Beer Can Soap Dish
Intro: Beer Can Soap Dish
It holds your soap and it's made from a beer can :o
STEP 1: Materials
For this Instructable you will need:
- A can you'd be proud to flaunt (473ml works well)
- scissors
- dry erase marker
- scissors
- dry erase marker
STEP 2: Prepare Can
Lay your can on its side such that the mouth is at the bottom.
STEP 3: Draw Cut Lines
On the top of the can, draw a line from one end to the other. Make sure you leave about half a cm on each side (you need to fold this part over later so nobody gets cut).
At the end of this line draw another set of lines that reach about 1/3 of the can's circumference downwards.
STEP 4: Cut
With your scissors, cut along the lines. It might help to poke a hole at the end of the lines with a small screwdriver so you don't cut too far
STEP 5: Bend
Using the edge of your table as a guide, bend the sides down away from their natural position.
Next you'll want to bend over the sharp edges of the can so that nobody bleeds on the soap!
STEP 6: Insert Soap
Insert soap.
You know what to do next!
I guess you could insert other things as well. Maybe pop tabs if you're into that; or butter.
7 Comments
nelsonguitar 10 years ago
Matt4_16 15 years ago
shooby 15 years ago
austin 15 years ago
bruc33ef 15 years ago
HeWantsRevenge 15 years ago
Scott_Tx 15 years ago
