Bench Top Tool Stand
Intro: Bench Top Tool Stand
An extremely easy and quick project is building a stand for a bench top tool. If you have a well equipped workshop they can be built from cut offs and scrap wood. Other than a pocket hole jig, no special tools are necessary. For the last stand I built the only purchase necessary was plastic furniture guides for the legs.
STEP 1: Materials Needed:
The dimensions of the stand are determined by the size of the tool you are building it for. For my newly purchased scroll saw I chose a height of 30 inches as the best for working at the saw sitting on a stool. The foot print of the saw was perfect for a 24 inch wide piece of plywood cut off on hand. Four 30 inch legs I made from a couple of 2 x 4's on hand. Stretchers were also made from cut-offs from other projects. The stand top should be about one half an inch larger in each dimension than the assembled frame, and the plywood shelf the exact dimensions of the frame.
STEP 2: Making the Pocket Holes
Over the years I have been making furniture carcasses with mortise and tenon joinery, but have recently discovered the ease and simplicity of pocket screws. A jig is necessary to make the pocket holes. The best on the market that I have found is by Kreg. There are several lesser costing simple jigs on the market, an excellent one from Rockler, and much more expensive dedicated machines available. I made the pocket holes for this project in less than 20 minutes, a job that would have taken mortise and tenon joinery many hours
STEP 3: Assemble the Project
Make the frame in two sections, screwing the stretchers to the legs. Use a thin board to space the stretchers in the middle of each leg. Then assemble the two sections together into the frame. I only drilled one pocket screw on each end of the stretchers. In retrospect I would have had a much stronger joint had I drilled two. Clamping the legs to the workbench facilitated the assembly.
STEP 4: Put Top, Shelf and Guides
Now you are ready to screw on the top, shelf and finish with guides. Remember that the top is larger by about 1/2 inch than the frame . Using the table legs as a guide, cut out notches the size of each leg. Draw a line down the middle of the shelf, rip it in half and fit the shelf on the lower stretchers and screw into place. Screw 2 inch round furniture guides on each leg, mount the scroll saw on top, and you are ready to go!
8 Comments
blink1953 10 years ago
Really liked what you did here.. I just finished making one and made two slight modifications. I have several tools I would like to use on this stand so I cut several other pieces of plywood same size as the top. I attached all my bench tools to these bases then just clamp them on when needed. This way I can use the stand for other uses. Secondly I drilled and tapped a hole in the bottom of each leg to take a 5/8" appliance leg. This allows me to not only slide the stand easily but also level it when needed.
Wheatridge 10 years ago
Good idea. I have several other tool stands with just that modification. This very simple smaller one slides around the shop quite well on the plastic guides I mounted on each leg.
steelsun 10 years ago
chipper35 11 years ago
Wheatridge 11 years ago
mbusby 12 years ago
So as most of us older Aussies would say - pull ya head in ya drongo.
I built a shop stool basically the same way (pocket holes and PVA glue) and it holds my more than ample 145kg bulk without any problems and yes I have also used it as a step stool to change my fluro lights.
Wheatridge 12 years ago
Christopher_Moore 12 years ago
Thanks for the instructable!
