage space to the right of the basin. However, due to the layout of the bathroom, the part where the wash basin is located should preferrably be round (so you don't hurt yourself at sharp corners when you walk through) and the part to the right should be very shallow (max 12 cm).
Since I couldn't find anything like this, me and my dad decided to build one ourself.
This instructable does not include the complete instructions for the cabinet, but only for the part with the rounded doors since that is the most difficult part.
STEP 1: Make a Mold
To make curved doors, start by making two identical molds out of 18 mm medium-density fiberboard (MDF). For this part, we forgot to take pictures, but the process is fairly simple:
1. Nail 2 pieces of MDF together, so both molds will be exactly the same. Make sure the nails stick out a little so you can easily remove them later on.
2. Cut them to a rectangle that is much longer and a little wider than you need.
3. On one side of the rectangle, draw a half circle. Make sure the mold will still be much wider than you really need. Draw a center line on the molds. We will need this later on for alignment.
4. Cut out the half circle a little wider than you need. You should now end up with a mold that has an approximate circle that is a little too wide.
5. Shave the mold on all 4 sides to exactly the curvature you need. Do make sure that it keeps quite a bit longer than what you actually need.
6. Remove the nails to separate the two molds. You should now have to identical molds with exactly the right curvature.
7. Nail the two molds onto a third piece of wood, making an upside-down pi shape. The two molds should be spaced apart so that they are placed at 1/4 and 3/4 of the length of the piece of wood you want to bend.
Note: the molds can be re-used later on for top and bottom part (or interior shelf). The time it takes to make these two identical is thus not only for making a one-time only mold but also for making other parts of the cabinet.
STEP 2: Kerf-cut Your MDF
To make the curved surface, we will use 2 pieces of 8 mm MDF. Both pieces will be kerfed on one side and will be set on the mold and then glued together. The piece that will be on the inside will have its kerf-cuts towards and the piece that will be on the outside will have its kerf-cuts towards the inside. This way you will end up with curved doors that have a smooth surface on both outside and inside.
Both pieces of MDF should be a bit wider and longer than you need. When calculating the length you need, keep in mind that the piece that will be placed on the outside will have a bending radius that is 2 * 8 = 16 mm larger than the piece on the inside. It is a good idea however, to keep both pieces at the same length, since it will then be easier to remove the fixations of the inner piece later on.
If you haven't done so yet, calculate the half circumference of the outer circle (= pi * (r + 1.6), where r is the inner cicle in cm). Round this up to whole cm. (In our case, the inner cicle was 19.0 cm, so the half circumference of the outer circle was 647.2 cm.)
Follow these steps to kerf-cut the MDF pieces:
1. Start by finding the center of the pieces. Draw a dashed line there and make sure it extends on the sides and on the back. We will need these lines to align the pieces later on.
2. Working from the middle, draw two rigid lines at 0.5 cm from the center line: one to the left and one to the right. Next, draw rigid lines at 1.0 cm interval to the left and the right until you at least covered the length of the half circumference of the outer circle. (It doesn't hurt to add one more extra just to be sure. In our case, I've drawn 32 lines to the left and 32 lines to the right, for a total length of 65 cm.)
3. Take a piece of spare 8 mm MDF and draw a few lines, 1.0 cm apart. We will use this to find the right depth of the cuts.
4. Adjust your portable circular saw such that the blade will make a cut of only approximately 7 mm deep. Test this out on the piece of spare MDF. If the cut is not deep enough, it will be difficult to bend and might even break. If it is too deep, the material will be too fragile. See images below for how shallow the cut should be and how far you can bend it.
5. Once the saw is adjusted to the right depth and you are satisfied with the test kurfs on the spare piece, make the kerfs on the real MDF pieces. Save most of the saw dust as you will need it later on to make the glue thicker.
After making the kerfs, fixate the MDF sheets with several glue clamps on some solid pieces of wood to prevent damage.
STEP 3: Place the Kerfed MDF (part 1)
Place the first piece of kerfed MDF onto the mold with the kerfs on the outside. Align the center line with the center lines on the mold. Fixate it onto the mold with a nail in the centerline, make sure the nail sticks out a little. Starting from the center line work your way down, use more nails to fixate the MDF to the mold. Make sure the space between the MDF and the mold is minimized. For the last nail, don't use a nail but a screw and screw it in all the way. These screws should be on the outer ends of the MDF.
Next, remove all the nails, but leave the 4 screws. These 4 screws are all that fixate the MDF to the mold now. Check again that there is hardly any space between the mold and the MDF.
STEP 4: Fill Up the Kerfs
The next step is to fillup the kerfs with a paste of saw dust and wood glue:
1. Make a mixture of saw dust and wood glue (1:1 based on volume). If it is too thick to easily spread out, add a little bit of water. We used Bison wood glue D3.
2. Use a putty knife to work the putty into the kerfs. Work from the center along the cuts towards the outsides to prevent airtraps.
3. Once all kerfs are filled, dilute some glue (without saw dust) with a little water and use a brush to smooth out the grains of the glue / dust putty.
Place the second MDF plate on a flat surface and repeat steps 1 - 3 above.
STEP 5: Place the Kerfed MDF (part 2)
After you've filled both MDF plates with the putty and smoothed out most grains, use a brush to apply pure wood glue on both plates.
Place the second plate on top of the first with the kerfs to the inside. Carefully align the plate on the other plate and fixate it with a lot of nails to the bottom plate and the mold. Try to minimize the gaps between the MDF plates and the mold, but let the nails stick out a little bit for easier removal.
The most likely part that will deform during curing of the glue is the space between the MDF plates where the straight section ends and the curve begins. To prevent the deformation, add some wood and glue clamps to hold the plates together.
STEP 6: Cut Out the Doors
Wait 24 - 48 hours to let the glue dry. Then draw the lines where you need to cut to create the doors. Remove all the nails and remove the mold. The bend wood should not deform and should be pretty spingy and strong.
Then cut out the doors. During cutting, use the mold as support.
As you can see in the pictures, we used the large piece to create the base of the cabinet.
For the hinges of the doors, we cut out a small piece at the edges of the doors where the hinges should be. Then we inserted a thicker piece where we had cut out a hole for the hinge.
For the final step: connect the doors to the base of the cabinet and check that everything fits.
STEP 7: Paint and Install the Cabinet
Now that the cabinet is ready, the only remaining thing is painting. I've used water-proof latex (bathroom quality) for the first 2 layers, since MDF tends to soak up paint and moisture. After that, I used 3 - 4 layers of high gloss white lacquer. The top piece is oak wood with 5 very thin layers transparent lacquer (marine grade).
Once the paint is dry, fixate the cabinet to the wall, add the faucet and sink. Connect all the plumbing and then marvel at the result. ;-)
69 Comments
joshi.vijaya1 3 years ago
And also learned surface area of my coffee table too. Good old YouTube and internet
I will post the image once I had made it but will be a while- off the DIT store for MDF.. C U SOON
Odama1 6 years ago
Hi there. Very well done ... so well done that I am thinking in doing one for my small bathroom. Since your cabinet it is suspended how did you fix the cabinet to the wall! Thanks Lino
admarschoonen 6 years ago
Thanks! I've used 4 shelf brackets similar to these: http://www.toolstation.com/shop/Ironmongery/d170/S...
I don't remember the size of the brackets any more, but I used 2 big ones for the round cabinet and 2 small ones for the small cabinet. The brackets were fixed against the wall and both cabinets have little slots in the back so they could just slide over. Add a few screws to prevent it sliding back and you're done.
Odama1 6 years ago
Thanks Mate. I just start the gathering of the materials and soon will start making one next summer (I mean in December).I love it. Once more thank you.
SQUAREeGG 7 years ago
What do you use to seal your end grain on MDF?
admarschoonen 7 years ago
It's been 3 years ago and haven't seen any issues.
jperry26 9 years ago
BenKochan 9 years ago
This is a really simple way to make curved doors - do you think it would work with doors about twice the size?
admarschoonen 9 years ago
Hi Ben,
We didn't have much issues with this size, so I think it could be doable. Be careful though that the cuts don't break while handling and positioning the kerfed wood. The extra weight due to the larger size might put extra stress on the kerfs during this phase.
Once the glue has cured, it should be as solid (or even more solid) as before. Any small cracks in the kerfs on the outside can still be polished away with some wood-filler and a good paint job. (We had to do that as well in some places.)
lsymms 10 years ago
Hi Isymms,
Yes, I made a small jig to make the vertical cuts in the middle. Nothing fancy so I didn't take a picture.
Sorry for the late reply; I only saw your comment just now.
admarschoonen 10 years ago
The only part where we used electric tools was a circular saw for making the kerfs, since you need very good control over the depth.
thayes4 9 years ago
wow, this form of a curved wood surface is exactly was I was looking for. Took a lot of misses before I hit this. Thanks a ton for sharing!
josdevassy 10 years ago
icooper2 10 years ago
AngryRedhead 10 years ago
emerson.john 10 years ago
Tinworm 10 years ago
Thank you
OTP1 10 years ago
