Introduction: Beard to Paint Brush
I am an Artist and I use paint brushes. One brush in my arsenal of brushes is always made from my hair or beard in the case of this brush. I find that painting with my own hair puts more of me into my art and makes it uniquely mine. The hair paint brushes are not the best or worst I have made fine tip to broad tipped brushes. For this Instructable I will be making a broad brush.
Step 1: Grow Some Hair
This step takes awhile. So I trim my beard off every 3 or 4 month and grow it again. Braid it and band it tight then cut it off.
Step 2: After the Weirdness of a Hair Cut
It is always a weird feeling after a haircut adjust to the changes and get over it hair grows back.
Step 3: Get a Stick
To make a brush it will require a stick to hold it other wise its just finger painting. I used oak and left the little summer acorns on the shaft because I was reading a bumper sticker that said "THE MIGHTY OAK,ONE LITTLE NUT THAT HELD ITS GROUND" and for me that was one heck of a statement. So cut off the leaves and trim the ends to a point.
Step 4: Pull Some Hair
Unbraid some hair and lay it across a string tie it then fold the hair over and tie it again. Then tie it a few times just for good measure and add a drop of waterproof glue on the tied end.
Step 5: Stick to It
put a dab of glue on the stick and push the brush end onto it then tie it to the stick with hitch knots and glue the ends. Trim off loose hairs and shape the brush as desired.
Step 6: Paint
Your brush is done now paint. Need a pen check out my quill
Epilog Challenge VI
Paint It! Sponsored by Olympic Paint
13 Discussions
5 years ago
could you do this with horse hair?
Reply 1 year ago
Yep
6 years ago on Introduction
I guess that means that there is no risk of someone stealing your paintbrush! That is yours alone, and only you can use it! XD
Reply 5 years ago
Lol so right!
Reply 5 years ago
XDDD
6 years ago
You should try getting a paintbrush at a store and removing the hair, then put your own hair on.
Reply 6 years ago on Introduction
that would work. But why pull the hair from an existing paint brush?
Reply 5 years ago
yah, I gues that you could replace the bristles with hair oncwe the bristles start, as I say "dying" you know when the bristles are in such a bad condition that you can't use the brush.
5 years ago
the only thing i can say is bruh...
5 years ago on Introduction
This is the most metal thing i've ever seen.
6 years ago
To replace the paint brush hair with your own hair.
very nice, very creative!!!
thanks
