Battery Percentage Indicator
Intro: Battery Percentage Indicator
Hii friend,
Today I am going to make a Battery level indicator that will show the percentage of up-to 15V Battery.This circuit is very easy to make and it is very cheap.
Let's get started,
STEP 1: Take All Parts As Shown Below
STEP 2: Solder All Components in PCB
Solder all components in PCB according to this circuit diagram.
STEP 3: Insert All LEDs in PCB
Insert all LEDs in PCB in series like circuit diagram.
STEP 4: Solder All Wires
Solder all wires of LEDs as solder in picture.
STEP 5: Insert All Resistors
Now insert all resistors in pcb as inserted in the picture according to circuit diagram.
STEP 6: Solder All Wires of Resistors
Next solder all wires of resistors as solder in picture according to circuit diagram.
STEP 7: Next Solder Input Wire
Next solder voltage input wires as solder in picture according to circuit diagram.
Black wire is -ve and brown wire is +ve input DC power supply.
STEP 8: Circuit Is Ready
Now our battery level indicator circuit is ready.Now match circuit according to the circuit diagram and
Give input power supply to the circuit.
NOTE:We can give maximum 15V DC power supply to this circuit.
As in picture when I give above 13V DC input then all 5-LEDs is glowing.
STEP 9: We Can See All Voltages Level in Pictures
As in all pictures we can see the different voltages Indicate different LEDs are glowing.
As in picture 1 show when I give above 2V then one LED is glowing,
When I give above 5V then two LEDs are glowing,
when I give 10V then 3-LEDs are glowing,
When I give above 13V then All 5-LEDs are glowing.
Thank you
8 Comments
seriolapistola 1 year ago
Lakz 1 year ago
stkeith11 3 years ago
This "indicator" would show:
5 lights - Probably overcharged, you may be damaging the battery.
4 lights - almost dead, stop now, and you may have hope of getting significant life out of it, recharge immediately.
3 lights - beyond dead, you are significantly harming the life of your battery, recharge immediately.
2 lights - significant permanent damage has occurred, and if you keep doing this, you're going to trash this battery in short order.
1 light - even more significant permanent damage has occurred, and if you keep doing this, you're going to trash this battery in short order.
While an interesting exercise, it has no useful applicability to acting as a battery charge level indicator.
Jack Reimer 1 year ago
Seventeenrodeo 2 years ago
I was wondering how to calculate the needed resistors for an 18/20 volt system, I am running (3) 6v SLA batteries in series for my kids powerwheels. I want to make a battery level indicator. Basically what formula to use to determine resistor size?
Thank you.
harshkhodwe 3 years ago
Catfishjames 4 years ago
