Beebeecraft Tutorials on Making Tibetan Beads Necklace
319
Introduction: Beebeecraft Tutorials on Making Tibetan Beads Necklace
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Do you like Tibetan style necklace? How about learning to make a necklace with Beebeecraft during leisure time? It’s easy to finish by following this tutorial. Try to make your jewelry meaningful. Let’s start.
Step 1: Supplies Needed for the Tibetan Beads Necklace:
12~25x8~13mm Antique Golden Tibetan Style Beads
12.5x10.5x1.8cm Mixed Color Tibetan Style Spacer Beads
8mm Mixed Color Cat Eye Beads
8x4mm Golden Bead Covers
5x0.7mm Golden Jump Rings
12x6mm Golden Lobster Clasps
2mm Golden Round Spacer Beads
0.38mm tiger tail
Steel DIY Jewelry Plier Sets
Step 2: Instructions on How to Make the Tibetan Necklace
1st Select the beads according to your preferences, and thread them on the wire. Then put a 2mm spacer bead on the end.
2nd Thread the four beads on the wire in the opposite direction.
3rd Continue to thread the other beads on both sides of the wire. Pay attention that the both sides should be symmetrical.
Step 3: Another Instructions on How to Make the Tibetan Necklace
4th Use a 2mm spacer bead and bead cover to fix the end of the necklace.
5th Use the jump ring and lobster claw clasps to connect your necklace.
Step 4: The Final Look Is Like This:
Now the project of making Tibetan style necklace is completed. It’s so special, isn’t it? Do you want to have a try ? Maybe you can do it better than this tutorial, and you can adjust the length of the necklace. Welcome to find more jewelry supplies on Beebeecraft where you can meet your craft needs.
Be the First to Share
    • Halloween Contest
      Halloween Contest
    • Microcontroller Contest
    • Crayons Challenge
      Crayons Challenge
