Bentwood Rings With Stone Inlay
Intro: Bentwood Rings With Stone Inlay
This is an easy bentwood ring making guide for ring bands & inlay. These rings are VERY strong miniature structures basically for wooden rings.
STEP 1: Wood
Once you have this veneer, make a 12" strip and 1/2" wide.
STEP 2: Prep
Next, get it soaked in water from the sink, and then slightly squeeze most of the water off so that the towel is not dripping any longer.
Microwave this wet paper towel with the wood strip two times. First time is for 20 seconds, re-wet the towel like previously, then again for 15 seconds.
STEP 3: Prep Cont.
Break off a 4" piece of tape and keep it within reach for later.
Begin to slowly wrap the wood around the pole. The wood does not need to be perfectly flat, this is still prep and not making the final ring. Try to do your best to keep the wood from snapping or cracking while wrapping it on the pole.
Once it is all wrapped, take the piece of tape to keep the wood wrapped while it dries in this spiral shape. Slide it off the pole for drying.
STEP 4: Sizing
Get a roll of masking tape & a pole that is smaller than the ring size you are needing for the next step.
STEP 5: Wrapping
First, you are going to need the pole, something to hold down the pole, masking tape, and an electronic measurer for precise measurements.
Second, wrap as much tape as you need WITH THE STICKY PART UPWARDS onto the pole until the diameter is what you need for the ring size + equal all around the tape (no waves, needs to be flat). THEN lay a separate piece of tape STICKY PART DOWN to keep the other section of tape from spinning on the pole.
Forth, sand the inside end of the prepped veneer. Make sure the veneer is dried by this point. This takes 24 hours usually, but at least give the prepped band 12 hours of drying before wrapping. You don't want the wood wet because it will cause your superglue to turn a white color when it dries.
Fifth, stick the sanded end of veneer on the sticky tape and add a drop of super glue. Wrap the veneer around tightly once until it meets the end again. Press your finger on the meeting point to make sure it dries flat to eachother. *Flatness and no gaps between the wraps is key to a good bentwood ring.*
Yes btw, you will have a serious case of "glue fingers" during this wrapping, and no you don't want gloves because the gloves WILL rip and tear and be glued into your ring forever. Super glue will eventually flick off your fingers with time. Make sure not to glue your fingers together as well.
Sixth, continue to add a couple of drops of super glue to the remaining strip of veneer as you slowly and carefully wrapp the rest of the band together.
STEP 6: Sanding
When sanding the inside part of the ring, VERY carefully get rid of the end strip inside. Have a ring pole sizer handy to make sure the band stays around the correct size.
For the edges, sand until the desired ring width. For the top part, try to smooth it out without digging into the ring band too much.
Have a sheet of 220 or lower grit sand paper to flatten the edges if need be.
STEP 7: Inlaying
After freshly sanding your ring to shape, get a vice and two squared pieces of wood to hold onto your ring as you work on it.
First, get some toothpicks & your super glue to help you move the tiny stones around when placing into the grooves.
Second, use a triangle shaped metal file to precisely carve away channels for your inlay. Get creative!
Third, put a single drop of super glue in the carved out channel, then start placing pieces of inlay.
Forth, once all of the channel is filled, keep applying layers of glue until the grooves are filled above the top layer of wood.
Fifth, use your dremel to carefully sand down the excess glue and stone bits so they are level with the ring surface.
STEP 8: Practice
Practice makes perfect! Once you have mastered the basic bentwood ring band, then you can move onto more complicated stuff like inlaying stone.
Check out my Instagram to see what is going on in my studio as I make bentwood ring orders from my Etsy shop. @thetreehearts
STEP 9: Finishing
You will need 220, 400, 600, 1000 & 1200 grit sand paper. Start from the lower grit to the highest grit.For a finish, I personally use an organic beezwax and olive oil finish. You can use mineral oil, coconut oil, walnut oil, hemp oil, or olive oil as well.
139 Comments
emily_c 9 years ago
Quick question, how did you keep the ring from getting superglued to your form? I've tried and successfully softened the wood and wrapped it but I always end up gluing my ring onto the form.
sbell-3 9 years ago
2. Super glue doesn't stick to polyethylene. This is the same material as the thin, clear, cheap foodservice gloves. You can use this material to line your wrapping device, as well as to keep your fingers glue-free!
thetreehearts 9 years ago
When you mention the "form" are you talking about the pole the ring is wrapped on? If so, try either using less glue or put the tape sticky-side-up on the pole first before gluing. The tape is easy to pull/sand off from the ring.
ashleyjlong 9 years ago
Very cool! Do you ever stain the wood, or do you just begin with a colored veneer? The deep colored woods and black are so striking and I just wondered if you have to do anything extra to attain that richness.
Good to know! I've never really worked with wood and wouldn't have known one from the other going into it. Thanks for the info and pic. Its a great project. I'll be surprised if this one doesn't win the goodies in the ring contest.
buildalongwithbrian 9 years ago
seamster 9 years ago
This is an excellent beginner's guide! Thank you for sharing this.
Can you share a bit on how to do those inlaid bits? I'd really like to take crack at this sometime, and love those details.
Added to the instructable the inlay portion! Check it out. :)
I think I just might have to make 2 more instructables haha. One for layered bentwood rings and the other for basic inlay. :)
rbauter 5 months ago
KellyP20 2 years ago
Tristar13 3 years ago
DanielG645 6 years ago
Beautiful!
I'm working on some on my own^^
May i ask what glue you used for the inlay? I tried clear epoxy but even after a whole day of drying it still was soft on the inside and sanding it did not work.
Swansong 6 years ago
These are absolutely gorgeous! I love the set with the white and wood grain. This is a great thorough tutorial :)
ChrisT372 7 years ago
JasonM192 7 years ago
I am having trouble getting the stones to stick to the ring with superglue. Am I doing something wrong? I ordered (what I thought was smaller stones) these are large chunks, do I just crush them down?
stillash 7 years ago
Yonatan24 7 years ago
kiaee 7 years ago
