Introduction: Beebeecraft Tutorials on Making a Pair of Sweet Earrings
This Beebeecraft tutorial will show you some special tips about how to make a pair of sweet earrings. Small and cute earrings are extraordinarily suitable for summer, and they are suitable for girls. As you known, pink gemstone beads is popular for making jewelry, especially earrings. This is because the gemstone beads are very textured and glamorous. Pink gemstone beads extremely make you shiny and playful.
Via making your own gemstone beaded earrings, you can create items that actually accord to your personal preference and add sparkles to any outfit as much as you’d rather to. Once you master the skills for major craft jewelry ideas, you can make them easily at home. What’s more, you can also wear them, give to friends as special gifts or even sell them.
Step 1: Jewelry Craft Supplies Needed to Make the Sweet Earrings
10mm Jade Beads
2mm Glass seed beads
18mm Iron Sliver Earring Hooks
0.2mm Thread Nylon Wire
4~10mm Brass Jump Rings
Flat Nose Pliers
Cutting Pliers
Step 2: How to Make the Sweet Earrings
step1: Secure beads in a wire
1st, slide a pink gemstone beads and a white seed bead in turn, and their number both three eventually; 2nd, slide three seeds bead between the two glass beads.
Step2: Finished the sweet earrings.
1st, slide a white seed bead between the pink beads;
2nd, connect the jump ring in a seed bead which is placed in the middle of the seed beads; 3rd, attach an earring hook to the jump ring.
Step 3: The Final Look of the Sweet Earrings:
Wow! How beautiful and cute earrings. These tips are easily to learn and just spend your little time. Fellow the steps above and you can easily have a pair of sweet earrings made by yourself.
