Introduction: Beebeecraft Tutorials on Making Red Crystal Earrings
The simple crystal earrings are beautiful and stylish, and they are classics in our jewelry box. Earrings are an integral part of the ladies' jewelry box. Various colors and styles. Different styles match different costumes and occasions. Today, we will learn how to make a pair of crystal earrings with Beebeecraft. The red glass beads makes the earrings brighter at once. And this earring is suitable for any occasion. Do you want to have a try?
Step 1: Supplies Needed for the Earrings:
15x10mm Clear Faceted Glass Drop Beads Strands
10mm Red Transparent Glass Bead Strands
2mm White Glass Seed Beads
2x2mm Two Cut Round Silver Hole Glass Bugle Beads
6mm Glass Pearl Beads Strands
Silver Iron Jump Rings
19mm Silver Brass Earring Hooks
0.2mm Transparent Fishing Thread Nylon Wire
Jewelry Pliers
Rustless Round Nose Pliers
Stainless-Steel Scissors
Iron Sewing Needles
Step 2: Make the Basic Part of the Earrings
1st, using the fishing wire to string 5 seed beads and make the beads a circle;
2nd, using the fishing wire and needle to string the seed beads string, one clear Glass Drop Bead, several bugle beads, two red glass beads and several bugle beads(as the picture shows);
3rd, connect the two ends of bugle beads string by passing the other end of fishing wire through the hole of the glass drop bead.
Step 3: Finish the Crystal Earrings
1st, string another bunch of bugle beads with both ends connected to drop beads and redbeads;
2nd, connect one pearl bead at the bottom of the drop glass bead;
3rd, use the jump ring to add the earring hook to the beaded pendant; 4th, repeat all the steps above to make the other earring to make a pair.
Step 4: Now, This Red Crystal Earrings Have Been Finished:
Now I have finished this Beebeecraft red crystal earrings tutorial, so easy but beautiful, right? I'm sure the pretty earrings will make you pretty. Hope this couple of red crystal earrings can bring you warmness and good mood.
