Be Aromatic~!
2,314
8
Introduction: Be Aromatic~!
You might have experienced your own foot odor especially when you wear long boots or ugg boots during winter.
When it happens, it is absolutely shameful if we need to take off shoes somewhere.
Furthermore, it is pretty hard to remove foot odor in the shoes, especially for boots, we can not wash the whole boots easily or often.
This is special shoe rack that removes foot odor in your shoes! It is easy and convience!
Step 1: Draw and Cut
You will need: Automatic airfreshner, Cardboards, Cutter, Pencil, Steel ruler, Rubber mat
Draw 4 different shapes on the cardboards and cut them.
You will need 2 pieces for number 3.
Step 2: Glue the Pieces
You have 2 pieces of sides and 1 piece of top, bottom and back. Glue them accordingly.
Step 3: Disassemble the Automatic Airfreshener
Disassemble the air freshener in order to reduce the volume.
You can remove the case and just keep the air freshener with the button.
Step 4: Make a Airfreshener Box
Use any shoes box or any other box, if it fits the air freshener in it.
Make a 1.5cm x 1.5cm hole in the middle of the box (at the bottom).
Attach the air freshener at the top of the box inside.
Make sure to match the point that the spray comes out to the hole you made at the bottom.
Step 5: Attach the Airfreshener Box to the Body
Put the battery inside of the box and button on the top of the box.
Glue the air freshener box at the top of the body.
Make sure to match the holes on the box and the body.
Cover the box.
Step 6: Done
You can put your boots in side now.
Remove foot odor in your shoes!!
Step 7: Movie
Step 8:
Be the First to Share
    • Laser Challenge
      Laser Challenge
    • Paint Challenge
      Paint Challenge
    • Unusual Uses Contest
    2 Comments
    lemonie
    lemonie
    10 years ago on Introduction
    That's an original bit of engineering, good job.
    L
