Getting More From Your Angle Grinder
54,278
208
33
Introduction: Getting More From Your Angle Grinder
About: Ews & qualified welder/metalworker since 1998
Hi!
I have used angle grinder over twenty years.
I had allready forgot how difficult it was to use at the beginning.
Then i heard people saying that its too difficult to cut with it..
That started me to think about how to improve its handling, also i wanted to get more from it.
As it think, it can be used as a bench grinder too, and with suitable blade, it works as a circular saw, or with the right attachment its a great tool for cutting even big pipes, straight and easily.
Easy version starts from the step 1, improvements from the step 8. Attcahments for grinding and pipe cutting from the step 10
This is my simple and easy prototype for that problem, improvements makes it little more difficult.
Video tutorials shows the process.
Used tools:
Angle grinder
Welder
Drill
Material:
3mm steel plate
40 x 40 x 5mm square tubing
Piece of 30 x 30 x 3 L-profile
80mm long M12 screw and M12 nut
Two M10 screws, spring washers, and one M10 nut
Step 1: Cut the Parts..
Cut the parts to the desired size.
Sand edges smooth, and round the corners.
Step 2: Easy Mount for the Angle Grinder..
My angle grinder, as usual had threads for the handle in both sides.
Also, its very usual that those threads are little tilted, instead of pointing directly up and down.
So, when you bolt plates to them, Plates make kind of V-shape. That shape makes this simple structure firm enough, no need for extra connections.
Just line those plates and the M12 screw with the angle grinder, before welding. Keep cutting disc on its place and use right angle for lining.
Step 3: Make Extra Position for Handle..
Made a hole, big enough that thread of the handle fits through it. (10mm)
Cut it to shape, and weld nut behind the hole. ( M10 )
Tack weld it. Place and shape it so that you still manage to push "disc lock"- button. So, you can change new disc without need to remove your attachment.
Step 4: Bottom Plate..
I made a little bend for the front of the bottom plate, it helps it to slide easier.
Then made 8mm holes for the "back stop", that's the piece of 30 x 30 x 3mm L- profile, mentioned earlier.
Connected it with butt welds. That way bottom plate stays straight, and the result looks nicer.
Step 5: Connecting to the Bottom..
To connect these two parts together.
I made a simple "hinge" from a piece of 40 x 40 x 5mm square tubing.
Drilled 12mm hole to the center of the side. Made it through both sides. ( M12 screw goes trough it )
After drilling i cut it to desired length. ( 35mm )
Then i weld it to the bottom plate.
Step 6: Finishing..
Finally i grinded away some material from the " back stop ", so that angle grinder fits to move lower.
Cleaned welds with steelbrush and finally painted it black.
Step 7: How It Works??
It works as a little chop saw..
Its easier to handle when cutting freehanded..
Its more easier to use, when cutting using guide..
And of course, its easy to mount, just clamp it to the table..
And.. when you remove bottom plate, you can use extra position for the handle, to get firm grip for heavier working.
Thanks for watching!
Stay tuned...
Step 8: Improvements...
Some improvements. I'll update this section until its finally "done".
1. Another option for the handle.
2. Screw that locks the angle grinder to the stand so that it doesn't move sideways when tightening screw is loose. Good when using as a chop saw. It also secures straight cuts if tightening screw opens itself.
3. Quick tightening action with simple thump screw, made from M12 nut and piece of flat bar.
Down its loose. Up, its tightened.
4. Bigger guard for safer use.
Step 9: Improvements Continued..
1. add supports that guides angle grinder to the same line with the base, faster and easier assembly.
2. Optional support wheel, helps with wood carving and grinding.
I use Graff speedcutter discs wich are made to wood cutting and shaping with angle grinder, max rpm is 12.000.
Step 10: Attacments...
Simple grinding rest from 2mm steel.
And pipe cutting attachment. This is a prototype wich can be used with pipes between 50-125mm diameter.
Its intented to be used in jobsite works, when you need to have accurate joints. For example: When you weld pipes trough from the one side, you need precise cap to get acceptable root.
Actual final version will be for pipes over 200mm diameter.
Video shows the process:
Step 11: Woodworking..
Last video is from woodworking with it.
Works nicely with dados, grooves, and of course with a simple attachment..
Its a biscuit jointer too..
Step 12: Invention...
And...
The actual "invention" is very simple. All those attachments shown, could be much easier to install..
If tool manufactures would add this simple lug to their angle grinders.
Picture is bad, shape and size just something.. But i think that would be best location for the extra lug.
Thanks for watching..
And vote if you liked the idea..
Regards
Tuomas
Invention Challenge 2017
Before and After Contest 2017
2 People Made This Project!
  • Bikes Challenge
    Bikes Challenge
  • Remix Contest
    Remix Contest
  • Make it Move Contest 2020
33 Discussions
HappyCamper76
HappyCamper76
5 days ago
Hi.. i've seen something like that made in china...price from 8 to 12 bucks...
doing it myself i'll spend at least half of it... maybe less..
Anyway i will make it coz ain't that complicated to put together,most of all, detailed instructions are provided!!!!
Big THANK YOU FOR SHARING!!!
The other Finnish guy
Reply 5 days ago
Yep. They started to make these in China, after i posted this. 🙂
MizouL
MizouL
9 months ago
Merci Toumas.
DWiskow
DWiskow
1 year ago on Introduction
What a fantastic idea, the development of the various accessories is truly inspired . . . in response to your "Step 12: Invention . . ." I have created a 3D printed part that effectively provides a ready made "Easy Mount" for those without the welding skills and/or tools to replicate your approach.
The 3D printed Easy Mount ( https://www.thingiverse.com/thing:3257797 ) is fitted to the angle grinder with two M10x25mm bolts inserted into the two existing threaded holes (usually used for the handle). The Mount then provides a forward facing mount point perpendicular to the disk in the form of two M10 captive nuts vertically spaced 25mm apart. These two M10 captive nuts provide the means for attaching accessories to the front of the angle grinder with short or long M10 bolts as required.
Full access is provided to the spindle lock and the guard adjuster when the bracket is in place.
Bosch PWS 7-115 Mount.JPGBosch PWS 7-115 Mount (coach bolts - vertical).JPGBosch PWS 7-115 Mount (M10 x 25mm).JPG
amgleft
amgleft
1 year ago
This is awesome! I don't have the capabilities to do the welding though — would you sell one of these?
OtroZ
OtroZ
2 years ago
In process
IslamA52
IslamA52
2 years ago
i want to make it but the dimension for the base plate please.
thanks for your project.
MarianoD8
MarianoD8
Reply 2 years ago
see comment above by Toumas..
MarianoD8
MarianoD8
Question 2 years ago on Step 1
can you please post the size of the bottom plate?
Answer 2 years ago
215mm x 105mm x 3mm
Bend at the front end, 20mm distance from the front end. Square tubing that works as a hinge is placed to 22mm distance from the front edge.
MarianoD8
MarianoD8
2 years ago on Step 4
I have scaled this plate in another video and looks like 220x100 x3mm ,please clarify..
Kafukai
Kafukai
3 years ago
This is great :)
Can easily cost lot of money and space on a chop saw.
Reply 3 years ago
Thanks! Im making some improvements to it atm. I hope that i can update this next week
bothal3
bothal3
Reply 2 years ago
Thanks Tuomas.
Did you manage to add the dimentions as you intended to? I missed them somehow.
Please let me know.
sunwah
sunwah
3 years ago
Following closely I intend to try to follow the way you have shown. The problem is the Bosch grinder 'MAKITA grinder 9500N' there are no handle holes in it. I do hope you can come up a way so I could do it. Thanks.
undinstructable
undinstructable
3 years ago
Hi Tuomas, thanks for your project, I find it very interesting. I have a couple of question for you:
I see you use a drill press with a speed controller attached to it. Could you please provide details on its brand/model etc?
Also, you use a sheet bender to bend metal. It is probably home made. I'd like details on such bender, any link to project files?
And last, since I'm in the process of replacing my angle grinder, any suggestions on a decent one for hobbyist use? Bosch may be? ;-)
Thank you - regards!
Angelo
